    [4.1-Unstable] Bug reports
    4.1 bugs
    46
    349
    397352
      Substring @DjLeChuck last edited by
      @DjLeChuck prolly kodi, i made a bug abt it
      • lackyluuk
        @Substring Just a very small "bug". During the splash video, when the recalbox-logo appears it looks sharp (shapes, font etc) But when the controls starts to rotate, the whole thing becomes quite blurry -.- any reasons about this?
          Substring @lackyluuk last edited by
          @lackyluuk might be simply video related, does the same happen if you watch the video on a PC ?
          • lackyluuk
            @Substring yes, the same behaviour. It seems that the elements are overexposed. Also the rotating controls on top.
              @lackyluuk I guess the video was rendered that way 🙂
              • lackyluuk
                @Substring alright 🙂 maybe the creator considers to update it one day 😄 (of course only this is a bug and not wanted)
                Raphael Bueno Hatencia 1 Reply Last reply Reply Quote 0
                • Raphael Bueno Hatencia
                  Raphael Bueno Hatencia @lackyluuk last edited by
                  @lackyluuk I don´t think it is a bug, it was blurry on the render to shine more I think. I´ve made my custom video intro with some classic gameplays and everything is sharp, just the end of the movie that fades off the opacity. That´s cool because I finished the video with Ryu Hadouken(SF2) =D soo its all white at the end. perfect
                  • treacle
                    treacle last edited by
                    I see a horizontal 1 pixel line flashing up during that intro animation. during the rotation. pretty much in the middle of the screen.
                    • treacle
                      Another issue I ran into: I can't update. The system always tells me there is an update. Then I start the update... After a while I'm asked to reboot. When I reboot, I see the startscreen, then the installation doesn't happen. Instead, it restarts, and I end up in the same version (with the popup mentioning there's an update available).
                        Substring @treacle last edited by
                        @treacle i bet you're using a 4.1 from an img, not a 4.0 upgrade ?
                        treacle 1 Reply Last reply Reply Quote 0
                        • ferminote
                          ferminote last edited by
                          In web interface can´t change ps3 controller to xbox controller
                          Change checkboxes but not can´t apply changes.
                            Substring @ferminote last edited by
                            @ferminote i don't understand a single word 😕
                            ferminote 1 Reply Last reply Reply Quote 0
                            • treacle
                              treacle @Substring last edited by
                              @Substring umm, yes... didn't think that would be an issue 🙂
                              So should I rather install 4.0.1 and update from there?
                              • ferminote
                                ferminote @Substring last edited by
                                @Substring
                                in web manager 4.1, In the controls section I can not apply the changes when I select r xbox driver instead of ps3.
                                ferminote Substring 2 Replies Last reply Reply Quote 0
                                • sevenx
                                  sevenx last edited by
                                  Today i wanted update the Recalbox System RECALBOX 4.4.13-v7 #1 SMP Sun Mar 5 10:04:42 UTC 2017 on my Pi3.
                                  But while updating, it canceled with the follow error message:
                                  tar: can't open './usr/recalbox-manager2/node_modules/core-js/library/modules/_object-assign.js': No space left on device
                                  df -h:
                                  Filesystem Size Used Available Use% Mounted on
                                  /dev/root 1.3G 825.2M 399.0M 67% /
                                  devtmpfs 236.7M 0 236.7M 0% /dev
                                  tmpfs 240.9M 0 240.9M 0% /dev/shm
                                  tmpfs 240.9M 4.0K 240.9M 0% /tmp
                                  tmpfs 240.9M 2.8M 238.1M 1% /var
                                  tmpfs 240.9M 120.0K 240.8M 0% /run
                                  /dev/mmcblk0p1 63.0M 6.9M 56.1M 11% /boot
                                  /dev/mmcblk0p3 27.9G 1.1G 25.4G 4% /recalbox/share
                                  Any tips?
                                  • ferminote
                                    ferminote @ferminote last edited by acris
                                    http://subefotos.com/ver/?a420a98af8d38a06671c0a08e7aa5782o.jpg
                                    http://thumbs.subefotos.com/a420a98af8d38a06671c0a08e7aa5782o.jpg
                                      @ferminote You could have made the effort of reading through this topic, we said xboxdrv has been removed in favor of the xpad kernel driver. xboxdrv no longer works on 4.1 as it's not compatible with kernel 4.4
                                        Substring @sevenx last edited by
                                        @sevenx are you on a .img version ?
                                          @treacle and @sevenx we're having strange issues with the .img version where tar complains about missing space on / whereas there is usually like 400MB free. We have 2 ideas to solve that, it's on our issues list and we're working on it right now
                                          sevenx 1 Reply Last reply Reply Quote 0
                                          • sevenx
                                            sevenx @Substring last edited by
                                            @Substring
                                            Hi Sorry, yes i have installed a .img Version of the unstable Version.
                                            Is there anything that i can do, or. can help?
                                            100.8k
