    [4.1-Unstable] Bug reports
    4.1 bugs
    46
    349
    397411
      Substring @azvarel last edited by
      @azvarel no idea then 😕
      azvarel 1 Reply Last reply Reply Quote 0
      • azvarel
        azvarel @Substring last edited by
        Is this problem on my television?
        I went to see if she had compatibility with DMT
        tvservice -m DMT
        Group DMT has 19 modes:
                   mode 4: 640x480 @ 60Hz 4:3, clock:25MHz progressive
                   mode 5: 640x480 @ 72Hz 4:3, clock:31MHz progressive
                   mode 6: 640x480 @ 75Hz 4:3, clock:31MHz progressive
                   mode 9: 800x600 @ 60Hz 4:3, clock:40MHz progressive
                   mode 10: 800x600 @ 72Hz 4:3, clock:50MHz progressive
                   mode 11: 800x600 @ 75Hz 4:3, clock:49MHz progressive
                   mode 16: 1024x768 @ 60Hz 4:3, clock:65MHz progressive
                   mode 17: 1024x768 @ 70Hz 4:3, clock:75MHz progressive
                   mode 18: 1024x768 @ 75Hz 4:3, clock:78MHz progressive
                   mode 21: 1152x864 @ 75Hz 4:3, clock:108MHz progressive
                   mode 28: 1280x800 @ 60Hz 16:10, clock:83MHz progressive
                   mode 32: 1280x960 @ 60Hz 4:3, clock:108MHz progressive
                   mode 35: 1280x1024 @ 60Hz 5:4, clock:108MHz progressive
                   mode 36: 1280x1024 @ 75Hz 5:4, clock:135MHz progressive
                   mode 39: 1360x768 @ 60Hz 16:9, clock:85MHz progressive
                   mode 47: 1440x900 @ 60Hz 16:10, clock:106MHz progressive
                   mode 48: 1440x900 @ 75Hz 16:10, clock:136MHz progressive
                   mode 51: 1600x1200 @ 60Hz 4:3, clock:162MHz progressive
                   mode 58: 1680x1050 @ 60Hz 16:10, clock:146MHz progressive
        in recalbox.conf is:
        ## Dreamcast emulator
        ## Like N64, such a CPU intensive emulator needs a small resolution
        ## Consider DMT 4 HDMI or DMT 9 HDMI. Mode 9 is selected for a better screen compatibility
        dreamcast.videomode=DMT 9 HDMI
        replaces in dreamcast.videomode=DMT 9 HDMI with dreamcast.videomode=default
        reicast opens in CEA, in 4: 3 and with sound, however with many freezes in the games and choking in the sound
        The gameplay was disgusting 😞
        This is Satan's thing, disrupting my gambling.
        Did I have any idea, @Substring ?
        Zodian Theme | #SNESProject
          @azvarel setting to default makes you run reicast at 720p, which will be of course a pain for the pi cpu and gpu. That's why we force a lower resolution. You could eventually try DMT 4
          anyway, don't expect too much from reicast on a pi3, there are only very few games that will give a good gaming experience. Not only the emulation is hard, but the overall compatibility is not so good.
          • azvarel
            I put it on DMT 4 and also the sound did not work, so I put it on DMT 10 and to my surprise it worked perfectly the gameplay of Ikaruga and Marvel vs Capcom 2 is fine
            The odd thing is it's running at 72Mhz well instead of 60Mhz, though this my samsung tv is old for over 10 years, I believe this is it.
            Thank you for your patience and dedication, @Substring.
            • jackalpret
              jackalpret Translator @Substring last edited by
              @Substring said in [4.1-Unstable] Bug reports:
              @jackalpret the next unstable should allow to select the audio output
              thats a very good notice ! thanks and thanks !
                Substring @jackalpret last edited by
                @jackalpret though you may need to manually set the sound volume in Ă lsamixer`because i never ever could find a way to link an audio device with its mixer(s) (and on PC, that's even worse : a device can have several mixers, what a pain)
                jackalpret 1 Reply Last reply Reply Quote 0
                • jackalpret
                  but I tried to change in menu of ES ... but nothing happend.
                  Did You tellme that I need to enter via ssh and try to change output with alsamixer ? I can test it ...
                    @jackalpret yup : SSH > alsamixer (sadly ...). That would just show you which audio output is active, you definitely some changes inside recalbox to make this "saved" and survive after reboot (this, at least, will come the the audio output selection)
                    • azvarel
                      azvarel @azvarel last edited by
                      1. controller snes30 8bitdo firmware 2.70
                      I can pair but if it hangs up for lack of use or if you turn off rpi3 the pairing is lost
                      After this last unstable update, the controller was finally paired even after shutting down the rpi3
                      Solved!
                      • azvarel
                        @Substring
                        When it is inside the reicast and the control turns off (be it bluetooth or xbox 360) you can not continue the game anymore, having to restart the recalbox.
                          @azvarel just kill the process with SSH, don't unplug the power cord ...
                          • azvarel
                            @Substring I do not pull the power cord, I have a reset button in my #SNESProject
                            • azvarel
                              My brother's wifi key starts with 0 (zero) the recalbox for some reason, removes this initial 0 and leaves the correct remaining sequence.
                              I had to change the wifi key on the router so that the recalbox could connect
                              • Chris Johnson
                                Chris Johnson last edited by Chris Johnson
                                My bugs ive ran into using latest unstable version, off a RPi3
                                Dreamcast Emulator:
                                ‱ Couple of games crashed on me during setting up the current date and time for controller
                                ‱ Lags, frameskips
                                PPSSPP Emulator:
                                ‱ VERY SLOW!!! Havent been able to play any roms because of how slow it is.
                                ‱ Even changed the settings to max performance and barely reached 16 frames.
                                Moonlight
                                ‱ Paired, scraped the roms, worked the first time. shutdown console, hasnt worked since. tried to pair again after removing device from nvidia and doesnt work. checked moonlight.conf everything looks right. so its a bug im assuming.
                                • Chris Johnson
                                  Chris Johnson @jthemad last edited by Chris Johnson
                                  @jthemad hey man i know how to fix it , i've had the same issue forever!!! this is what you do.
                                  Retroarch Squares fix:
                                  ‱ Go to your retroarchcustom.cfg
                                  /share/system/configs/retroarch/retroarchcustom.cfg
                                  ‱ Open, and add this line anywhere
                                  video_font_path = "~/.config/retroarch/assets/xmb/monochrome/font.ttf"
                                  ‱ Save, Close, restart.
                                  ‱ Success. no more squares for you 🙂
                                  if you also have black boxs for icons let me know and i can help fix that too.
                                  • Raphael Bueno Hatencia
                                    Raphael Bueno Hatencia last edited by Raphael Bueno Hatencia
                                    STOP ES and restart buttons on the manager 2.0 isnÂŽt working for me.
                                    But if I stop with F4 on keyboard, the Start ES button on manager works.
                                    • RustyMG
                                      RustyMG last edited by
                                      Hi, I've tried about 50 psp games and about 20 play perfectly. Not a great hit rate, but sounds like 20 more than you have - setup issue??
                                      Sinclair ZX Spectrum 48k "dead flesh" keyboard, Commodore 64, Amiga A500, Amiga A1200, CD32, PC Engine, PS1, PS2, PSP, Nintendo DS, Dreamcast, Wii, XBox 360, Xbox One-X, Pi2, Pi3, Pi4 owner, ARRM contributor ( http://jujuvincebros.fr/wiki/arrm/doku.php ).
                                      • lackyluuk
                                        @RustyMG would you mind to add the tested games into the compatibility list? 🙂 That would be great
                                        https://docs.google.com/spreadsheets/d/13M7aAfua3zdlWZ3-i70kkb5_EGhCbwgFidPZFH33qkM/htmlview
                                          Substring @RustyMG last edited by
                                          @RustyMG We are not the authors of the PSP emulator, so most of times, we can't do anything other than point you to guides helping to optimize PPSSPP. In some cases, turning multithread on does help for emulation. But remember you're running a pi3, it can't do miracles regarding emulation.
                                            New unstable available 🙂
                                            jackalpret lackyluuk 2 Replies Last reply Reply Quote 1
                                            100.8k
