    [4.1-stable] FAQ
    [4.1-stable] faq
    44
    155
    100158
    • Ledrunning
      Ledrunning @Substring last edited by
      @substring said in [4.1-stable] FAQ:
      for some people, deactivating audio-pwm-mode=2 in /boot/config.txt did the trick
      Ok I will try on evening
      • Caramasof
        Caramasof @Substring last edited by
        https://github.com/recalbox/recalbox-os/wiki/Connect-bluetooth-controller-manually-(EN)#if-your-recalbox-version-is-41x-or-later
        So, i've test this procedure but i obtain this :
        [bluetooth]# pair 85:55:06:78:6F:30
        Attempting to pair with 85:55:06:78:6F:30
        Failed to pair: org.bluez.Error.InProgress
        [bluetooth]# connect 85:55:06:78:6F:30
        Attempting to connect to 85:55:06:78:6F:30
        Failed to connect: org.bluez.Error.Failed
        [bluetooth]# trust 85:55:06:78:6F:30
        Changing 85:55:06:78:6F:30 trust succeeded
        When i boot without my USB, with lot of tests i have connect one controller but when i restart with my USB the controller don't work and i can't reconnect it...
        A idea?
        On Recalbox Manager/ Controllers i have change the plugin PS3 on "Original" and i think it's better but if i save, it return to "Bluez 5"...
        I am sure it's possible ^^
        Thanks for your help.
          Substring @Caramasof last edited by
          @caramasof manually edit the recalbox.conf for the PS3 driver, it works. At least it should. But for now, on every update, it will be reset to bluez.
          Which controller did you try to pair with bluetoothctl ? not a PS3 i hope ?
          Caramasof 1 Reply Last reply Reply Quote 0
          • Caramasof
            No i have try with a Gamesir G3S (https://www.amazon.fr/GameSir-G3s-Bluetooth-Compatible-Smartphone/dp/B019PXVCDQ/ref=sr_1_1?ie=UTF8&qid=1508243170&sr=8-1&keywords=gamesir+g3s)
            She have a PS3 mode or other type of connection. Before with the dongle i use the PC mode for connect them (the recalbox call him "Xbox 360 pad").
            What i edit on recalbox.conf? And i have see a second recalbox.conf with the 4.1 what it's different?
              @caramasof I told you about the ps3 driver, and manually set it to bluez. I don't remember the exact key, probably controllers.ps3.driver.
              But on which mode can your gamesir work ? PS3 ? PC ? On PS3, I'm not sure the pairing process would be like a regular PS3. Does your pad come with a dongle ?
              • Caramasof
                @substring I have succeeded!!! So i think i have had a bug because i have try and try and try... and it's work!!
                When i look the config, it's set on bluez so i don't change and i retry with all mode of the manette every time.
                So if anybody it's interessed for Gamesir G3S pad, power it with "B" + "Home" and select the bluez mode for PS3 controllers.
                Thanks for your help @Substring you are awesome!
                • plootje
                  plootje last edited by
                  How to control C64 like start, select, a,b,x,y and joypad ? anybody ?
                    Substring @plootje last edited by
                    @plootje it's a libretro core, it all mapped the way it is intended. But remember it's a computer that requires a keyboard
                    • Ledrunning
                      Ledrunning last edited by
                      @Substring Hello all! What I should to do for entering into safe mode to change my /boot/config.txt? I tried to press Shift before the os is loaded, but it doesn't work... This method works great at past version.
                        Substring @Ledrunning last edited by
                        @ledrunning Just let recalbox start, log in with SSH, type mount -o remount, rw /boot and then you can edit (via WinSCP seems the easiest)
                        Ledrunning 1 Reply Last reply Reply Quote 0
                        • Ledrunning
                          WinSCP
                          I try edit /boot/config.txt via Putty, but I see a message that file is read only...
                            @ledrunning You forgot the command I mentionned
                            • lackyluuk
                              @Ledrunning For your reference: https://github.com/recalbox/recalbox-os/wiki/Make-a-partition-writable-(EN)
                              This Mini How-To is here for reading..believe it or not 😉
                              • Ledrunning
                                @Substring Thank you! Everything works great!
                                • toniosj
                                  toniosj Spanish moderator last edited by
                                  In recalbox Manager, the CRC for dc_flash.bin is d6e11a23f1fa01cddb5dfccf7e4cc8d7. It's not the same in the faq.
                                    Substring @toniosj last edited by
                                    @toniosj nevermind, te manager just handles 1 hash per file for now. But the DC accepts almost any valid bios
                                    • plootje
                                      plootje last edited by plootje
                                      what kind of mame roms can be played at rpi2 ? 0.78 and ... what settings ?
                                        voljega Banned last edited by
                                        @Substring @rockaddicted @acris
                                        Hello I updated arcade documentation on the wiki for 4.1 final but there are a few links wich I don't know how to update, between github wiki and the moving of the code to gitlab where I can't find anymore the recalbox-buildroot project.
                                        How to update the following links for FBA 0.2.97.139 ?
                                        https://raw.githubusercontent.com/recalbox/recalbox-buildroot/rb-4.0.X/board/recalbox/fsoverlay/recalbox/share_init/roms/fba_libretro/fba_libretro_gamelist.txt
                                        https://raw.githubusercontent.com/recalbox/recalbox-buildroot/rb-4.0.X/board/recalbox/fsoverlay/recalbox/share_init/roms/fba_libretro/fba_0.2.97.37.dat
                                        Substring paradadf 2 Replies Last reply Reply Quote 0
                                          Substring @voljega last edited by
                                          @voljega said in [4.1-stable] FAQ:
                                          https://gitlab.com/recalbox/recalbox/blob/master/package/recalbox-romfs/recalbox-romfs-fba_libretro/roms/fba_libretro/clrmamepro/fba_libretro_gamelist.txt
                                          fba_0.2.97.37.dat
                                          https://gitlab.com/recalbox/recalbox/blob/master/package/recalbox-romfs/recalbox-romfs-fba_libretro/roms/fba_libretro/clrmamepro/FB Alpha v0.2.97.39.dat
                                            voljega Banned @Substring last edited by
                                            @substring thanks !
                                            100.1k
