    [4.1-Unstable] Bug reports
    4.1 bugs
    46
    349
    397387
      Substring @jsianes last edited by
      @jsianes that's a retroarch bug, would probably require a b*mp of retroarch. No idea if this will happen in 4.1
      • Raphael Bueno Hatencia
        Raphael Bueno Hatencia last edited by
        I managed to get wifi working again. No recalbox problem, it was my SSID hidden. Recalbox can't connect to hidden wifi? That would be nice.
        • Edvis
          Edvis last edited by
          Hello, when using the hotkey, the bottom of the screen shows no letters, but squares, how to fix it? So it became after the system update v.4.1
          jsianes Substring azvarel 3 Replies Last reply Reply Quote 0
          • jsianes
            jsianes @Edvis last edited by
            @Эдвис-Фатходинов make sure you are using the latest unstable version. That happened to me first time I moved from 4.0 stable to unstable. Right after the first update, it came another a couple of days after that fixed that issue.
            Edvis 2 Replies Last reply Reply Quote 0
            • Edvis
              Edvis @jsianes last edited by Edvis
              @jsianes RB emulationstation v 4.1.0-DEV
              this is last version
              rpi3-2017-03-23-12-59-40-12832536
              • Edvis
                @jsianes the Russian language in setting menu appeared in the latest version?
                  Substring @Edvis last edited by
                  @Эдвис-Фатходинов there hasn,'t been any updates on ES languages yet
                    @Эдвис-Фатходинов are you using custom config files for retroarch ?
                    Edvis 1 Reply Last reply Reply Quote 0
                    • Edvis
                      Edvis @Substring last edited by
                      @Substring did not understand you.
                      retroarch Did not change anything. Everything was fine on v 4.0.0
                      , Then I updated it to 4.0.2 and immediately to 4.1
                        It´s normal to have all folders ROMs with disk size bigger than the actual size? See example pic.0_1490738526490_65cca829-dbc8-4fb6-ae17-4403559b86ae.jpg
                          @Эдвис-Фатходинов there was an update of retroarch on 4.1, hence the problem. We solved it by manually forcing the video font path in the retroarch config file.
                            Substring @Raphael Bueno Hatencia last edited by
                            @Raphael-Bueno-Hatencia This is not the place to discuss about what space files are, and what space they really take (see what a FAT cluster is, or what an inode is)
                            • azvarel
                              azvarel last edited by azvarel
                              @Substring
                              I do not know if this was mentioned before, because I was not following version 4.1, but I had to update to perform some tests with the rpi3 bluetooth, come on.
                              1. controller snes30 8bitdo firmware 2.70
                              I can pair but if it hangs up for lack of use or if you turn off rpi3 the pairing is lost
                              2. wiimote without wiimotion (first model)
                              It is paired, however when setting the UP, LEFT buttons with you, but when I set the RIGHT, DOWN buttons, it changes the LEFT mapping.
                              3. Dualshock 3
                              It is paired, however the LEDs keep blinking forever, it does not position which controller it is (I do not know if there has to be an xbox360 controller), even if it is disabled in the settings it persists.
                              4. PSP and DC games
                              I remember someone put some spreadsheets to report which games are 100% working, which ones need overclocking, which ones do not work.
                              @paradadf can you help me?
                              5. Overclocking
                              When testing the game Outrun Coast 2 Coast of the PSP, I saw that it gives a lot of choking and the gameplay is very much to be desired, when leaving the game it gave black screen, it stopped the recalbox, I made the overclock in the extreme way and simply the recalbox broken, did not initialize more.
                              Zodian Theme | #SNESProject
                              paradadf Substring azvarel 3 Replies Last reply Reply Quote 0
                              • azvarel
                                azvarel @Edvis last edited by
                                @Эдвис-Фатходинов said in [4.1-Unstable] Bug reports:
                                This happened to me and I did the direct installation by downloading the files from https://archive.recalbox.com/updates/v1.0/unstable/ and I am using the English language.
                                  paradadf Staff @azvarel last edited by
                                  @azvarel the compatibility lists are on the "IMPORTANT - README FIRST" section.
                                    Substring @azvarel last edited by
                                    @azvarel said in [4.1-Unstable] Bug reports:
                                    @Substring
                                    That's rather surprising. But I don't believe it. You should turn the pad on AFTER recalbox starts loading ES, not before (yeah, that's a change since 4.0)
                                    Ain't the wiimote already configured ? If you're familiar with es config files, what if you manually edit the file to set the right values ?
                                    3. Dualshock 3
                                    I don't have such behaviour. A few people reported it. I just own some shanwans, no genuine, and the led does work.
                                    4. PSP and DC games
                                    5. Overclocking
                                    That's why there is a warning about overclocking. Extrem voids your warranty. You should know that the PSP emulation is a succession of ups & downs : some games do very nicely work, some can be tweaked, some are just unplayable (give a try to ultimate ghouls'n'ghosts or tekken 6 ...)
                                    azvarel 1 Reply Last reply Reply Quote 0
                                    • azvarel
                                      azvarel @Substring last edited by
                                      @Substring said in [4.1-Unstable] Bug reports:
                                      I'm going to film the process that I do to pair the 8bitdo controller and turn off the recalbox and when it pairs again it gets lost, I take advantage and I also do the dualshock 3 for you to see.
                                      @paradadf
                                      I will give an updated there in the psp spreadsheet has many games that "fart" in rpi3
                                        @azvarel Yesterday i talked with someone on IRC whose BT data was not saved, which is very surprising as no one reported that after more than a month of unstable. Can you check if you have an archive in ~/bluetooth/ ?
                                        regarding PPSSPP : there are SO MANY possible tweaks inside the emulator that you should really experiment with them and report best settings.
                                        for example : multithread is not activated by default, whereas it gives a major speed boost (but the team says it's still experimental and can lead to bugs)
                                        • azvarel
                                          @Substring has a bluetooth.tar file
                                            @azvarel Should know what's inside to be sure 😉
                                            100.8k
