    No more sound after installing v. 4.1 in recalbox
    MediaCenter & Dualboot
    more sound installing 4.1 recalbox
    10
    215
    112739
      Substring @Dragu last edited by
      @dragu I guess I spend about 4 to 6h a day on support for 4.1 since Friday, and it's becoming exhausting ... So many people who just can't read or report false bugs ... Have to find the truth in all forum topics
      But the hifiberry IS a real regression bug that sadly I can't test at home
      Now can you make that line 409 look like :
      for param in `amixer controls | cut -d ',' -f 1` ; do recallog "Setting volume for $param" ; amixer -q cset ${param} 100% ; done
      reboot, and report ?
      benj008 1 Reply Last reply Reply Quote 0
      • Dragu
        Dragu Banned last edited by
        @Substring
        No, it has no effect. In ES the sound level is put back to 0% after leaving the sound menu.
        But in my beloved version from march, this is the same, anyway as the volume for this card is not regulable and always at max.
        I see the problem from the driver side, the hifiberry driver is not loaded. If you have the tools to run a compare between versions. If you compare build 11603320 with the stable release, somewhere shoud be the answer, I think.
        • benj008
          benj008 @Substring last edited by
          @substring same for me the 409 line looks line the one you propose already and even with the # changes, no sound again.
          But my ES seems to save volume after reboot or leavong dound menu unlike dragu..
            @dragu said in No more sound after installing v. 4.1 in recalbox:
            11603320
            ok that's the runner ID.
            Have you followed https://support.hifiberry.com/hc/en-us/articles/205377651-Configuring-Linux-4-x-or-higher ? looks like it's not "compatible" with our default config.txt
            • Dragu
              @Substring
              Yes, the modifications in the config.txt are made this way. Would also be interesting if aplay was in the package.
                @dragu aplay is not on the pi, but aplay is not useful in that case.
                Try this :
                cat > ~/.asoundrc << EOF
                pcm.!default  {
                 type hw card 0
                ctl.!default {
                 type hw card 0
                EOF
                reboot, report 🙂
                • Dragu
                  @Substring
                  No change.
                  But I have no directory /proc/asound/ as lackyluuk has.
                  • lackyluuk
                    lackyluuk Translator last edited by lackyluuk
                    @Dragu Don't know if it's relevant for this, but have you created a asound.conf file?
                    I also noticed that if I remove the internal sound card, it is added back after every reboot into /boot/config.txt
                    • Dragu
                      @lackyluuk
                      @Substring
                      Yes, /etc/asound.conf I created, is there that I made the modifications from
                      before, (cat >..) I expect it was the right place, or should this block be in /boot/config.txt ?
                        @dragu WTF ? no /proc/asound ??? i guess lackyluuk hasn't removed the dtparm=audio=on from the config.txt. But still ... I'll look at changes since March
                        Dragu 1 Reply Last reply Reply Quote 0
                        • lackyluuk
                          If I remove dtparam=audio=on in the config.txt it is automatically re-added after a reboot. Only commenting it out helps. But then I cannot access amixer, alsamixer etc anymore. And no soundcard at all is loaded
                          • Dragu
                            Dragu Banned @Substring last edited by
                            @substring
                            Take your time, I am not playing fulltime, have a rescue from march and also some other cats to whip... 🙂
                              @Dragu if you still have your march image, can you check lsmod if a specific module is loaded ? I'll check the differences on audio between april and march (and there are many)
                              • benj008
                                benj008 last edited by benj008
                                It had become a bit complicated for me... I leave it to you professionals 😉
                                Ok with Dragu i'm not in a hurry so take time
                                Could you just let me know if you find something that work it out?
                                Thank you
                                • Dragu
                                  @Substring
                                  If you tell me how to make screenshot, there is a lot. there are 6 snd_soc modules loaded snd_soc_hifiberry_dacplus and snd_soc_hifiberry_dac snd_soc_pcm512x_ic2 snd_soc_bcm2835_i2s snd_soc_pcm512x snd_soc_core
                                  thats it for the march version.
                                  In the 4.1 Stable in my configuration not one snd_soc is loaded.
                                  lackyluuk 1 Reply Last reply Reply Quote 0
                                  • lackyluuk
                                    lackyluuk Translator @Dragu last edited by lackyluuk
                                    @dragu just use raspi2png and the screenshots are saved in your shared folder
                                    • Dragu
                                      Dragu Banned last edited by OyyoDams
                                      @lackyluuk
                                      thanks.
                                      monsieurlefou 1 Reply Last reply Reply Quote 0
                                      • monsieurlefou
                                        monsieurlefou @Dragu last edited by
                                        @dragu I have also a problem with hifiberry dacplus. It worked very well with recalbox 4.0.2 but since the maj 4.1 no sound anymore....
                                        But i have this:
                                        boot$ cat /proc/asound/cards
                                        0 [sndrpihifiberry]: snd_rpi_hifiber - snd_rpi_hifiberry_dacplus
                                        Strange?
                                        Thanks for your help!
                                        • lackyluuk
                                          @monsieurlefou What Raspberry do you use?
                                          how does your etc/modules.conflook like? Do you have any other modules loaded than the internal sound card (bcm2835)? Or did you remove the internal one?
                                          It seems that your card is loaded.
                                          • monsieurlefou
                                            monsieurlefou last edited by
                                            Hi and thanks for your help!
                                            My PI is a PI3
                                            My etc/modules.conf looks alike:
                                            snd_bcm2835
                                            uinput
                                            usbhid
                                            I don't remove anything
                                            100.6k
