    No more sound after installing v. 4.1 in recalbox
    MediaCenter & Dualboot
    more sound installing 4.1 recalbox
    10
    215
    112769
      Substring @Dragu last edited by
      @dragu someone's making fun at me here, uh ? 😛
      @lackyluuk the only thing i understand is that kernel modules aren't loaded. So i guess the device is not found by the kernel.
      @Dragu do you think you can check in your march version if dmesg finds the hifiberry ?
      • Dragu
        Dragu Banned last edited by
        @Substring
        Hi,
        Yes I see it on the list. How can I send you the result of dmesg ?
        lackyluuk 1 Reply Last reply Reply Quote 0
        • lackyluuk
          lackyluuk Translator @Dragu last edited by lackyluuk
          @dragu you can create a support file. The easiest way is to let it be created by the recalbox manager. There you also get directly a link to the file which you can share
          • Dragu
            @lackyluuk
            @Substring
            Simple, thanks. Hope that everything inside.
            https://file.ac/7P8sJvtlGxM/
              @dragu Ok so in that case, we do see
              [    2.938674] snd-rpi-hifiberry-dacplus soc:sound: ASoC: CODEC DAI pcm512x-hifi not registered
              [    2.938691] snd-rpi-hifiberry-dacplus soc:sound: snd_soc_register_card() failed: -517
              [    3.012972] snd-rpi-hifiberry-dacplus soc:sound: pcm512x-hifi <-> 3f203000.i2s mapping ok
              So it really looks like a device detection problem, which can only occur at boot ...
                I'll get in touch with hifibery and see how I can get a device. By the way i saw their DAC+ is compatible with the Tinkerboard ^^
                • lackyluuk
                  @Dragu Is the green LED of your hifiberry ON? Mine is OFF.
                  @Substring Thanks for your effort. I am already looking forward for tinker support 😄 😄
                  but first i need to add hyperion leds to my n64 😉
                  • Dragu
                    @lackyluuk
                    Yes its on :D, and working. With the 4.1stable, alone in the dark.
                    You want also a copy from the march PI3 version of Recalbox ?
                    Its as download on my site.
                    • lackyluuk
                      @Dragu I am fine, thank you 🙂 I try to figure out whats wrong etc.
                      Actually I spend much more time with modding and custom stuff than with playing 😄
                        Substring @lackyluuk last edited by
                        @lackyluuk i spend much more time here and working on features for all our greedy users than playing myself lol
                        Anyway, got Super Mario Odyssey to finish, then ... the so long awaited Xenoblade Chronicles 2 !!!
                        • lackyluuk
                          @Substring Nice! I don't even own a Switch 😄 I try to finish starfox 2 on the snes mini 🙂
                          • Dragu
                            @Substring
                            Problem when you offer your time on internet, it is very quick seen as social sevice, I make this experience in germany but sure eveywhere the same. People dont realize that you must also eat and have a place to sleep. And time to sleep. 😉
                              @dragu and f*** too sometimes .. ooops hahaha
                              Hopefully there are some great people wh odo undertand that and who play the same game in return 🙂
                              I'm just waiting for hifiberry's answer for now ...
                                received a DAC+, will give it a go in a few days
                                • lackyluuk
                                  @Substring Great news! Could they give you even any further information?
                                  • Dragu
                                    @Substring,
                                    Great !
                                    When the green led is on, you are a winner.
                                      @Dragu @lackyluuk well 'im colour blind, so I can't tell if the led is green or red or god knows what. But i did get the hifiberry card in ES. No RCA cables yet at hand, but i'm sure it works. Tested on a fresh 17.11.10.2 on a pi2, using a DAC+ standard RCA version.
                                        I DO have sound through the DAC
                                          My simple step by step:
                                          • had an img of 17.11.02, burnt it to the SD
                                          • started the pi2, updated to 17.11.10.2
                                          • made the 2 edits in /boot/config.txt
                                          • rebooted
                                          • and voilà
                                          • Dragu
                                            @substring said in No more sound after installing v. 4.1 in recalbox:
                                            17.11.10.2
                                            Great, but what you did, no modifications ?
                                            I cannot understand, did you nail a chicken on the door to your hobbyroom ? 🙂
                                            100.6k
