    [4.1-Unstable] Bug reports
    4.1 bugs
    46
    349
    397365
      Substring @sevenx last edited by
      @sevenx i'm trying to fix that for now by extending / to 2GB. I'm not sure it's gonna work the way i want it to
      sevenx 1 Reply Last reply Reply Quote 0
      • sevenx
        sevenx @Substring last edited by
        @Substring got you the command for this right now, or must i search through the internet ;)?
          @sevenx no you can't do that, the current .img are a dead-end
          • treacle
            treacle last edited by
            Not a bug, but a question regarding PlayStation DS4 support: Is the touchpad area supported? As mouse? That would be cool 🙂
              Substring @treacle last edited by
              @treacle no idea, i don't own one
              • sdlvivian
                sdlvivian last edited by
                After following the dosbox readme I get the dosbox logo when I run a game but then it exits back to the menu.
                sdlvivian 1 Reply Last reply Reply Quote 0
                • sdlvivian
                  sdlvivian @sdlvivian last edited by
                  Sorry if this is the wrong place to post this. Not sure if it's a bug or not since it seems other forum members have it working
                  • sevenx
                    @Substring do you think, with the next .img, it will be possible to update in future?
                      @sevenx that's what we're aiming at, of course.
                      • grgohr
                        grgohr @Substring last edited by
                        @Substring @peterpan123123 isn't it an issue with SDL_GameControllerDB instead ?
                        I can't seem to find a proper gamecontrollerdb.txt config for the Xinmo => leftstick, leftx, lefty don't work either
                        https://github.com/gabomdq/SDL_GameControllerDB/blob/master/gamecontrollerdb.txt
                        and it seems PPSSPPSDL can only work with that gamecontrollerdb file, not possible to override with classic controls.ini anymore
                        • Campana
                          Campana last edited by
                          The web console is in French. I selected the American flag on the left and rebooted several times but the web console is still in French. Anyone know how to fix this?
                          Gorion 1 Reply Last reply Reply Quote 0
                            Substring @grgohr last edited by
                            @grgohr you should be able to override it using the internal configurator and disabling recalboxconfiggen + deleting gamecontrollerdb.txt
                            Anyway, i have to partially revert the ppsspp configgen to how it was about 8 months ago, and manage several cases :
                            • dpad throws axis events
                            • hotkey is on select or any other key already assigned in the emulator(this one is really really evil)
                            as ppsspp doesn't handle keys combo, i'm afraid some people will have to stop it with a GPIO button
                            grgohr 1 Reply Last reply Reply Quote 0
                            • Gorion
                              Gorion @Campana last edited by
                              @Campana The developer of the web manager already knows about this issue and the solution. He simply forgot to implement the translation files for the other languages.
                              https://github.com/DjLeChuck/recalbox-manager/issues/3
                              He is going to fix this in the next release.
                              Campana 1 Reply Last reply Reply Quote 0
                              • Campana
                                Campana @Gorion last edited by
                                @Gorion Thank you!
                                • grgohr
                                  @Substring this is what I thought and tried, but then no controller, it seems PPSSPPSDL 1.3 relies only on gamecontrollerdb, and does not work like 1.2.2 before
                                  any possibility to download an archive (like before) of recalbox to get the previous bin ?
                                    @grgohr nope you can't. I'll find a solution, one way or another
                                    • rsn8887
                                      rsn8887 last edited by rsn8887
                                      My updates are set to "unstable".
                                      • Recalbox tells me there is an update.
                                      • I go to update in the menu
                                      • "working" for 30 minutes
                                      • tells me it needs to reboot
                                      • after reboot, tells me there is an update
                                      • controllers don't work I cannot click OK
                                      • keyboard doesn't work
                                      • recalbox host not accessible on network (network connection not working)
                                      • taking out sd card, and using Applie-Pie, burn latest img.
                                      • it works again
                                      This happened to me twice. First it happened two weeks ago, and now again just yesterday.
                                      Extremely annoying.
                                      Oh and I have a USB stick connected that has all my roms on it, so re-burning the .img is not SUCH a big deal luckily. This is a raspberry Pi 3.
                                      I get the img from https://archive.recalbox.com/updates/v1.0/unstable/
                                      • rsn8887
                                        Hmm after re-burning the latest .img it seems to work now, and I did get the changelog display about the newest manager, as I should, and I could select OK and the controller (PS3 Dualshock) is now working.
                                        Maybe the problem was that I was not using the very latest unstable build.
                                          Substring @rsn8887 last edited by
                                          @rsn8887 it rather looks like you rolled back from 4.1 unstable to 4.0.2 stable
                                          • rsn8887
                                            I am now on latest 4.1.0 downloaded .img. And I am getting the "wi-fi password turns into gibberish after re-boot" bug. The wifi password automatically gets corrupted everytime I reboot.
                                            In recalbox.config, it becomes "enc:somegibberish" The funny thing is, I just rebooted and even though the pw is gibberish, my recalbox did connect succesfully to wi-fi!
                                            100.8k
