    [4.1-Unstable] Bug reports
    4.1 bugs
    46
    349
    397344
    • starmagoo
      starmagoo @peterpan123123 last edited by
      @peterpan123123 ok perfect!
      • DjLeChuck
        DjLeChuck @Raphael Bueno Hatencia last edited by
        @Raphael-Bueno-Hatencia @starmagoo The i18n component use your browser local storage or cookies to save the selected language between sessions.
        Could you see if one of these are used?
        Raphael Bueno Hatencia 1 Reply Last reply Reply Quote 0
        • Raphael Bueno Hatencia
          Raphael Bueno Hatencia @DjLeChuck last edited by
          @DjLeChuck How can i get this info?
          DjLeChuck 1 Reply Last reply Reply Quote 0
          • DjLeChuck
            @Raphael-Bueno-Hatencia It depends of your browser. You use Chrome, Firefox, other?
              @DjLeChuck chrome
              • DjLeChuck
                @Raphael-Bueno-Hatencia Press F12 then a new panel should appear.
                Go to Application tab then you can see Local Storage, Session Storage and Cookies.
                You must be on the manager to see the manager local storage / cookies
                  @DjLeChuck Thanks! Got it.
                  Local Storage: i18nextLng > pt-BR
                  Session: nothing
                  Cookies: nothing
                  • DjLeChuck
                    @Raphael-Bueno-Hatencia Strange, pt-BR is here... So the interface is in french but you see pt-BR in local storage?
                      @DjLeChuck Yes, I click on the flag, choose Brasil, EUA....no matter what language the mannager stays French.
                      • DjLeChuck
                        @Raphael-Bueno-Hatencia Can you let the panel open but go in Network tab and see if there is any errors? Same with Console tab.
                        • badges3000
                          badges3000 last edited by
                          Have the same problem, Local Storage: i18nextLng - de, nothing in Session and Cookies. Cleaned the Storage, nothing happens. In Console I have the following errors:
                          DevTools failed to pa**e SourceMap: http://192.168.1.99/static/css/main.a049ccfe.css.map
                          DevTools failed to pa**e SourceMap: http://192.168.1.99/static/js/main.666b1be8.js.map
                          • DjLeChuck
                            DjLeChuck @badges3000 last edited by
                            @badges3000 What's going on with this? 😞 The two errors can be ignored and are not related (I mean, they should not be related...)
                            I will take a look tonight, trying to reproduce it.
                              Here is the screenshot.
                              I tried again running recalbox-support.sh on chrome from windows, from mac and even on safari and still got no link to send to @Substring. When i hit the button that recalbox-support showed up and got status pending (forever).
                              • DjLeChuck
                                OK, I have the same problem with locales and I know what's wrong. I will fix this.
                                For the support.sh script, @Raphael-Bueno-Hatencia please connect with SSH then:
                                • Type cd /usr/recalbox-manager2
                                • Type NODE_ENV=production PORT=3000 node dist/server.js
                                • Go to http://recalbox:3000/help
                                • Try to execute the script
                                • Look at your console if something went wrong
                                • When all is done, you can CTRL+C to kill the instance
                                  @DjLeChuck Nice! Im glad to help even a bit =D
                                  I did everything as you said, but when I tryed to go to the link: http://recalbox:3000/help
                                  My page says: This site can’t be reached.
                                  • DjLeChuck
                                    @Raphael-Bueno-Hatencia You are under Mac or Linux I guess, so it's http://recalbox.local:3000/help
                                    In fact, you must use the same URL as usual except you add :3000 before /help
                                      Raphael Bueno Hatencia @DjLeChuck last edited by Raphael Bueno Hatencia
                                      @DjLeChuck Now the link worked!
                                      The script is running now, but nothing showed up in the console.
                                      ok, now i've got many many lines with this:
                                      cp: write error: No Space left on Device
                                      • DjLeChuck
                                        @Raphael-Bueno-Hatencia So this is the answer, your card is full?
                                          @DjLeChuck nope, I have 52GB/56GB (92%).
                                          I see this strange files in the save folder, don't know if it is related somehow.
                                          • DjLeChuck
                                            DjLeChuck @Raphael Bueno Hatencia last edited by DjLeChuck
                                            @Raphael-Bueno-Hatencia Yes it is, this are the generated files! You can safely remove them.
                                            But 227MB, WTF??? The file is uploaded on an external service after being generated. I think that's the problem.
                                            @substring do you know WHY it's so big?
                                            100.8k
