    [4.1-Unstable] Bug reports
    4.1 bugs
    46
    349
    397337
      I'd need mappings of wired xbox360 controllers, wired xbox one controllers. For this purpose, the easiest for you is to go to http://recalbox/help then launch the script and paste here the generated link.
      Thank you very much 🙂
        @substring wired xbox360 controllers with xpad, are already up to date on repo.
        • styletwo-wan
          styletwo-wan @Substring last edited by
          Has the "bluetooth major improvement" been integrated into the build 11402041 ? Thank you.
            paradadf Staff @styletwo-wan last edited by
            @styletwo-wan I don't know, but just update to the latest build and you'll have it.
            peterpan123123 1 Reply Last reply Reply Quote 0
            • peterpan123123
              peterpan123123 @paradadf last edited by
              @paradadf btw. update is superslow right now...
                rockaddicted @peterpan123123 last edited by
                @peterpan123123 yep bandwith issue... you will have to retry later.
                • grgohr
                  grgohr @Substring last edited by
                  @Substring here it is:
                  sdl2-jstest -l
                  sh: setterm: command not found
                  Found 2 joystick(s)
                  Joystick Name: 'Xin-Mo Xin-Mo Dual Arcade'
                  Joystick Path: '/dev/input/event0'
                  Joystick GUID: 03000000c0160000e105000001010000
                  Joystick Number: 0
                  Number of Axes: 2
                  Number of Buttons: 10
                  Number of Hats: 0
                  Number of B***s: 0
                  GameController:
                  not a gamepad
                  Axis code 0: 0
                  Axis code 1: 1
                  Button code 0: 288
                  Button code 1: 289
                  Button code 2: 290
                  Button code 3: 291
                  Button code 4: 292
                  Button code 5: 293
                  Button code 6: 294
                  Button code 7: 295
                  Button code 8: 296
                  Button code 9: 297
                  Joystick Path: '/dev/input/event1'
                  Joystick Number: 1
                  Number of Axes: 2
                  Number of Buttons: 12
                  Number of Hats: 0
                  Number of B***s: 0
                  GameController:
                  not a gamepad
                  Axis code 0: 0
                  Axis code 1: 1
                  Button code 0: 288
                  Button code 1: 289
                  Button code 2: 290
                  Button code 3: 291
                  Button code 4: 292
                  Button code 5: 293
                  Button code 6: 294
                  Button code 7: 295
                  Button code 8: 296
                  Button code 9: 297
                  Button code 10: 298
                  Button code 11: 299
                  • grgohr
                    grgohr @grgohr last edited by grgohr
                    @Substring ok i've been able to get the last libretro core working (from lakka xu4) so i guess it should be added back (I am not sure I understand your defconfig pr thing : should I add a line like BR2_PACKAGE_LIBRETRO_SCUMMVM=y ?)
                    2 issues though:
                    _ scummvm does not launch games directly, seems to be a recent scummvm bug, related to dir scan might be fixed soon
                    • more critical : i cannot browse the /recalbox/xxx/ folders and add games (grayed out folders) : any idea ? i can put and browse a game folder anywhere else (with the remout -rw) but that is not the purpose. seems there is conflict with scummvm own access rights and recalbox access rights. and i can't find the relevant .ini files to force the path. any idea much appreciated (very few other posts on the same issue, grayed out folders in scummvm for sd card browsing)
                    • Raphael Bueno Hatencia
                      Raphael Bueno Hatencia last edited by Raphael Bueno Hatencia
                      wifi stopped working. Can recalbox connect to a wifi with ssid hidden?
                      I typed correctly the name and password, but it dosnt connect. Only via ethernet cable.
                      My Recalbox manager (http) is in french, how to change back to english?
                      I tried the brazilian and USA flag, but the language dosnt change. My system is in portuguese by the way.
                      Thanks
                        Substring @grgohr last edited by
                        @grgohr to add the package, yes that's basically the idea, though doing make menuconfig, add the core then make savedefconfig and send us a pull request is the best way to do it
                        Regarding that grayed folder stuff, no idea
                          Substring @Raphael Bueno Hatencia last edited by
                          @Raphael-Bueno-Hatencia some other people reported a problem with wifi not reconnecting.
                          I'd need you go to http://recalbox/help and maunch the supoort script then give me the generated link.
                          Known bug for the manager to not translate anymore, @DjLeChuck should solve that sooner or later
                          Raphael Bueno Hatencia 1 Reply Last reply Reply Quote 0
                            Raphael Bueno Hatencia @Substring last edited by
                            @Substring I tried to generate but it passed 1hour and no link yet. How much longer it takes to generate link?
                              @Raphael-Bueno-Hatencia a few seconds
                                @Substring aww sorry I don´t know how to do it. I try but it takes hours every time and nothing happens. The arrows icon keep doing circles forever, and no link is show to me.
                                  @Raphael-Bueno-Hatencia @DjLeChuck any idea abt that ?
                                  DjLeChuck 1 Reply Last reply Reply Quote 0
                                  • DjLeChuck
                                    DjLeChuck @Substring last edited by
                                    @Substring @Raphael-Bueno-Hatencia I must add a logging system to store all errors on the manager.
                                    Actually it was maybe a temporary downtime with the external service used to upload file. This means you can retry and maybe it will work.
                                    If it doesn't work so there is a problem in the code and I must see the encountered error...
                                    So you must start the manager yourself with SSH and tell me the console output when you launch the script. Can you do that if I tell you the commands?
                                    P.S. : @rockaddicted tu n'as pas oublié ma petite demande concernant l'upload des fichiers du script recalbox-support ? 🙂
                                      Raphael Bueno Hatencia @DjLeChuck last edited by
                                      @DjLeChuck I'll try again today to see if it works.
                                      Yes I can do that. I only used simple commands until now, but I will give my best =D
                                      • starmagoo
                                        starmagoo @rockaddicted last edited by
                                        @rockaddicted Thx, worked!
                                        • starmagoo
                                          starmagoo last edited by
                                          I have discovered a new problem, I can't change Webinterface language. It is only in French.
                                          • peterpan123123
                                            peterpan123123 @starmagoo last edited by
                                            @starmagoo https://forum.recalbox.com/topic/6453/4-1-unstable-bug-reports/129#
                                            starmagoo 1 Reply Last reply Reply Quote 1
                                            100.8k
