    [4.1-Unstable] Bug reports
    4.1 bugs
    46
    349
    397400
      regarding PPSSPP autoconfiguration, a fix can be tested byt setting updates.type=gitlab/64-b*mp-configgen
      • azvarel
        azvarel @Substring last edited by
        @Substring said in [4.1-Unstable] Bug reports:
        @azvarel messing around with es_systems.cfg is definitely not recommended as updates would erase it. There could be a way of having a custom version of this but in that case, you wouldn't get updates. So just get used to it, it's not such a big deal, is it ? 😉
        I have to conform
        regarding DC : no idea of your problem. What sound output are you using ?
        HDMI
        regarding PPSSPP autoconfiguration, a fix can be tested byt setting updates.type=gitlat/64-b*mp-configgen
        Where it would apply this definition?
        Zodian Theme | #SNESProject
        Substring azvarel 2 Replies Last reply Reply Quote 0
          Substring @azvarel last edited by
          @azvarel said in [4.1-Unstable] Bug reports:
          recalbox.conf
          azvarel 1 Reply Last reply Reply Quote 0
          • azvarel
            azvarel @azvarel last edited by
            HDMI, all other emulators work flawlessly.
            • azvarel
              @Substring
              no updates =(
                @azvarel you make an error : gitlab not gitlat
                • azvarel
                  azvarel @acris last edited by
                  @acris thanks
                  • azvarel
                    @Substring I find this reicast-audio-oss maybe this is related. I saw that people with retropie had similar problems with mine.
                    • kelv
                      kelv last edited by
                      I'm scraping from mamedb using recalbox 4.1 the mame folder using last version on a RPi3 and normally I'm getting an error message saying "Error saving resized image. Out of Memory. Disk Full?" .The thing is that the disk is not full and there is enough memory. However my question is: if I set up let user decide in conflict = false, why Am I prompted with a message? Is that expected? THX
                      Raspberry Pi model: RPi 3b+
                      Recalbox build : 7.0.1 DragonBlaze
                      Hardware: MicroSD UHS 128 GB up to 80 MB, Class 10 and 2.5 A Power Supply.
                      Overclocked: 1485 MHZ
                      Controller(s): Wired Xbox 360 PAD (working perfectly on any other game/emulator).
                        @azvarel it's not supposed to use oss but ALSA
                        • azvarel
                          @Substring I do not even know what else to do.
                          Awesome reicast not having audio, on my rpi3
                            @azvarel Start reicast, leave, then make a support archive through the web manager and give me the link please
                            • azvarel
                              @Substring
                              https://file.ac/hzXk23BJJMM/
                                @azvarel i don't get the output ... can you, by ssh :
                                • /etc/init.d/S31emulationstation stop
                                • python /usr/lib/python2.7/site-packages/configgen/emulatorlauncher.pyc -p1index 0 -p1guid 030000005e040000a102000000010000 -p1name "Xbox 360 Wireless Receiver" -p1nbaxes 4 -p1devicepath /dev/input/event0 -system dreamcast -rom /recalbox/share/roms/dreamcast/Daytona\ USA\ -\ DCRES.cdi -emulator default -core default -ratio auto
                                And make a pastebin of the output (reicast is quite talkative :/)
                                • jackalpret
                                  jackalpret Translator last edited by
                                  I'm having troubles with audio output in pc 64bits version of recalbox 4.1 unstable.
                                  In desktop computer I tried with mini jack output and hdmi ... but the "menu options" shows volumen in 0% and I tried to change output but noone works ...
                                  If I open console (ALT F4 and ctrl alt F2 or F3) I saw:
                                  lvl0: VolumeControl::init() - Failed to find mixer elements!
                                  That the only message that I can read about sound ...
                                  • azvarel
                                    @Substring
                                    After I put the command appeared this information and it has been 15min and so far it has not given any more.
                                    ['/usr/bin/reicast.elf', '/recalbox/share/roms/dreamcast/Daytona USA - DCRES.cdi']
                                    Powering on HDMI with explicit settings (DMT mode 9)
                                    • azvarel
                                      @Substring
                                      https://pastebin.com/aBVzWT08
                                        Substring @jackalpret last edited by
                                        @jackalpret the next unstable should allow to select the audio output
                                        jackalpret 1 Reply Last reply Reply Quote 0
                                          @azvarel it's definitely using ALSA. Except a volume set to 0% (check with alsamixer), i have no idea why this is happening
                                          • azvarel
                                            @Substring
                                            alt text
                                            100.8k
