    No more sound after installing v. 4.1 in recalbox
    MediaCenter & Dualboot
    more sound installing 4.1 recalbox
    10
    215
    112741
    • lackyluuk
      @monsieurlefou It's the same as for me. According to Hifiberry it does not matter if the soundcard is not in modules.conf when the dtoverlay=hifiberry_dacplus is set and the dtparam=audio=on is removed from config.txt. But I don't know exactly how it works in recalbox
      • monsieurlefou
        monsieurlefou last edited by
        My config.txt seems ok, dtoverlay=hifiberry_dacplus and dtparam=audio=on removed.
        The command amixer returns this (it seems the voulume is set to 0, isn't it?):
        /etc$ amixer
        Simple mixer control 'DSP Program',0
        Capabilities: enum
        Items: 'FIR interpolation with de-emphasis' 'Low latency IIR with de-emphasis' 'High attenuation with de-emphasis' 'Fixed process flow' 'Ringing-less low latency FIR'
        Item0: 'FIR interpolation with de-emphasis'
        Simple mixer control 'Analogue',0
        Capabilities: pvolume
        Playback channels: Front Left - Front Right
        Limits: Playback 0 - 1
        Mono:
        Front Left: Playback 0 [0%] [-6.00dB]
        Front Right: Playback 0 [0%] [-6.00dB]
        Simple mixer control 'Analogue Playback Boost',0
        Capabilities: volume
        Capture channels: Front Left - Front Right
        Limits: 0 - 1
        Front Left: 0 [0%] [0.00dB]
        Front Right: 0 [0%] [0.00dB]
        Simple mixer control 'Auto Mute',0
        Capabilities: pswitch
        Mono:
        Front Left: Playback [off]
        Front Right: Playback [off]
        Simple mixer control 'Auto Mute Mono',0
        Capabilities: pswitch pswitch-joined
        Playback channels: Mono
        Mono: Playback [off]
        Simple mixer control 'Auto Mute Time Left',0
        Capabilities: enum
        Items: '21ms' '106ms' '213ms' '533ms' '1.07s' '2.13s' '5.33s' '10.66s'
        Item0: '21ms'
        Simple mixer control 'Auto Mute Time Right',0
        Capabilities: enum
        Item0: '21ms'
        Simple mixer control 'Clock Missing Period',0
        Capabilities: enum
        Items: '1s' '2s' '3s' '4s' '5s' '6s' '7s' '8s'
        Item0: '1s'
        Simple mixer control 'Deemphasis',0
        Simple mixer control 'Digital',0
        Capabilities: pvolume pswitch
        Limits: Playback 0 - 207
        Mono:
        Front Left: Playback 0 [0%] [-99999.99dB] [off]
        Front Right: Playback 0 [0%] [-99999.99dB] [off]
        Simple mixer control 'Max Overclock DAC',0
        Capabilities: volume volume-joined
        Capture channels: Mono
        Limits: 0 - 40
        Mono: 0 [0%]
        Simple mixer control 'Max Overclock DSP',0
        Limits: 0 - 40
        Mono: 0 [0%]
        Simple mixer control 'Max Overclock PLL',0
        Limits: 0 - 20
        Mono: 0 [0%]
        Simple mixer control 'Volume Ramp Down Emergency Rate',0
        Capabilities: enum
        Items: '1 sample/update' '2 samples/update' '4 samples/update' 'Immediate'
        Item0: '1 sample/update'
        Simple mixer control 'Volume Ramp Down Emergency Step',0
        Capabilities: enum
        Items: '4dB/step' '2dB/step' '1dB/step' '0.5dB/step'
        Item0: '4dB/step'
        Simple mixer control 'Volume Ramp Down Rate',0
        Capabilities: enum
        Simple mixer control 'Volume Ramp Down Step',0
        Capabilities: enum
        Item0: '4dB/step'
        Simple mixer control 'Volume Ramp Up Rate',0
        Capabilities: enum
        Simple mixer control 'Volume Ramp Up Step',0
        Capabilities: enum
        Item0: '4dB/step'
        Thanks for your help
        • lackyluuk
          @monsieurlefou You should leave dtoverlay=hifiberry-dacplus in your config.txt
          • monsieurlefou
            I confirm that dtoverlay=hifiberry-dacplus is in my config.txt.
            Just dtparam=audio=on removed
            I don't change anything since the maj 4.0.2 => 4.1
            Thanks
              Looking at dragu's screenshot, there are 3 kernel modules that are loaded along with the hifiberry.
              What also happened with 4.0.x -> 4.1 is a kernel b*mp from 4.1 to 4.4. That's the only lead I have for now + quite some changes regarding audio volumes (because of that DARN x86 version)
              • monsieurlefou
                Hi, i progress
                I reinstall from 0 recalbox 4.1.
                I modify config.txt by adding dtoverlay=hifiberry-dacplus and comment (#)dtparam=audio=on.
                No sound with emulastation but sound is come back under kodi.
                Any idea?
                thanks a lot
                • monsieurlefou
                  I don't understand.
                  After trying change audio settings in the audio recalbox menu to auto, to hifiberry, to auto (hacking the audio setting...), the sound is appears wihout i can understand what was the matter.....
                  Strange, something wrong but i cannot identify the problem.
                  Excuse my poor english...
                  • lackyluuk
                    @monsieurlefou that sounds really strange 😄
                    do you have the soundcard available in the sound settings in ES? For me it does not show up 😞
                    • Dragu
                      Dragu Banned last edited by
                      @monsieurlefou
                      You want to say that you modified recalbox.conf
                      audio.device=auto
                      ## Set system volume (0..100)
                      audio.volume=0
                      audio.bgmusic=0
                      into
                      ## Set the audio device (auto, hdmi, jack, hifiberry)
                      audio.device=hifiberry
                      audio.volume=0
                      audio.bgmusic=0
                      monsieurlefou 2 Replies Last reply Reply Quote 0
                      • monsieurlefou
                        Yes i have hifiberry dacplus soundcard in the sound settings in ES.
                        After reboot sound starts only after manipulate joystick to navigate in menu (controler xin mo). If i don't touch controler no music (??)
                        I'm not sure (sorry) but I remember that i have already the card in the sound settings BEFORE modify the file config.txt (it surprises me) but sounds doesn't work.
                        On my another pi3 with same recalbox without sound card sound start on splash screen on boot (?)
                        X-files???
                        • monsieurlefou
                          monsieurlefou @Dragu last edited by
                          @dragu
                          i don't modify recalbox.conf.
                          I just hack settings audio via the recalbox audio menu settings.
                          • monsieurlefou
                            @dragu
                            My audio setting in recalbox.conf file:
                            audio.device=[0:0] snd_rpi_hifiber - snd_rpi_hifiberry_dacplus + HiFiBerry DAC+ HiFi pcm512x-hifi-0
                            audio.volume=0
                            audio.bgmusic=1
                            • benj008
                              benj008 last edited by
                              Hi
                              Just to know if you have any news on fixing the issue?
                              Bye
                                The soud device selection in ES does more than just editing the recalbox.conf. It also sets some parameters for ALSA.
                                benj008 1 Reply Last reply Reply Quote 0
                                • benj008
                                  benj008 @Substring last edited by
                                  @substring ok j espere que vous trouverez un moyen pour retablir le son sur cette version 4.1
                                  Pourriez vous me tenir informé en tous cas ?
                                  Merci pour votre ecoute et bon courage
                                    Substring @benj008 last edited by
                                    @benj008 oui
                                      To everyone : just a few words regarding what you'd believe to be strange but may not be:
                                      • the splash video is played through omxplayer which doesn't care about soundcards. Just jack and hdmi
                                      • changing a sound device in ES woumd not change where the music is output until a reboot, wheras emulators would work straight away after. That is a lumitation of alsa not being able of dynamically changing the output device of an already running process
                                      • we know about that bug in ES where music would start after player input
                                      @monsieurlefou as your dac works, can you make a support archive ? http://recalbox/help
                                      • Dragu
                                        @Substring
                                        I dont understand what he made, as he didnt modified recalbox.conf, but has other values inside as we have ?
                                        @monsieurlefou said in No more sound after installing v. 4.1 in recalbox:
                                        @dragu
                                        • Dragu
                                          @Substring
                                          I was just testing with 4.1 stable now and the communicated value of audio.device=
                                          Nothing changed, always no sound. The same in Kodi, no found device.
                                          So I have some doubt...
                                          Perhaps possibility to provide momentary download of march 4.1us, so that the few concerned
                                          could use their machine before they have convulsions 😉 I have just PI3 version. benj008 has PI2.
                                            Substring @Dragu last edited by
                                            @dragu we don't have such old builds. What i should do is check all sound commits between march and april and see what i can do. No time for that, i'm on holidays, won't be very active for a week
                                            100.6k
