    [4.1-Unstable] Bug reports
    4.1 bugs
    46
    349
    397427
    • RustyMG
      RustyMG @Substring last edited by
      @Substring Hi, been away from the internet for a bit.
      I had figured that out to be honest. Well, I just added in support for .dsk to see if that fixed it and that was good enough for the files I had, but thanks anyway!
      Regarding the latest unstable update, I followed the link and Ive had a look at what I THINK is the changelog, but the top entry doesnt have a date - it just has "## [Unrelease][unreleased]", and it also mentions :
      Added support for vice 2.4.24. This means support for commodore c64 and other commodore systems
      • Added theme for commodore c64
      • Added two demo ROMs for commodore c64"
      But, Ive just updated to it and I see no c64 folder in the roms folder.
      The next update date after "## [Unrelease][unreleased]" is "[4.0.0-beta5] - 2016-08-13", so can anyone confirm where / what IS the update log for the April 27th unstable update, and if c64 support is back?
      Many thanks.
      Sinclair ZX Spectrum 48k "dead flesh" keyboard, Commodore 64, Amiga A500, Amiga A1200, CD32, PC Engine, PS1, PS2, PSP, Nintendo DS, Dreamcast, Wii, XBox 360, Xbox One-X, Pi2, Pi3, Pi4 owner, ARRM contributor ( http://jujuvincebros.fr/wiki/arrm/doku.php ).
      azvarel 1 Reply Last reply Reply Quote 0
      • azvarel
        azvarel @RustyMG last edited by
        @RustyMG C64 is not yet in this unstable version (27/04), the other day I was talking to IRC with @Substring about it and it is still on top of development, if I am not mistaken it is their highest priority.
        Zodian Theme | #SNESProject
        • Piti
          Piti last edited by
          I use a fresh install with 4.1.0-master-rpi3-2017-04-11 but psx doesn't work.
          When i put the games (.bin) in the psx directory there is nothing in es.
          When i make self a gamelist.xml there is showing nothing in es.
          How can i get work psx that is showing my games?
          Tested and works:
          NES
          SNES
          N64
          Mega Drive
          PSP
            Substring @Piti last edited by
            @Piti this looks like a support problem, not a 4.1 bug.
            • Piti
              Piti last edited by Piti
              I come from gamestarter plugin but do a fresh install of all.
              On gamestarter there no problems with my games.
              On my Pi 2 with recalbox 4.0.2 all psx works fine 😞
              edit:
              OK now its work.
              I have to make my bin to pbp with PSX2PSP and now the games listen and i can play.
                @Piti you need a cue file with bin !
                Piti 1 Reply Last reply Reply Quote 0
                • Piti
                  Piti @Substring last edited by
                  @Substring
                  Ahh ok, that is the case, i have only the bin in the directory.
                  But now i convert the games to pbp and i safe a little space.
                  • Pepe
                    Pepe last edited by
                    In 4.1.0-master-rpi3-2017-04-27-11-56-31-15156468 seems that the parameter o2em.configfile=/absolutepathtofile/my_o2emconfig.cfg does not work and retroarch don't load my own retroarch custom config for maganvox odyssey, retroarchcustom.cfg loads instead.
                    • kelv
                      kelv last edited by
                      Hello
                      I don't know if it's only me however since last update 4.1 from end of April PPSSPP seems to crash more often.
                      I'm running a RPi3 OC to 1342.
                      Does anybody notice something strange? BTW, Where can I collect logs for PPSSPP
                      THX
                      Raspberry Pi model: RPi 3b+
                      Recalbox build : 7.0.1 DragonBlaze
                      Hardware: MicroSD UHS 128 GB up to 80 MB, Class 10 and 2.5 A Power Supply.
                      Overclocked: 1485 MHZ
                      Controller(s): Wired Xbox 360 PAD (working perfectly on any other game/emulator).
                        Substring @Pepe last edited by
                        @Pepe Can you try using odyssey2 instead of o2em ?
                        Pepe 1 Reply Last reply Reply Quote 0
                          Substring @kelv last edited by
                          @kelv try not to overclock, the last b*mp for PPSSPP happened 3 months ago, so i doubt this has anything to do with the emualtor
                          • Pepe
                            Pepe @Substring last edited by
                            @Substring it works, thanks.
                              @Pepe well still, that's not the way it should work ...
                              • Raphael Bueno Hatencia
                                Raphael Bueno Hatencia last edited by Raphael Bueno Hatencia
                                Hi, i have this adapter with 2 original ps2 controllers: 0_1496456955702_adaptor-product.jpg
                                It works fine, all buttons in all emulators, including moonlight playing with another 2 ps3 controllers. Using 4.1 recalbox.
                                But I have a problem playing PS1 games, when using this adapter, no command input is detected, many games won´t even pass by the start screen. (I´ve tried games like Marvel vs Capcom, B****y Roar I -II)
                                I can even use hotkey + B to enter retroarch menu and everything is working fine.
                                Can someone help me please? Sorry if this is not the correct place to post this question.
                                  Substring @Raphael Bueno Hatencia last edited by
                                  @Raphael-Bueno-Hatencia this is not the right topic to report. Please create a seperate topic for your problem
                                  • toniosj
                                    toniosj Spanish moderator last edited by
                                    Each time I reboot, my PS3 controllers desync and I must to sync again after reboot. Anyone with same problem?
                                    Substring 1 Reply Last reply Reply Quote -1
                                      Substring @toniosj last edited by
                                      @toniosj try resetting your controllers. And as I have asked on IRC : genuine PS3 or shanwan or gasia ? or maybe something else ?
                                      toniosj 1 Reply Last reply Reply Quote 0
                                      • toniosj
                                        toniosj Spanish moderator @Substring last edited by
                                        @Substring PS3 official and PS3 shanwan. both of them desyncronize. I going try reset controllers
                                        • Dragu
                                          Dragu Banned last edited by
                                          In 4.1.0-master-rpi3-2017-04-27-11-56-31-15156468 I have a problem with DAC card, Hifiberry-dacplus.
                                          In the version from march everything was working fine. The card was working after selection in the sound menu. I was just going into dosbox, load a game, and sound always there. After exit from dosbox, no sound at all anymore. In alsamixer the card is defined and found.
                                          • tavareslfelipe
                                            tavareslfelipe last edited by
                                            I'm late for this thread (https://forum.recalbox.com/topic/6517/4-1-unstable-need-testers-for-a-bluetooth-major-improvement/34), but bring a feedback.
                                            I tested a 8bitdo SFC30 (Firmware version 4.0.) with Rpi 3 internal bluetooth and everything worked fine, except for one thing: the hotkey combination to save/load games doesn't works. I tried it using a wired Xbox One controller and i was able to save and load using the specifics hotkeys shortcuts.
                                            What can be happening?
                                            100.8k
