    No more sound after installing v. 4.1 in recalbox
    MediaCenter & Dualboot
    more sound installing 4.1 recalbox
    10
    215
    112777
      Substring @Dragu last edited by
      @dragu no, Recalbox recognizes its master, I can't help ... Is that the same DAC as me that you have ?
      • Dragu
        Dragu Banned last edited by
        @Substring
        Hi,
        I have a hifiberry DAC+ with jack connector, but free RCA soldering pinholes.
        So I guess, it is the same as you. But you cannot tell me that nobody changed no code on this recently ? My luck that @lackyluuk has the same problem, so I am not standing there as fool 🙂
        alt text
        • lackyluuk
          lackyluuk Translator last edited by lackyluuk
          I have the HifiBerry DAC+, HW 1.0.
          It should be the same as @Dragu but not with the Jack but with the RCA connectors soldered to it.
          Here you can see my card: https://forum.recalbox.com/topic/8031/recal-cardboard-box
          @Substring
          have you created a asound.conf file or was it not needed?
            @dragu I'll give it a go on a pi3, but still, it does work for me 😕
            my (filtered) lsmod reports :
            Module                  Size  Used by    Not tainted
            snd_soc_hifiberry_dacplus     4100  1
            snd_soc_pcm512x_i2c     2243  1
            snd_soc_hifiberry_dac     2511  0
            snd_soc_bcm2835_i2s     6354  2
            snd_soc_pcm512x        17268  1 snd_soc_pcm512x_i2c
            snd_soc_core          125885  4 snd_soc_hifiberry_dacplus,snd_soc_hifiberry_dac,snd_soc_bcm2835_i2s,snd_soc_pcm512x
            regmap_i2c              3393  1 snd_soc_pcm512x_i2c
            snd_pcm_dmaengine       3391  1 snd_soc_core
            snd_pcm                75698  7 snd_bcm2835,snd_soc_hifiberry_dacplus,snd_soc_hifiberry_dac,snd_soc_pcm512x,snd_soc_core,snd_pcm_dmaengine
            snd_timer              19156  1 snd_pcm
            snd                    51908  5 snd_bcm2835,snd_soc_core,snd_pcm,snd_timer
            clk_hifiberry_dacpro     2278  1
            uio                     8000  1 uio_pdrv_genirq
            • lackyluuk
              @Substring Okay, I tested with another RPi3.
              • downloaded latest recalbox build -> installed
              • mounted Hifiberry DAC+
              • Removed dtparam=audio=on from config.txt
              • Added dtoverlay=hifiberry-dacplus to config.txt
              • rebooted
              Nothing happens! No LED is on, no card is visible in ES..maybe the card is kaput?
              • Dragu
                @lackyluuk
                Kaput twice no 😉
                Or voodoo or some code that changed bad in PI3 system.
                • lackyluuk
                  I tried now my hifiberry DAC+ Light card..and tada..recognized by recalbox....LOL
                  but i need my DAC+ standard...it looks really like its not working anymore..
                  • Dragu
                    @lackyluuk
                    Try onetime with
                    http://www.zclub.eu/recalbox_11603320.img.xz
                    It will recover from death.
                    Anyway, the DAC+ light is just the simple DAC, so you must declare it as
                    hifiberry-dac, not hifiberry-dacplus.
                    lackyluuk 1 Reply Last reply Reply Quote 0
                    • lackyluuk
                      lackyluuk Translator @Dragu last edited by
                      @dragu thanks, I will try it out now.
                      yes, this I am aware of. the DAC+ light was recognized, but not the DAC+ standard
                      • Dragu
                        @Substring
                        From Hifiberry Website
                        The DAC+ Light uses a different DAC chip (from ESS instead of a Burr-Brown model), which allows us to offer you an even more affordable DAC for your Raspberry Pi. It lacks some features of the DAC+: It has no integrated EEPROM (which is no problem at all) or integrated volume control. To control the volume, you need to connect it to an amplifier with integrated volume control or use so-called software volume control. The latter option is supported in many—but not all—applications.
                        For me it seems as a driver was at a certain moment renamed and perhaps the driver for DACPLUS use the wrong chipset. Like both are different.
                        That could be a plausible explication.
                        • lackyluuk
                          it becomes even more strange 🙂
                          With Dragu's image I can see with lsmod the DAC+. But the led is not working and I can also not access amixer or alsa settings...thus it does not really work...
                          dmesg tells me this (Image of Dragu):
                          [ 3.434116] snd-rpi-hifiberry-dacplus soc🔉 ASoC: CODEC DAI pcm512x-hifi not registered
                          [ 3.434130] snd-rpi-hifiberry-dacplus soc🔉 snd_soc_register_card() failed: -517
                          [ 3.515429] snd-rpi-hifiberry-dacplus soc🔉 ASoC: CODEC DAI pcm512x-hifi not registered
                          [ 3.515452] snd-rpi-hifiberry-dacplus soc🔉 snd_soc_register_card() failed: -517
                          [ 3.519463] usbcore: registered new interface driver brcmfmac
                          [ 3.519487] snd-rpi-hifiberry-dacplus soc🔉 ASoC: CODEC DAI pcm512x-hifi not registered
                          [ 3.519496] snd-rpi-hifiberry-dacplus soc🔉 snd_soc_register_card() failed: -517
                            Substring @lackyluuk last edited by Substring
                            @lackyluuk mmhhhh ... Should try with an older version of the firmware then
                            • Dragu
                              Dragu Banned last edited by OyyoDams
                              @lackyluuk
                              @Substring
                              I have exactly the same dmesg as you can see on my screenshot with march version, but try some more sound-test.
                              Because, when you enter ES, led is green! and sound working in ES, Kodi, Games.
                              When I go to the root, led goes out and it gives me the following dmesg :
                              But you really tried out the sound in ES ? Because this is working for me and @benj008 also.....
                              In line 10 he makes some mapping.
                                @dragu please select text in putty, it's automatically copied to clipboard, then paste it here surrounded by 3 back quotes, it's easier to read and manipulate 😉
                                • lackyluuk
                                  @Dragu What do you mean by "going to the root"? You mean go to the terminal?
                                  My led is off when I turn of my recalbox. No sound in ES.
                                  • Dragu
                                    @Substring
                                    ok, first time I use putty for Recalbox. Difference, the led stays green as I must not quit it. But result the same, always in working march version 4.1u
                                    [    2.754525] snd-rpi-hifiberry-dacplus soc:sound: ASoC: CPU DAI (null) not registered
                                    [    2.754540] snd-rpi-hifiberry-dacplus soc:sound: snd_soc_register_card() failed: -517
                                    [    2.757516] snd-rpi-hifiberry-dacplus soc:sound: ASoC: CODEC DAI pcm512x-hifi not registered
                                    [    2.757529] snd-rpi-hifiberry-dacplus soc:sound: snd_soc_register_card() failed: -517
                                    [    2.813147] usb 1-1.2: New USB device found, idVendor=0079, idProduct=0006
                                    [    2.813165] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
                                    [    2.813172] usb 1-1.2: Product: Generic   USB  Joystick
                                    [    2.813178] usb 1-1.2: Manufacturer: DragonRise Inc.
                                    [    2.817897] usbcore: registered new interface driver brcmfmac
                                    [    2.822122] snd-rpi-hifiberry-dacplus soc:sound: pcm512x-hifi <-> 3f203000.i2s mapping ok
                                    @lackyluuk
                                    I mean, when I leave to ssh with F4. Otherway, when I start Recalbox, led directly on and sound working.
                                    You made also the usual modifications in this march version, config.txt, asound.conf.
                                    • Dragu
                                      @lackyluuk
                                      @Substring
                                      Between 4.1u march and 4.1s all codec drivers were also updated (03.17 - 10.17) and here interesting question on the hifiberry page, with same error 517 :
                                      https://support.hifiberry.com/hc/en-us/community/posts/207236915-Dac-pro-error-in-dmesg
                                      even more interesting
                                      https://support.hifiberry.com/hc/en-us/community/posts/207234405-RPi3-and-DAC-Pro-Linux-not-working-Working-on-a-fix-
                                      • Dragu
                                        @Substring
                                        I think I found something, just follow the second link.
                                        They were having an issue with PI3,DAC+ and internal bluetooth. They proposed at this moment to disable it by the following lines :
                                        dtoverlay=pi3-disable-bt
                                        I wanted to try it out on 4.1 stable, but pi3-disable-bt not working.
                                        Perhaps the codec version is from this time.
                                          @dragu ok i'll give a go on a pi3
                                          Anyway, this looks really wierd as it used to work some time ago with bt enabled
                                            @lackyluuk @Dragu give a try to the last 4.4 commit on firmware + dtbo files : https://github.com/raspberrypi/firmware/tree/b4b1f641ba1290bdf275b99922e16c0194a8e54b/boot
                                            100.6k
