    Recalbox sur TV CRT en RGB
    recalbox crt rgb
    51
    782
    824575
    • archimage
      archimage last edited by
      Mets tes roms dans le dossier fba_libretro à la place de fba
        voljega Banned @n3o_c59 last edited by
        @n3o_c59 dans le dossier fba l'emulateur par défaut est fba dans le dossier fba_libretro l'emulateur par defaut est fba_libretro donc je sais pas trop ce que tu trifouilles... Par ailleurs 'fba' sans libretro n'utilise pas libretro contrairement à 'fba_libretro' et les deux ne sont bien évidemment pas le même emulateur et n'utilise pas le même romset. Sur cemerci de bien vouloir lire la doc arcade sur le wiki
        • aTg
          aTg last edited by aTg
          This post is deleted!
          • aTg
            I am in the final stage to launch a distro of recalbox for CRT all preconfigured with an pixelperfect philosophy, i will upload to github, compatible with all GPIO adapters but i am stopped with one issue and i need a little help.
            I make one config file for every machine with the correct aspect ratio and other configurations of retroarch for example snes.cfg but when you use a custom config file like this the buttons mapping from Emulationstation not work and need to remap, i am searching the way to load the button mapping of ES or Recabox but i think is neccesary make changes in configgen.
            Any help are much apreciated.
            • ian57
              @atg I did not had this controller issue with my test of the cfg core file in 4.1. For example the snes.cfg file only contain the video configuration :
              aspect_ratio_index = "22"
              custom_viewport_width = "1792"
              custom_viewport_height = "224"
              custom_viewport_x = "104"
              custom_viewport_y = "16"
              the others configuration options remains identical tho the retroarch default config no ?
              Perhaps you did this in the 4.0 release?
                Substring @aTg last edited by Substring
                @aTg Like explained on https://forum.recalbox.com/post/26027 your per system .cfg is appended to the main .cfg. In other words :
                • recalbox sets ~/configs/retroarch/retroarchcustom.cfg for controllers or anything else
                • then configgen will detect the ~/configs/retroarch/snes.cfg (in the case of snes) and APPEND whats inside, which means overwrite anything existing in the previous file. The snes.cfg is just intended to have what @ian57 suggested, nothing about pads
                aTg 1 Reply Last reply Reply Quote 0
                • aTg
                  aTg @Substring last edited by aTg
                  @Substring @Ian57 I build all the system over 4.0 and not works
                  Im going to make the changes in /libretroGenerator.py many thanks
                  • haricot
                    haricot last edited by
                    ok , ca fait un petit moment , j'ai enfin résolu mes soucis de résolutions , le bon adaptateur HDMI vers VGA suffisait....
                    pour info , je poste ici car je n'ai pas vu le lien dans le fil du forum.
                    pi2scart
                    je vais backer je pense 😄
                    stéphane.
                      Substring @haricot last edited by
                      @haricot le gros pb de ce projet c'est le son odieux du pi ... Après c'est vraiment un public TRES ciblé
                      ajefr 1 Reply Last reply Reply Quote 0
                      • aTg
                        I finish my MOD of Recalbox OS for CRT based on 4.0
                        RGB-Pi 4.0 Beta
                        Is compatible with all DPI conversors (changing dtoverlay= on config.txt)
                        Installation over CRT (PINN recompiled instead of NOOBS)
                        One resolution for every console with the correct aspect ratio to get PixelPerfect
                        Theme modified for lower resolutions
                        The list of custom resolution with PixelPerfect, the rest are in 320x240 60Hz
                         atari2600
                         atari7800
                         neogeo
                         mastersystem
                         pcengine
                         pcenginecd
                         turbografx
                         gamegear
                         gb
                         gbc
                         gba
                         nes
                         snes
                         megadrive
                         psx
                         n64
                        Please try it and give me your feedback
                        • ian57
                          ian57 Staff last edited by
                          @aTg Great job... congrats
                          • ajefr
                            ajefr @Substring last edited by
                            @Substring said in Recalbox sur TV CRT en RGB:
                            On sent l'informaticien qui parle 😉
                            Le montage donné au dessus te donnera sûrement un son d'encore moins bonne qualité que la sortie jack du pi (c'est encore moins filtré que dans le pi)
                            Pour le public "TRES" ciblé, ne pas confondre la version JAMMA et la version SCART/PERITEL ce sont deux projets différents.
                            Le scart se rapprochant exactement de ce qui est discuté ici
                              Substring @ajefr last edited by
                              @ajefr non, tu parles à un mec qui a un bon bagage en electronique analogique et numérique. Et un truc est sûr : quand un signal de base est pourri, tu n'en feras pas un cheval de course 🙂 donc ce n'est pas un informaticien qui te répond, juste un mec qui a un diplôme assez loin post bac avec une spécialisation traitement du signal 1D/2D ^^
                              • haricot
                                J avoue que ce qui m'interesse c'est le coté "authentique" du rendu graphique ( je tente une intégration compléte dans une SNES avec manettes/transfo/péritel d'origine). voila pourquoi je suis passé par un adaptateur VGA - HDMI , j'avais besoin du GPIO pour connecter le front panel de la SNES.
                                Si la qualité sonore est un peu en dessous , il ne faut pas oublié que la destination est un tube , et le son n'était déja pas leur point fort...
                                J'avoue que ce qui me chagrine le plus c'est le coté INPUT LAG que certain reproche au PI (mythe ou réalité ? :D).
                                Du coup j'avais un peu mis le projet de coté pour essayer de faire un bidouillage pour le mesuré cette input lag .
                                L idée c'est d'utiliser une caméra USB rapide ( j'ai par le boulot une 640x480 en 120 fps) et d'enregistrer une vrai SNES avec le pad branché à un relais USB ( j'utilise un SDK qui me permet d'insérer des infos sur la vidéo , comme l'appuis sur le bouton ou le temps de chaque frame ) . Je peux donc avoir le delta de temps entre l'appui sur "jump" par exemple , et son action a l'écran .
                                L'idée par la suite c'est de comparer ca avec les différent émulateurs.
                                Désolé si je sors un peu du cadre du Topic , mais si on en ai à vouloir du Pixel Perfect autant pousser le raisonnement jusqu'au bout.
                                Bien à vous.
                                Stéphane.
                                greenalex Substring 2 Replies Last reply Reply Quote 1
                                • greenalex
                                  greenalex @haricot last edited by
                                  @haricot
                                  +1 Pour moi aussi, l'input lag est un peu la grosse zone d'ombre qui traîne au-dessus de tous les projets liés à l'émulation sur Pi ( et l'émulation en général...). Mais n'ayant qu'un RP 2, et en attendant le prochain RP4, je prends mon mal en patience B-)... Les réglages de Retroarch que j'ai trouvé sont pas mal, meme s'il faut modifier la config suivant les émulateur.
                                  Sinon, encore un gros coup de chapeau à tous ceux qui œuvrent autour de ces projets de pixel perfect sur CRT !
                                  J'aimerai y participer mais mes connaissances en la matiere m'obligent, comme pas mal de monde je pense, à rester un spectateur quotidien de vos exploits...
                                  Hâte que les différentes solutions soient accessibles, sous forme d'achat ou de montage accessibles au petits bricoleurs !
                                    @haricot @greenalex pour le pixel perfect CRT, on va avoir un travail titanesque. Il ne suffit pas d'afficher sur du CRT, mais aussi générer la bonne résolution pou rle téléviseur. Chaque console de salon a AU MOINS 2 resolutions. Donc il va falloir, à partir de la ROM, trouver les éléments permettant d'avoir des billes dessus pour arriver au niveau top moumoute en se passant de ADVANCEMESS (qui lui pourrait resoudre nos problèmes, à tester aussi)
                                    • aTg
                                      aTg last edited by
                                      I have opened a web where I will have updated the latest version of Recalbox for CRT made by me, there are also available cables already assembled ready to use.
                                      rgb-pi.com
                                      As says @Substring still we have a lot of work to make all games to work in their original resolutions but for now there is a lot that can already be enjoyed.
                                      • ajefr
                                        Tout à fait d'accord, mais bon, une sortie pwm peut aussi donner d'excellent résultat, c'est bien ce qu'il y a sur tous les amplis classe D.
                                        Par contre, mal filtrée, ça peut être terrible.
                                        Sur les gpios, ce n'est pas un signal analogique qui sort mais bien les mêmes pwm que sur la sortie casque.
                                        Substring ian57 2 Replies Last reply Reply Quote 0
                                          @ajefr alright, you win 😄
                                          • aTg
                                            @ajefr Sorry but the pins 18, 19 ,12.. in the GPIO are PWM analog output
                                            http://pinout.xyz/pinout/pin12_gpio18
                                            100.1k
