    [4.1-stable] FAQ
    [4.1-stable] faq
    44
    155
    102466
      Google Public DNS
      IPv4 : 8.8.8.8 et 8.8.4.4
      IPv6 : 2001:4860:4860::8888 et 2001:4860:4860::88442
      • Schnubbi
        Schnubbi last edited by
        This post is deleted!
        • jac666
          jac666 @jac666 last edited by
          @jac666 (for me).
          It work!!! Great news!!!
          • chris256
            chris256 last edited by
            Hello !
            I would like to install a multiboot with raspbian and Recalbox 4.1 using NOOBS. I tried to follow the following procedure :
            https://github.com/recalbox/recalbox-os/wiki/Créer-un-dualboot-raspbian-recalbox
            but I don't find the "os" folder of Recalbox to put in the noobs "os" folder of NOOBS (I downloaded and extracted all RPI3 archives and did not find this folder : boot.tar.xz, root.tar.xz and recalbox.img).
            Could someone tell me how to proceed ? Thanks !!!
            • Fudoh
              Fudoh last edited by
              Thanks and congratulations on the new milestone!
              Just a quick question: does any of the 4.1 images available on the archive page already support the Pi Zero ?
              • ZML
                ZML last edited by
                1. "No update" on Pi3. >retry
                2. "Update available, do you want update ?" >yes
                3. "Update fail" and reboot. >d**n...
                4. "No update" >retry
                5. ... 😞
                  Substring @ZML last edited by
                  @zml well the canary may sometimes give headaches ...
                  • goroots
                    goroots last edited by
                    Bonjour, est ce normal que la mise a jour prenne autant de temps.... une heure qu'elle tourne sur en cours, j'ai toujours la musique qui tourne mais par contre les petits carré en guise de sablier ne tournennt pas... snif snif
                    Pi3b+ sd Samsung 32gb + clef sandisk 256gb.
                    Theme next pixel 480p.
                    Xbox 360+adaptateur Microsoft, ds4, xbox one filaire, 8bitdo nes pro+arcade, 2 Wiimot gun avec dolphin bar, Clavier sans fil viboton.
                    goroots 1 Reply Last reply Reply Quote 0
                    • Jesús BL
                      Jesús BL last edited by
                      Thanks and congratulations for the very desired new version 🙂
                      Trucos y recetas para raspberry pi:
                      http://malagaoriginal.blogspot.com.es/search/label/raspberry pi
                      • stigzler
                        stigzler last edited by stigzler
                        Fabulous Work folks! Great to see the new release of the best SBC FE I've used so far. Thanks. 🙂
                        I've got both a Pi3 build and a XU4 build. How's it working on the XU4? Been waiting on a Batocera/GameStation alternative for over a year now!
                        • goroots
                          goroots @goroots last edited by
                          @goroots said in [4.1-stable] FAQ:
                          Pour ceux qui auraient le même soucis. J ai eu peur mais j ai éteint mon pi3 et je l ai rebooté et miracle la mise a jour s'est installée... merci beaucoup a tous pour votre travail de titan qui nous permet de rester de grand enfants 😍
                            Substring @stigzler last edited by
                            @stigzler The XU4 works just great. Mostly missing video hardware decoding for moonlight and kodi, but everytihng else runs just perfect, dreamcast almost at 100%
                            stigzler 1 Reply Last reply Reply Quote 0
                              rockaddicted @Fudoh last edited by
                              @fudoh on archive dl a rpi1 image. It is same used on rpi0-w
                              • stigzler
                                stigzler @Substring last edited by
                                @substring Truly Cool Beans 😄
                                • Chipiok
                                  Chipiok last edited by Chipiok
                                  Congratulation for the huge work, I have a question, is someone have problem of blackscreen with PSP games ? I try 3 games (Shin Budokai 1 and 2, Daxter all in .cso extension) on my RPI3 (not overclock). Sorry for bad english I'm French.
                                  Je détaille le problème en Français pour que ce soit plus clair, lorsque je lance un jeu PSP, écran noir et rien ne se passe il faut que je fasse plusieurs fois Hotkey+start pour espérer retourner sur le menu Recalbox avec un RPI3 non overclocké, j'ai essayé avec Daxter, DBZ Shin Budokai 1 et 2,tout 3 en .cso, est-ce les jeux qui sont trop puissants peut-être ?
                                  • Marcelo Souza
                                    Marcelo Souza last edited by
                                    Finally my SnesPI has the "Eject' button working with this release. I don´t know why, but now i can press "Exit emulator" Combo Keys (Select + Start in my case) from any controller, not only from the 1P. That was one of my main issues before. But the Reset stills not working (It´s mapped as one of GPIO controller buttons, i guess Button 4 along with the Select + Start for having the eject working... But i can´t assign a new key on Retroarch coming from the Third Player (GPIO), it´s only getting Hotkey bindings from Player 1 controller (USB). 😞 So the reset isnt working i guess i will have to modify the hardware and make the reset do a combo press on SELECT (Hotkey) + A, so it will probably work across all emulators... I hope...
                                    Check it working (EJECT button) https://www.instagram.com/p/BaNU30EHFxZ/?taken-by=msouza3d
                                    • duri3
                                      duri3 last edited by
                                      Is it possible I still do not get the update?
                                      I'm on the latest 4.1 unstable from april and I changed "Update typ" to "Stable" too.
                                      Why does it say Available Update -> not connected? Do I need to change the Update URL somewhere too?
                                      Can somebody help me?!!!
                                      2_1507956410292_IMG_4045.jpg 0_1507956410291_IMG_4046.jpg 1_1507956410291_IMG_4047.jpg
                                      plootje 1 Reply Last reply Reply Quote 0
                                      • DacK
                                        DacK last edited by
                                        Nothing here either 😞
                                        No update found from 4.0.2 since yesterday.
                                        • plootje
                                          plootje @duri3 last edited by plootje
                                          @duri3 for me the same, running 4.1 unstable, no update available !
                                          please somewone help !
                                          • plootje
                                            plootje last edited by
                                            100.2k
