    [4.1-Unstable] Bug reports
    4.1 bugs
    46
    349
    397317
      Substring @jthemad last edited by
      @jthemad All apologies, what i said doesn't work in the case of an upgrade from 4.0
      So add to your retroarcCustom.cfg :
      menu_driver = rgui
      video_font_path = /recalbox/share_init/system/.emulationstation/themes/recalbox/data/ubuntu_condensed.ttf
      This will restore retroarch as before
      Regardnig your xbox pad : was this pad the 1st player ? The xbox 360/one driver changed in 4.1, you do need to reconfigure your pad. Was your pad the 1st player ? HK is not used on players others than the 1st
      jthemad Mercvtio 2 Replies Last reply Reply Quote 1
      • jthemad
        jthemad @Substring last edited by
        @Substring thanks again.. ok I'll try to add the lines later.. regarding the controller I tried to set player1 and it doesn't work, tried to set default same issues. Looking in cfg file I noticed that I have controllers.xboxdrv.enabled=0, could it be the problem? (I had the same setting in 4.0.2 and it worked)
          @jthemad no more xboxdrv on 4.1, as i already said
          jthemad starmagoo 2 Replies Last reply Reply Quote 0
          • jthemad
            @Substring you said it changed, not it is not used in 4.1. However I have the line i wrote in 4.1 recalbox.conf file.. controllers.xboxdrv.enabled=0
            Section D2
              @jthemad nevermind the line, it's not used anymore
              jthemad 1 Reply Last reply Reply Quote 0
              • jthemad
                @Substring ok I'll try reset the keys but I think there is a bug with this controller.. I'll let you know.. hi
                • Mercvtio
                  Mercvtio @Substring last edited by
                  @Substring I had the same issue with the square bug, and those lines did the job allright. Thank you !
                  It might be worth adding the info in the first post.
                    Substring @Mercvtio last edited by Substring
                    @Mercvtio there is a much faster way to solve it, but the fix is done, needs some testing
                    • peterpan123123
                      peterpan123123 @Substring last edited by
                      @Substring said in [4.1-Unstable] Bug reports:
                      can't update with a USB key from 4.0.1 to 4.1 : yeah, that's a major problem, we're investigating on that
                      Is this still a problem? Just updated from 4.0.2 to 4.1 with USB attached HDD (system on HDD). No problem so far, everything worked like it should. Even the MAXTRY entry works now without modification - great job!
                        rockaddicted @peterpan123123 last edited by
                        @peterpan123123 hi, what is your fs ? Fat32/NTFS/ext4 ?
                        peterpan123123 1 Reply Last reply Reply Quote 0
                        • peterpan123123
                          peterpan123123 @rockaddicted last edited by
                          @rockaddicted ext4
                            @peterpan123123 Ok this bug only affect devices formated on fat32
                            • toti83
                              toti83 last edited by paradadf
                              Hi there,
                              I have a bug with 2 dreamcast games : PowerStone2 et Shenmue. (DELETED BY MODERATION: DO NOT MAKE REFERENCE TO ANY SOURCE).
                              These 2 games only display a black screen.
                              I'm using these bios :
                              e10c53c2f8b90bab96ead2d368858623 dc_boot.bin
                              0a93f7940c455905bea6e392dfde92a4 dc_flash.bin
                              Anyone have the same issue ?
                              • starmagoo
                                starmagoo @Substring last edited by
                                What does this mean? No use of xbox controller att all?
                                  rockaddicted @starmagoo last edited by
                                  @starmagoo said in [4.1-Unstable] Bug reports:
                                  That mean we are using the kernel driver, xpad, no more the standalone driver xboxdrv.
                                  This driver is no more maintains since more 1 year, and is no more working on new linux kernels.
                                  starmagoo 1 Reply Last reply Reply Quote 1
                                    Substring @toti83 last edited by
                                    @toti83 the powerstone 2 i tried was running just great. Have you at least reached the time setting screen ?
                                    toti83 1 Reply Last reply Reply Quote 0
                                    • toti83
                                      toti83 @Substring last edited by
                                      @Substring thx for you reply, i found this mornig the issue. I have the right bios (checked by md5) but i have to rename it for make it works
                                      Dwarf 1 Reply Last reply Reply Quote 0
                                      • Dwarf
                                        Dwarf @toti83 last edited by
                                        @toti83 what's the correct name and the correct folder for the bios files? Thanxs!
                                        RPi3 Recalbox 7.0.1 (Stable)
                                          Substring @Dwarf last edited by
                                          @Dwarf read the very first post of this topic, i mentionned it. Bios files go to the bios folder
                                          • max216
                                            max216 last edited by max216
                                            serais ce possible d'avoir la liste des répertoires de roms vu qu'ils ne sont pas créé automatiquement ?
                                            J'en ai trouvé certains tout seul mais par exemple dos et advancemame j'en ai essayé des tas sans résultats.
                                            Pour l'emu dosbox, y'a t il une notice quelque part ? j'aimerais m'y lancer.
                                            J'ai un RPI3 non OC, SD 64go, manettes PS3 avec dongle (pas enlevé encore)
                                            Pour mes retours:
                                            • pour ma part idem, la navigation et la sortie d'un jeu est plus lent en 4.1 qu'en 4.0
                                            • Dreamcast testé ce matin, isos CDI ne pasent pas uniquement en GDI
                                              streetfighter Vs capcom 2 injouable car bug sur les personnages déformés (probleme de l'emulateur)
                                              daytona, au début j'ai eu peur une impression quelques secondes que ca rame dès l'intro et puis non au final c'est fluide, j'ai juste pas trouvé comment aller a droite et gauche, je verrais plus tard. ca fonctionne super avec la musique et les sons ca claque !
                                              san fransico rush 2029, pas ruéssi a lancer le jeu, j'arrive qu'au menu DC de la console, je vais tenter une autre version
                                              shenmue, quelques petits bugs d'affichage mais le reste niquel et super beau, j'ai testé qu'avec le 1er CD tout le départ
                                            la PSP,
                                            l'affichage rame plus ou moins selon les jeux, par contre le son toujours meme si c'est a peu pres normal pour le reste. j'ai testé GTA SA (jouable), un DBZ (très moyen), un starwars (ulta lent)
                                            Les jeux d'avant marchent tous comme avant pour ceux que j'ai testé.
                                            voila quand j'aurais les infos je testerais advmame car j'ai le bon set et les jeux DOS.
                                            voila 😉
                                            100.8k
