    [4.1-stable] FAQ
    [4.1-stable] faq
    44
    155
    102475
    • lackyluuk
      @dh04000 I don't think 4.0.2 is still distributed over OTA. It's highly recommended to do a clean install of 4.1
      • plootje
        plootje @lackyluuk last edited by
        @lackyluuk if i change the rpi2 tp rpi3 do inhave to install everyting again ?
        • lackyluuk
          @plootje Yes, because it installs a different OS version for each supported hardware, i think. You cannot just switch the SD card.
          If I am wrong please correct me 🙂
            Substring @plootje last edited by
            @plootje the real idea would be to use the scripts inside recalbox to save your user data on a USB key, install recalbox for Pi3 to a new SD, and then plug this key and leave it on your Recalbox.
              @plootje https://github.com/recalbox/recalbox-os/wiki/Use-an-external-usb-storage-device-on-recalbox-(EN)#optional--sync-your-usb-key-with-your-sd
              • Ledrunning
                Ledrunning last edited by
                Hello all! I've got problem after updating system. I upgraded the RecallBox 4.0.1 to 4.1 operating system and now it is very slow also on main menu. And I see 100% 4th core loading. What I did wrong? PS: I'm using CRT TV and on 4.0.1 version I've played perfect.
                jeevuz Edvis 2 Replies Last reply Reply Quote 0
                • jeevuz
                  jeevuz @Ledrunning last edited by
                  @ledrunning Hi i have the same problem. in HDMI works perfect in crt tv i have bad sound quality and bad performance. In 4.0.2 it works great. Try update and new install, the result is the same.
                  Pd: sorry for my english.
                  • Edvis
                    Edvis @Ledrunning last edited by
                    @ledrunning I have the same problem
                    • Ledrunning
                      @ledrunning said in [4.1-stable] FAQ:
                      Maybe Rpi 2 doesn't support on this version?
                        Many people seem to have slowdowns with CRT, i'll have a look once I have time (but i didn't have any when I tested ...)
                        Caramasof 1 Reply Last reply Reply Quote 1
                        • Ledrunning
                          It would be great!!!
                            Substring @Ledrunning last edited by
                            @ledrunning Tell me one thing : anything running on GPIO ?
                            Ledrunning 1 Reply Last reply Reply Quote 0
                            • Ledrunning
                              Ledrunning @Substring last edited by Ledrunning
                              @substring nothing...
                              And this is my conf...
                              disable_overscan=0
                              sdtv_mode=2
                              hdmi_group=1
                              hdmi_mode=16
                              gpu_mem_256=128
                              gpu_mem_512=256
                              gpu_mem_1024=512
                              #hdmi_force_hotplug=1
                              temp_limit=65
                              kernel=zImage
                              disable_overscan=0
                              overscan_scale=1
                              #Здесь также ничего не трогаем!
                              arm_freq=1050
                              core_freq=250
                              sdram_freq=450
                              force_turbo=0
                              over_voltage=6
                              over_voltage_sdram=0
                              gpu_freq=250
                                @ledrunning please provide me a support archive
                                • Ledrunning
                                  @substring said in [4.1-stable] FAQ:
                                  Sorry, what do you mean? Is these some logs? Where can I find it?
                                  • lackyluuk
                                    @Ledrunning This:
                                    https://github.com/recalbox/recalbox-os/wiki/Recalbox-support-(EN)
                                      @ledrunning for some people, deactivating audio-pwm-mode=2 in /boot/config.txt did the trick
                                      Ledrunning 1 Reply Last reply Reply Quote 1
                                      • Caramasof
                                        Caramasof last edited by Caramasof
                                        Hello every body!!! Congratulations for the 4.1!! You are awesome!! Thanks!!
                                        I need you help because i want to connect my bluetooth controllers ( two gamesir G3S and a chinese controllers) but i doesn't work...
                                        Before the 4.1, i used a dongle for connect the G3S and a cable for the chinese but now i want to use the internal bluetooth.
                                        I have forget the connection with all my controller in the system and when i scan for connect them i have the controller but if i choose them i have "impossible to connect".... i have reset the controller but it isn't change anything... sometime it work it but it reconize the controller on keybord and i can configure just the power switch...
                                        Nobody can help me?
                                        (I'm sorry for my bad english 😅)
                                        Thanks.
                                        Config : raspberry pi 3 + card SD 16Go simple boot with stockage anyexternal.
                                          Substring @Caramasof last edited by
                                          @caramasof have a look at https://github.com/recalbox/recalbox-os/wiki/Connect-bluetooth-controller-manually-(EN)#if-your-recalbox-version-is-41x-or-later if you're ddesperate ...
                                          are you sure you resettted your pads ?
                                          Caramasof 1 Reply Last reply Reply Quote 0
                                          • Caramasof
                                            Caramasof @Substring last edited by
                                            @substring
                                            Thanks for your help, yes i have reset my controller and i have test with all his configuration (mode apple, android, android + mouse and PC/PS3) but all mode have the same results....
                                            I will test your link and i will be back if work it.
                                            Thanks
                                            100.2k
