    [4.1-stable] FAQ
    [4.1-stable] faq
    44
    155
    102473
      paradadf Staff @Javier Sandoval last edited by
      @javier-sandoval he didn’t write OS (Operation system) but FS (File system)
      Javier Sandoval 1 Reply Last reply Reply Quote 0
      • Javier Sandoval
        Javier Sandoval @paradadf last edited by
        @paradadf said in [4.1-stable] FAQ:
        isnt that the same thing? i mean i do understand the diference betwen FS and OS but what i mean is, the end user experience is what matters. But at the same time i understand that if theres not much interest in a feature, most likely it will not be developed.
          @javier-sandoval the share partition was FAT32, but because of many reason, it was decided to change it to a linux native FS. Recalbox is a linux distro anyway... as it was already mentioned.
            Substring @Javier Sandoval last edited by
            @javier-sandoval mount your partitions from recalbox, update what has to be updated "manually"
            • Dmx
              Dmx last edited by Dmx
              Hi,
              I read the FAQ (yeah really :)) and I'm still on Unstable 4.1, Version is dated 23.03.17. I know the FAQ says April etc. and also I'm not seeing the Update in the GUI, but is it still possible to Update (somewhat) safely to the Stable Release?
              Or can I Update to the lastet Unstable and then to Stable?
              I'm asking because I have a Multiboot System with Libreelec set up and would rather avoid reinstalling everything 😕
              • stigzler
                stigzler last edited by
                Hi devs,
                Finally found opportunity to test this on Pi3. Firstly, just to say HUGE THANKS for all the work you guys have put into this. It's awesome!
                Secondly - is this the place to post bugs? If so, few bits:
                1. Kodi doesn't appear to be able to be controlled via the joypad? Just a keyboard?
                2. When trying to scrape via Screenscarper, get the following error: "Error saving image. Out of memory? Disk Full?" Works fine with GamesDB
                3. Didn't 4.1 Unstable have some facility to transfer setup from SD Card to external USB drive? Did this disappear in the stable release?
                thanks again
                • rgdhogcxsrz
                  rgdhogcxsrz last edited by rgdhogcxsrz
                  Hello,
                  Thanks to all the team and the community for this great job!
                  Unfortunately for me Recalbox 4.1 crashed on my Rpi3 and did not restart.
                  I'm going to reinstall it, here's a screenshot of the error messages I got "kernel panic". (screenshot kernel panic -> https://ibb.co/cUEyqw)
                  text alternatif
                  Thank again
                  • Raphael Bueno Hatencia
                    Raphael Bueno Hatencia last edited by Raphael Bueno Hatencia
                    Hi!
                    I can´t stop emulation station from the manager. F4 on keyboard won´t work either. Is this normal in 4.1?
                    Thanks
                    • Chrisser
                      Chrisser last edited by
                      can i upgrade from V4.1.0-DEV to the new 17.12.02 Version by flashing the .img file on the SD Card again BUT without losing my config, roms, savegames etc.?
                      Thanks!
                        Substring @Chrisser last edited by
                        @chrisser flashing erases everything, that's no update
                        Chrisser 1 Reply Last reply Reply Quote 0
                        • Chrisser
                          Chrisser @Substring last edited by
                          @substring
                          and is there another way to get this version on my system?
                            @chrisser have you read the 1st post ? Conditions to upgrade from a dev version are explained
                            • francois lefebvre
                              francois lefebvre last edited by
                              hi, i need your help.
                              I don't know why but my recalbox boot only on the favotites or on a single play station.
                              How can i put the carousel to choose a games console?
                              i have try to modify the boot option but i don't manage to put the carousel....
                              thanks for helping me.....
                              lackyluuk 1 Reply Last reply Reply Quote 0
                              • lackyluuk
                                lackyluuk Translator @francois lefebvre last edited by
                                @francois-lefebvre you have to add roms (games) to let the different systems appear. But anyway you should see some systems by default when you install recalbox from scratch
                                francois lefebvre 1 Reply Last reply Reply Quote 0
                                • francois lefebvre
                                  francois lefebvre @lackyluuk last edited by
                                  @lackyluuk thanks for your response
                                  but i have already add roms in different system.
                                  i had the carousel before but now it boot only in the favorite or on a selected console (from the boot option). and i can't select another console.
                                  i don't know why...
                                  100.2k
