    [4.1-Unstable] Bug reports
    4.1 bugs
    46
    349
    397322
      Substring @kelv last edited by
      @kelv definitrly no problem at all. Is it a vanilla install or you added some plugins ?
      kelv 1 Reply Last reply Reply Quote 0
      • kelv
        kelv @Substring last edited by
        @Substring I have the pluggings that were isntalled before in the 15 release. I was wondering if the issue could be because of that, I will delete all of them and re-add them. THX!!!
        Raspberry Pi model: RPi 3b+
        Recalbox build : 7.0.1 DragonBlaze
        Hardware: MicroSD UHS 128 GB up to 80 MB, Class 10 and 2.5 A Power Supply.
        Overclocked: 1485 MHZ
        Controller(s): Wired Xbox 360 PAD (working perfectly on any other game/emulator).
        • Raphael Bueno Hatencia
          Raphael Bueno Hatencia last edited by
          Hi! I have a problem connecting through wifi on rpi3. I was using the unstable version, but after a restart it won't connect anymore.
          After checking the password, it shows some random numbers and letters before the correct password. Even when I re-type it correctly.
          What can I do to fix wifi? Via ethernet it still works, but can't use it all the time.
          Raphael Bueno Hatencia 1 Reply Last reply Reply Quote 0
            Raphael Bueno Hatencia @Raphael Bueno Hatencia last edited by
            @Raphael-Bueno-Hatencia Just got it working!
            I put the same wifi name and password on recalbox.conf on share and share_init, don't know why, but that did the job.
              The last unstable recalbox version embeds :
              • create missing rom folders
              • automatic umdate of the recalbox.conf
              • better bluetooth connectivity
              • new ES languages
              • update configgen for retroarch (yellow squares)
              • PSX core b*mp to enable the sony logo + disable rumbling
              treacle 1 Reply Last reply Reply Quote 0
              • treacle
                treacle @Substring last edited by
                @Substring Hi. Still having massive psx issues here. I'm running the latest update on a pi3. Psx is not playable. Was nice and smooth before, even with enhanced resolution.
                I notice that frame skip is set to 3 under quick menu/options changing that and deactivating enhanced resolution doesn't help much though - besides that wouldn't be a solution 🙂
                  Substring @treacle last edited by
                  @treacle what do you mean "unplayable" ?
                    @treacle games psx ? Exemple ? Rewind disabled ?
                    • treacle
                      treacle @Substring last edited by treacle
                      @Substring with unplayable I mean it's so slow. Emulation works though. Screen size is not filling my tv either. And the scanlines look odd too.
                      Rewind is disabled, and was before too
                        @treacle I'd say there's a problem on your side for sure ... @rockaddicted b*mped the core, he tested it, and reported no sluggishness
                        • treacle
                          @Substring ok... any idea what the problem could be? Didn't change any configs. Been on 4.1.0 unstable since 4.0.1
                            Yep I didn't notice significant slowdown during my tests. I only launched few games for testiing post b*mp and post patch about rumble.
                            @treacle do you have this issue with all your games ? Can you give us some examples ?
                            • treacle
                              treacle @rockaddicted last edited by
                              @rockaddicted I only tried two or three games. Crash bandicoot, castlevania. All running perfect before. Oh, and when I enter the (new xmb) retroarch menu, all icons are black squares
                                @treacle you can't have updated to the last unstable : squares and xmb (switched back t rgui) are solved. Unless you usensome custom configs ?
                                For the missing icins, just download retroarch assets
                                • treacle
                                  @Substring hmm, checked for updates about 2 hours ago, and it said there are none available
                                  • kelv
                                    kelv @kelv last edited by
                                    @Substring I wiped everything with Fresh Start plugging and it keeps crashing... Anyways I can live without Kodi. I have other sd card with kodi.
                                    THX
                                      @kelv A fresh start using an img from http://archive.recalbox.com/updates/v1.0/unstable/ ?
                                      kelv 1 Reply Last reply Reply Quote 1
                                      • kelv
                                        @Substring I'm falshing other sdcard now. Let's check 🙂 Thx for the link 🙂 The point is that I don't want to reconfigure and copy all roms from my main sd card.
                                          Substring @kelv last edited by Substring
                                          @kelv boooooo shaaaaaame ! I'll never stress it enough : USE USB KEYS ! (or HDD)
                                          anyway, that'd just be for a test with a pure vanilla 4.1
                                          kelv 2 Replies Last reply Reply Quote 0
                                          • kelv
                                            @Substring One question, do you think performance on a USB stick or solid state HD through usb is higher than a sdcard?
                                            supernature2k 1 Reply Last reply Reply Quote 0
                                            100.8k
