    [4.1-Unstable] Bug reports
    4.1 bugs
    46
    349
    397422
    • jackalpret
      jackalpret Translator @Substring last edited by
      @Substring said in [4.1-Unstable] Bug reports:
      New unstable available 🙂
      THANKS ! yupi !
      changelog ?
        https://archive.recalbox.com/updates/v1.0/unstable/rpi3/recalbox.changelog
        jackalpret 1 Reply Last reply Reply Quote 1
          Substring @jackalpret last edited by
          @jackalpret once you update, the changelog is dynamic since 4.1 😉
          • jackalpret
            jackalpret Translator @acris last edited by
            @acris thanks ! i saw it 10 seconds ago haha.
            is this the correct link to download ?
            there are updates to PC version ? or only to rpi3 ?
              Substring @jackalpret last edited by Substring
              @jackalpret most of them are fixes, i guess the main one being the configuration of PSP. We're aiming for a stable release, so don't expect new features until we start working on 4.2
              You just update through usual ways
              jackalpret 1 Reply Last reply Reply Quote 0
              • jackalpret
                @Substring i'm using 4.1 pc version and it works very well (previous unstable version) 😉
                • lackyluuk
                  lackyluuk Translator @Substring last edited by
                  Thanks for your hard work 🙂 thumbs up!!
                  • Dwarf
                    Dwarf last edited by
                    PPSSPP emulator works now, but no sound in EmulationStation, only sounds the initial video, after that no sound in any game...
                    RPi3 Recalbox 7.0.1 (Stable)
                      Go to emulationstation > sound options > hdmi or other.
                        Substring @Dwarf last edited by
                        @Dwarf You'd need to explain more : is your sound output set to auto ? hdmi ? or a USB key ? Where do you expect sound to come from ?
                        Dwarf 1 Reply Last reply Reply Quote 0
                        • eclipse16g
                          eclipse16g last edited by
                          @substring Since this latest update, I also lose sound after the intro video. I must toggle sound output between Auto and Jack or vice versa to bring it back. I have to do this on every bootup. Also the volume bar also changes, ie. might be 95 , then 97 on next boot.
                            Substring @eclipse16g last edited by
                            @eclipse16g the volume indicator has always been moving on its own ...
                            regarding the sound, what is your usual audio output ?
                            • eclipse16g
                              @substring I use the audio jack output, and I didn't notice the volume indicator moving before this last update, but I had no reason to go into the sound menu before either. This only happens with full shutdown or reboot. If I stop and start emulation station, the sound still works fine.
                                @eclipse16g mind making me a support archive with http://recalbox/help ? (add .local to recalbox if you're on linux/mac)
                                eclipse16g 1 Reply Last reply Reply Quote 0
                                  @RustyMG for the AppleII problems ... well, on the big job that rewriting the generation of the es_system.cfg, there were a few mistakes 😄 See by yourself :
                                    <system>
                                      <fullname>Apple II</fullname>
                                      <name>apple2</name>
                                      <path>/recalbox/share/roms/apple2</path>
                                      <extension>.iso .ISO .gc .GC .gcz .GCZ</extension>
                                      <command>python /usr/lib/python2.7/site-packages/configgen/emulatorlauncher.pyc %CONTROLLERSCONFIG% -system %SYSTEM% -rom %ROM% -emulator %EMULATOR% -core %CORE% -ratio %RATIO%</command>
                                      <platform>apple2</platform>
                                      <theme>apple2</theme>
                                      <emulators/>
                                    </system>
                                    <system>
                                  Extensions should be .nib .NIB .do .DO .po .PO .dsk .DSK
                                  RustyMG 1 Reply Last reply Reply Quote 0
                                  • Dwarf
                                    Dwarf @Substring last edited by
                                    @Substring sorry, i'm on vacations and can't confirm right now, i think audio is set to auto, and the speakers are plugged via jack to the raspberry pi 3. Sound works great til the update. I will return home next week and run more tests.
                                      @Dwarf I should be able to diagnose with just your ~/logs/recalbox.log
                                      • eclipse16g
                                        eclipse16g @Substring last edited by eclipse16g
                                        @Substring here's my support archive https://file.ac/j9h8zEDrqdY/
                                        • Dwarf
                                          @Substring I'm back!
                                          If I change sound options fron auto to jack, sound start working again, but on next reboot sound is lost again...
                                          Here is my recalbox.log:
                                          https://pastebin.com/qub1AABC
                                          Thanx for the help!
                                            @Dwarf well, i git quite f***** up this weekend at HFS3 on my pi using jack audio. So i can sadly reproduce the bug. Will try to sort it out asap
                                            100.8k
