    No more sound after installing v. 4.1 in recalbox
    MediaCenter & Dualboot
    more sound installing 4.1 recalbox
    10
    215
    112731
    • benj008
      benj008 last edited by
      merci!
      mais je n'ai toujours pas de son...
        Substring @benj008 last edited by
        @benj008 donne moi la ref exacte de ton hifiberry stp + archive de support en allant sur http://recalbox/help
        benj008 1 Reply Last reply Reply Quote 0
        • benj008
          c'est un hifiberry DAC+ standard RCA (n° modele 4260439550057)
          voici pour le lien:
          https://file.ac/H7idCNRf1ZE/
          • lackyluuk
            @benj008 @Substring
            I will test it tonight since I didn't have the chance yet to try 4.1.
            I'll give a feedback then 🙂
            • benj008
              benj008 @lackyluuk last edited by
              @lackyluuk ok thank you very much ! hope i don't bother you too much...
              • lackyluuk
                @benj008 Not at all. Actually I cannot wait any longer to try it out because I was away the whole weekend and couldnt install it. 😄 Lol
                • benj008
                  benj008 @Substring last edited by
                  @substring je ne sais pas si mon dernier message est passé desolé...le voici
                  voici pour le lien:
                  • Dragu
                    Dragu Banned last edited by
                    @benj008
                    @lackyluuk
                    I have also the issue with my hifiberry DAC+ not working with 4.1 stable.
                    Just for history, I was having the same problem with 4.1 unstable from april and switched back to 4.1 unstable from march, where the sound was working. Issue that I didnt followed. So it seems to me that something important changed between this 2 versions that was important for the DAC story.
                    What I changed so far on 4.1 stable (just today jumped in 😉 )
                    /boot/config.sys
                    comment out
                    #dtparam=audio=on
                    and put missing section
                    # uncomment for hifiberry
                    dtoverlay=hifiberry-dacplus
                    /etc/asound.conf create
                    pcm.!default {
                    type hw card 0
                    ctl.!default {
                    type hw card 0
                    etc/modules.conf
                    comment out
                    # snd_bcm2835
                    uinput
                    usbhid
                    for the moment, silence is golden.....
                    • Dragu
                      There is a very simple way to find out if the hifiberry-dacplus card is adressed.
                      On the board is a green led, when the card is in contact with a driver, it is lit. When it has no connection with software, is dark.
                      I changed again the cards and on 4.1 stable, led is not on. With my unstable from march, led and sound.
                      • benj008
                        benj008 @Dragu last edited by
                        @dragu so is it possible to get back and reinstall 4.1 from march? maybe it's one of the solutions for my issue
                        • Dragu
                          @benj008
                          I think, they should have a chance to look into this.
                          I have the system on another card, so easy for me to change, till they find a solution.
                          But if you have no image anymore from build 11603320, I have no idea.
                          • benj008
                            @dragu thanks, i was careless, i didn't have a backup of previous 4.0.1
                            • Dragu
                              @benj008
                              build 11603320 is an 4.1 unstable version, that I use (for me very stable, never had a problem).
                              I have still the image, but if I link it here, I will be in death row. 😉
                              • lackyluuk
                                @benj008 @Dragu @Substring
                                I have just installed 4.1 and my HifiBerry DAC+ is not working at all. In the settings I can only choose between AUTO, JACK and HDMI.
                                The dtoverlay in /boot/conig.txt is still dtoverlay=hifiberry-dacplus and the green LED on the card is on.
                                But somehow in alsamixer the card is not showing up. The only soundcard is the internal.
                                With cat /proc/asound/cards i get the following:
                                0 [ALSA           ]: bcm2835 - bcm2835 ALSA
                                                     bcm2835 ALSA
                                If I remove this driver I cannot access alsa or amixer anymore
                                Still try to figure out some other ways to check the soundcard implementation...
                                • benj008
                                  same for me..
                                  • Dragu
                                    In build 15156473 the problem was appearing for me.
                                      @benj008 @lackyluuk @Dragu The only things that changed regarding sound are how the volumes are set/forced at boot, so I have an idea where to look BUT as I can't test by myself, I need you guyz.
                                      So first remount / as read-write : mount -o remount, rw / then edit /recalbox/scripts/recalbox-configure.sh and comment line 409 by adding a # at the start of it and report back If it worked, remove the #, and set the volume to 100% in ES, reboot and report back.
                                      benj008 1 Reply Last reply Reply Quote 1
                                      • benj008
                                        @substring salut
                                        Tipping /recalbox/scripts/recalbox-configure.sh path in putty seems to bring me to an empty file
                                        • lackyluuk
                                          @Substring I will test it tonight when I am home. Thanks for the approach!
                                          • Dragu
                                            @Substring
                                            You sleep sometimes ?
                                            The file name is in my installation recalbox-config.sh, I think you mean the same.
                                            I made the comment out, it had no effect. I also changed in ES the sound to 100%. But the animal put it back directly to 0%, no way.
                                            I have some other issues with 4.1s, dont want to kill you. 😉
                                            100.6k
