    No more sound after installing v. 4.1 in recalbox
    MediaCenter & Dualboot
    more sound installing 4.1 recalbox
    10
    215
    112799
      Substring @lackyluuk last edited by
      @lackyluuk i'm saying that we , recalbox dev team, should have stayed at a 4.4 kernel + compatible overlays. We're probably out of sync. That's something that never caused any harm so far ...
      • clappique
        clappique last edited by
        Hello, I have the same trouble since I've upgrade to 4.1.
        Is there an issue or should I have to buy a new hifiberry board ?
        • lackyluuk
          lackyluuk Translator last edited by lackyluuk
          @clappique I dont know what your issue is exactly. I am going to buy a new one since mine is not even recognized by the hifiberry test images.
          Have you already tried our whole discussion? 😄
          (Using an older hifiberry.dtb, using test images etc)?
          • clappique
            @Dragu i didn't see the last posts about the driver available on github.
            Everything is actually OK after some hours trying to get the sound back.
            Many thanks to this precious post and to the community ! 🙂
            • Dragu
              Dragu Banned last edited by
              @clappique
              Très bien, mais c'est @Substring qui a eu l'idée. je ne suis qu'un humble serviteur 😉
              • wegen
                wegen last edited by
                bonjour,
                plus beaucoup de news avec ce sujet. Est-ce que la compatibilité en recalbox et HiFiBerry a été corrigée ?
                Merci d'avance
                • klubad
                  klubad last edited by
                  Hi @Substring
                  I also have a rpi3 with a hifiberry dacplus. I have no sound either.
                  I followed the instructions found here. With the old hifiberry-dacplus.dtbo file, the card now shows up in reacalbox UI and alsamixer. (I got the device tree file here https://github.com/raspberrypi/firmware/tree/b4b1f641ba1290bdf275b99922e16c0194a8e54b/boot/overlays)
                  But I can't have any sound. I tried to move up every sliders in alsamixer, but still no sound. Am I missing something?
                    Substring @klubad last edited by
                    @klubad have you selected the device in ES and rebooted ?
                    klubad 1 Reply Last reply Reply Quote 0
                    • klubad
                      klubad @Substring last edited by
                      @substring yes, multiple times 🙂
                      As much as I understood, it seems that we can't set volume through ES. So if I change the volume in ES, close the sound panel and reopen, volume is set back to 0. It is the expected behavior with hifiberry card, right?
                      I can provide you dmesg output and other stuff tonight.
                        @klubad ES is not very good at setting sound volume for anything other than the pi itself tonbe honnest. Alsamixer is a much better choice.
                        grgohr 1 Reply Last reply Reply Quote 0
                        • klubad
                          @Substring well, I tried to set the volume through alsamixer (and amixer too). No sound.
                          Any advice of what I could test next?
                          • grgohr
                            grgohr @Substring last edited by grgohr
                            hello @substring maybe an old topic but there is no sound in ES since 4.1 and thought it was a temp bug but not fixed with 1802 (XU4) (sound in videointro ok, sound in game ok)
                            here are the ES logs at first boot:
                            lvl0: Error loading sound "../sounds/scroll.ogg"!
                            Audio device hasn't been opened
                            lvl2: req music [system.bgsound]
                            lvl2: playing
                            lvl2: Mix_PlayMusic: Audio device hasn't been opened
                            Going in to the sound menu and validating a soundcard activates sound in ES (sound volume is always 0 but does not affect anything, can be ignored for XU4)
                              Substring @grgohr last edited by
                              @grgohr hey !
                              The sou d card parameter is supposed to be saved. How do you turn off your recalbox ?
                              • grgohr
                                @substring even after a proper menu>quit>shutdown or reboot I have the same behaviour and ES logs:
                                lvl0: VolumeControl::init() - Failed to find mixer elements!
                                lvl0: MUSIC Error - Unable to open SDLMixer audio: ALSA: Couldn't open audio device: Device or resource busy
                                once I go to the menu>sound and change the device from auto>card or vice-versa (I hear a sound click), sound comes and back and ES logs shows:
                                lvl2: Shutting down SDL AUDIO
                                lvl2: SDL AUDIO Initialized
                                lvl2: playing
                                also sound comes back after going into a game and chaning nothing in ES menu:
                                lvl2: Attempting to launch game...
                                going back from game
                                lvl2: playing
                                it seems that the following step is the key to have proper init of sound in ES
                                  @grgohr es may be trying to open the 1st sound card which must be the HDMI output (which hsmas no mixer available)
                                  100.6k
