    [4.1-stable] FAQ
    [4.1-stable] faq
    44
    155
    102396
    • gmgman
      gmgman last edited by
      looking forward to checking out the new version. thanks very much to the entire Recalbox team.
        voljega Banned @Fishou last edited by
        @aphrodite The new romset for fba_libretro will be 0.2.97.39
          added arcade romsets version + no sound on splash video for pi with USB audio
            added 2 PC paragraphs
            • charlesmarried
              charlesmarried last edited by
              Amazing news!!!! The new emulators Will be also in this update such as msdos? You are great!
                Substring @charlesmarried last edited by
                @charlesmarried https://github.com/recalbox/recalbox-os/wiki/Board-Compatibility-(EN) is up-to-date regarding emulators compatibility
                mr_0ta 1 Reply Last reply Reply Quote 0
                • mr_0ta
                  mr_0ta @Substring last edited by
                  @substring said in [4.1-stable] FAQ:
                  And nintendo DS? Because that list is from the beta, right?
                    The goal of a beta release is not to add new features, but to fix bugs.
                    Anyway do you know an open source emulator able to emulate NDS on rpi ?
                    On PC ok, and will be added later. But on rpi...
                    • mr_0ta
                      mr_0ta @rockaddicted last edited by
                      @rockaddicted
                      No, I know that retropie uses two cores MelonDs and Drastic that works very well in ARM processors, see Android that are similar processors, I have not tried the truth, only Drastic in android
                      But thanks by the info.
                        MelonDS works well on arm ? you must have an i7 cpu to be able to use it with a good framerate.
                        About Drastic, I told you an open source emulator, and it is a closed source... So it will never be added on recalbox.
                        For your information all "emulators" on android market are fork/rebranding of known and legit emulators.
                        Medusa still in alpha dev, desmume unplayable on rpi (will be added on pc and maybe odroid) an melonds strong pc necessary.
                        • NeeeeB
                          NeeeeB last edited by
                          And that's very unfortunate for Drastic (closed source), because it runs really well on mid range android device...
                          Vieux geek ^^
                          • mr_0ta
                            @rockaddicted said in [4.1-stable] FAQ:
                            I understand, and said that Drastic works well in ARM, MelonDs I do not know, but I understand that they are forks, I had seen that somebody out there had implemented the drastic in an image, and I do not know why I expected you to implement it as experimental also, anyway thank you for the clarification, and forgive the inconvenience. A greeting.
                            • MarcDK
                              MarcDK last edited by
                              Hi,
                              I am using a multi-boot image with recalbox and OSMC and upgraded 4.0 to 4.1 unstable back in April. What do I have to do to upgrade to 4.1? Do I have to wait for a new multiboot version with 4.1 stable? Any chance I just hit the update button and everything works fine?
                              https://marc.tv
                                rockaddicted @MarcDK last edited by
                                @marcdk backup your system, switch updates.type to stable in the recalbox.conf and try to update.
                                • MarcDK
                                  Ok, I try. I changed the config to "stable" but available update tells me "not connected" Does that mean, I did something wrong or is the update still not up?
                                  https://marc.tv
                                  kelv 1 Reply Last reply Reply Quote 0
                                  • kelv
                                    kelv @MarcDK last edited by
                                    @marcdk same here
                                    Raspberry Pi model: RPi 3b+
                                    Recalbox build : 7.0.1 DragonBlaze
                                    Hardware: MicroSD UHS 128 GB up to 80 MB, Class 10 and 2.5 A Power Supply.
                                    Overclocked: 1485 MHZ
                                    Controller(s): Wired Xbox 360 PAD (working perfectly on any other game/emulator).
                                      it takes time for the DNS to update worldwide
                                      • jac666
                                        jac666 last edited by
                                        Hi,
                                        Where I can download .img of recalbox 4.1 for Pi, PC, etc.?
                                        I don't want used update of 4.0.1, 4.0.2, etc.
                                        https://archive.recalbox.com/ is out of order!
                                          rockaddicted @jac666 last edited by rockaddicted
                                          @jac666 retry, it your dns that aren't updated.... Ok at home
                                          jac666 1 Reply Last reply Reply Quote 0
                                          • jac666
                                            jac666 @rockaddicted last edited by
                                            @rockaddicted, thanks for you help.
                                            https://archive.recalbox.com/ is already dead ("Adresse introuvable" with FireFox).
                                            I have tried on https://github.com/recalbox/recalbox-os/releases but only 4.0.1 version is available.
                                            I will try tomorrow.
                                            "Bon courage pour la suite"
                                            100.2k
