    No more sound after installing v. 4.1 in recalbox
    MediaCenter & Dualboot
    more sound installing 4.1 recalbox
    10
    215
    112751
    • Dragu
      Dragu Banned last edited by
      @Substring
      I wish you first nice (and merited) holidays. I hope not in silicon valley 😉
      So if benj008 spend the money for a PI3 (that anywhere he will not regret) and if he contacts me, I can help him.
      benj008 1 Reply Last reply Reply Quote 0
      • benj008
        benj008 @Dragu last edited by
        @dragu hi in this case do you think a pi3 will be a good idea?
        To tell the truth i thought about it at the very begining;-)
        Anyway i m ok with this if you think it can help bringing the sound back. I precise i m far for professional in such areas sorry. But happily accept you help.
        • Dragu
          @benj008
          If you send me a mail on "amarx"@"tango.lu", I will send you back a link short time after where you can download the 4.1 march version, just not to be without gaming.
          • benj008
            @dragu ok i ll do that on monday thanks.
            And what about the pi3?
            • Dragu
              @benj008
              You know that the images are processor dependant, so I have just the PI3 version. Anyway it is double speed from PI2.
              • benj008
                @dragu ok thanks. So i ll just have to insert my old sd card with v 4.1 on the pi3 and apply the march update?
                Do i have to reinstall hifiberry soundcard before that also?
                Dragu 1 Reply Last reply Reply Quote 0
                • Dragu
                  Dragu Banned @benj008 last edited by
                  @benj008
                  You must copy the march image and make the few modifications in config.txt and make asound.conf. You sure already did it once.
                  • benj008
                    Ok done, but could anyone tell me which modificationsi have to make in config.txt and asound.conf?
                    Thanks
                    • Dragu
                      Hi Benjamin,
                      On peut aussi parler francais et je vais t'aider.
                      Il faut avoir un clavier raccordé en USB sur ton raspberry.
                      Si tu veux récupèrer tes roms et ta configuration des joysticks, il faudra après recopier tout le directory /share (/recalbox/share) sur ta nouvelle installation.
                      Mais commencant par le début.
                      Si tu te trouves dans l'écran émulation, tu pousse t'abord F4 et après ALT+F2.
                      Il te demande le login.
                      nom : root
                      passcode : recalboxroot
                      Si tout est correct, il t'affiche #.
                      Maintenant une première commande linux est importante
                      ls ---> t'affiche les directory actuel, comme ça tu vois ou tu te trouve.
                      Maintenant tu fais
                      cd / avec un espace entre
                      ls devrait maintenant t'afficher les directory avec /boot et /etc on aura besoin des deux. tu fais
                      cd boot et après
                      ls ---> maintenant du verra config.txt qui se trouve dans boot. Tu dois te mettre en droit de modifier cet fichier par
                      mount -o remount, rw /boot un espace après la virgule et -o(ctave), pas zéro
                      pour les modifications tu appelle
                      nano config.txt
                      et il va normalement ouvrir le fichier
                      Tu navigue avec le curseur et tu met un # devant cette ligne
                      comment out
                      #dtparam=audio=on
                      et après tu ajoute les lignes, tu peut les mettre directement derrière
                      # uncomment for hifiberry
                      dtoverlay=hifiberry-dacplus
                      Voilà les modifications dans config.txt, il faut encore les sauvegarder. Tu fais
                      CTRL+X et Y pour dire yes, sinon tu recommence. Pour contrôler que config.txt est bien modifié, la commande
                      cat ---> va t'afficher le contenu 🙂 On quitte boot et on revient à la base, pour cela tu fais
                      cd .. (avec un espace) Maintenant si tu fais à nouveau
                      ls il va t'afficher entre autre le directory etc
                      • Dragu
                        Nous allons dans cet directory par la commande
                        cd etc
                        Maintenant pour avoir les droits d'écriture
                        donc comme avant sans boot derrière, ok, il faut créer le fichier asound.conf ici
                        nano asound.conf
                        il est vide, il faut tout créer
                        pcm.!default {
                        type hw card 0
                        ctl.!default {
                        type hw card 0
                        CTRL+X Yes et après tu peux à nouveau contrôler si le contenu est juste avec
                        cat asound.conf
                        Gagné. On restarte la machine avec la commande
                        reboot
                        The beat goes on !
                        • benj008
                          alors merci bcp dragu ca fait bizarre d'entendre les HP cracher à nouveau!!
                          Merci à toi!
                          j'essaie de recopier le dossier share on va voir...
                          • benj008
                            @dragu une dernière chose après je te lache...
                            bon maintenant j'ai un pb de mapping de mes controles
                            j'ai deux jeux de sticks arcade + 6 boutons reliés à une carte en usb avec le rpi sur un meme plan en bois
                            configurer celui de gauche est facile (1 player) mais qd je veux configurer l'autre (2p), il prend la place du 1p mais ne s'ajoute pas impossible d'avoir les 2 qui marchent en meme temps donc, comme c'etait le cas avant...
                            si t'as une idée, je prends!
                            Merci encore
                            • Dragu
                              @benj008
                              Bizarre parceque j'ai aussi 2 encodeurs USB avec un 10, l'autre 9 boutons.
                              Et pas de problème. Ou as tu un seul USB ?
                              As tu un screenshot (Recalbox manager) avec ton menu configuration des controlleurs ?
                              La configuration se trouve dans le fichier /share/system/.emulationstation/es_input.cfg
                              Si tu copie ton ancienne sur la nouvelle, et si tous les usb sont connectés de la même maniere, ça devrait fonctionner.
                              • benj008
                                @dragu salut
                                J'ai copié collé le fichier es_input.cfg, mais ca n'a rien changé.
                                j'ai une carte usb qui gere les deux sets (controleur+6 boutons chaque + deux boutons start 1p et 2p + 1 select/insert coins + 1 hotkey)
                                En plus j'ai une manette type snes en usb que j'ai deja configurée
                                Qu'entends tu par screenshots du menuconfig des controleurs?
                                Sur recalbox manager, dans controleurs, j'ai db9, gamecom, gpio et xbox sur off. seul ps3 est sur on.
                                c'est ca qui deconne?
                                • Dragu
                                  @benj008
                                  Essai une fois d'envoyer un screenshot du Manager de ta configuration. Il faut d'abord, je pense définir tes 2 controlleurs de base, après seulement la PS3. J'ai aussi eu des problèmes avec ça.
                                  Autre chose, les update. Essai de mettre la position sur off. Pas d'update. Comme de toute façon le seul moyen propre c'est de recopier une nouvelle image en entier, mon avis.
                                  Alors c'est bon de mettre ta configuration + les Roms sur un autre support (SSD, USB stîck minimum 64GB) et le sélectionner dans le menu système. Comme ça, après un update du système, par example bug Hifiberry fixé dans 4.1 stable, c'est beaucoup plus simple de continuer et tu ne dois plus copier et recopier tes Roms et le reste.
                                  benj008 2 Replies Last reply Reply Quote 0
                                  • benj008
                                    • benj008
                                      benj008 @Dragu last edited by benj008
                                      @dragu c'est de cela dont tu as besoin?
                                      • Dragu
                                        Non, non.
                                        Sur ta console tu ouvre le menu configuration controlleurs et alors tu vas sur Recalbox Manager la ligne "screenshot" pour faire une image écran de ta console. 🙂
                                        • benj008
                                          @dragu je suis désolé je capte pas ce que tu demandes : Sur ta console tu ouvre le menu configuration controlleurs
                                          • NeeeeB
                                            NeeeeB last edited by
                                            console = pi
                                            dans EmulationStation il veut dire.
                                            Vieux geek ^^
                                            100.6k
