    [4.1-Unstable] Bug reports
    4.1 bugs
    46
    349
    397444
    • Dragu
      Dragu Banned last edited by
      @Substring
      Some more informations. The Audio section in recalbox.conf looks strange with the cutoff hifiberry name. If you change it by hand, it comes back automaticly to this entry. I dont find the source from.
      ------------ C - Audio ------------
      Set the audio device (auto, hdmi, jack)
      audio.device=[0:0] snd_rpi_hifiber - snd_rpi_hifiberry_dacplus + HiFiBerry DAC+ HiFi pcm512x-hifi-0
      Set system volume (0..100)
      audio.volume=0
      Enable or disable system sounds in ES (0,1)
      audio.bgmusic=1
        Substring @Dragu last edited by
        @Dragu inly the [0:0] should matter
        • Dragu
          @Substring Thanks for your great job. There is nothing urgent, I have a full (SD) card game 🙂 I'am anyway not enough tough to dig deeper inside, so I have time but just wanted to report the problem.
          • dh04000
            dh04000 last edited by
            An ES crash occurs if you change the state of the last rom/item in a game category to "hidden".
            lackyluuk 1 Reply Last reply Reply Quote 0
            • lackyluuk
              lackyluuk Translator @dh04000 last edited by
              @dh04000 it has the same behaviour when you delete the last rom of a system
                rockaddicted @lackyluuk last edited by
                @lackyluuk said in [4.1-Unstable] Bug reports:
                @lackyluuk should be fixed now on 4.1
                • lackyluuk
                  Great to hear! Thanks!
                  • Michael Muguet
                    Michael Muguet last edited by
                    Hi,
                    The MySQL support seems to not been compiled in Kodi 16.1 since 4.1.0
                    Here is Kodi log :
                    12:24:04 T:1926729728 ERROR: MySQL library requested but MySQL support is not compiled in. Falling back to sqlite3.
                    12:24:04 T:1926729728 ERROR: Unable to create new database
                    • kelv
                      kelv @dewen last edited by
                      @dewen same issue with ZanacxZanac 😕
                      Raspberry Pi model: RPi 3b+
                      Recalbox build : 7.0.1 DragonBlaze
                      Hardware: MicroSD UHS 128 GB up to 80 MB, Class 10 and 2.5 A Power Supply.
                      Overclocked: 1485 MHZ
                      Controller(s): Wired Xbox 360 PAD (working perfectly on any other game/emulator).
                      100.8k
