    Recalbox sur TV CRT en RGB
    recalbox crt rgb
    51
    782
    824278
    • ian57
      ian57 Staff @ajefr last edited by
      @ajefr @substring yep c'est que l'on utilise ici aussi https://github.com/recalbox/recalbox-os/wiki/Analog-Audio-Pi-Zero-(EN)... bon j'me suis loupé sur les résustances sur le photos 😉 mais sinon c'est pas mal
      • ajefr
        ajefr @aTg last edited by
        @aTg said in Recalbox sur TV CRT en RGB:
        @ajefr Sorry but the pins 18, 19 ,12.. in the GPIO are PWM analog output
        http://pinout.xyz/pinout/pin12_gpio18
        PWM and Analog are two different kind of signals.
        Pins on RPI are PWM, not analog, you have to add some filterings to get a correct analog signal
        FYI:
        You can generate analog from pwm with some filters.
        Generating pwm from analog is not so easy.
        • aTg
          aTg last edited by aTg
          @ajefr Is the same as the signal RGB from digital paralel outputs, this generates a squared signal, what is the problem?
          Did the original games have analog audio chips? I would say that the audio outputs of game consoles were of worse quality than the output of the RPi
          ajefr 1 Reply Last reply Reply Quote 0
          • ajefr
            DPI output is different, it's a numeric representation of a needed voltage.
            It's true that it generate a analog signal but this one do not need (and must not in our usage) to be smoothed because each step might be a pixel.
            About original games, yes, most of them use analog sound for the musics.
            That's called FM chip, YM2151 is the most representative.
            SFX sound are using digital sound.
            • aTg
              aTg last edited by
              I'm much more concerned not being able to generate hdmi_timings or see interlaced modes.
              r11t16 1 Reply Last reply Reply Quote 0
              • r11t16
                r11t16 @aTg last edited by
                Bonjour à tous. Je suis à ranger dans la catégorie des débutants mais qui mettent les mains dans le cambouis.
                J'essaie de faire tourner mon rapsberry 3 sur ma tv crt (ça marche sur un lcd) mais quand je vois qu'il faut modifier des fichiers comme /usr ou/etc, je ne sais pas comment faire après quelques heures de recherche.
                Pouvez-vous m'aider?
                Merci d'avance.
                  si tu es sous windows il faut installer winscp , notepad++ et putty
                  voir le wiki
                  r11t16 2 Replies Last reply Reply Quote 0
                  • r11t16
                    r11t16 @acris last edited by
                    This post is deleted!
                    • r11t16
                      @acris said in Recalbox sur TV CRT en RGB:
                      voir le wiki
                      J'ai réussi à faire tout ça, j'ai bien l'affichage du thème CRT sur mon écran mais j'ai maintenant un problème d'écran noir au lancement des jeux, il doit y avoir un mauvais réglage ma part. Je suis encore un peu perdu avec les videomode=CEA 6 HDMI ou parfois = CEA 21 HDMI.
                      Pour le moment je ne fais que des essais sur snes avec un fichier snes.cfg créé.
                      • ian57
                        @aTg @Substring Goot news... RGB-Pi is supported almost out of the box in 4.1 : the only thing is to add some lines in the conf.txt :
                        dtoverlay=rgb-pi
                        enable_dpi_lcd=1
                        dtoverlay=pwm-2chan,pin=18,func=2,pin2=19,func2=2
                        display_default_lcd=1
                        dpi_output_format=6
                        dpi_group=2
                        dpi_mode=87
                        hdmi_timings=320 1 20 29 35 220 1 10 14 16 0 0 0 60 0 6400000 1
                        and the results :
                        alt text
                        alt text
                        alt text
                        After that need to tune the libretro core to fix the image
                        • ian57
                          ian57 Staff last edited by
                          A lot of reading to do to understand how hdmi_timings are working....
                            Substring @ian57 last edited by
                            @ian57 please share anything that would be worth
                            • ian57
                              @substring Of course i will do... but I think there is a great difference between the VG666 mode and the HDMI-VGA mode in terms of hmdi_timings...
                              • aTg
                                @ian57 Great, finally try the cable, I think it will not be necessary to generate hdmi_timings, the games are not seen in a correct aspect ratio if we generate the hdmi_timing, for example snes is 256x224 but this is 8:7 aspect ratio and need to rescale to 4:3, with the timing and nothing more the image show with much overscan. So it is better to start from a resolution like 1920x240 and expand it horizontally to 4:3 but keeping the 224 pixels vertical.
                                I've been testing for a long time and this is definitely the best option because in this way we do two jobs in one, we have a universal timing and at the same time we rescale the games to 4:3
                                The tests that I am currently doing are 480x300 for fronend and recovery (this is a custom timing the most "HD" posible), default for n64 and 1920x240 for global.videomode.
                                After each machine has its .cfg with the necessary rescaling and center parameters, the next step is to create .cfg for each game as a temporary solution to see all games in the original aspect.
                                • ironic
                                  ironic last edited by ironic
                                  @aTg
                                  Hi.
                                  I tried RGB-Pi40Beta3, nice job 🙂
                                  First boot, all was so ... ugly 😉
                                  Of course, i use my home made GPIO2SCART so i put :
                                  dpi_output_format=5 in config.txt
                                  and change dtoverlay=rgb-pi by dtoverlay=vga666
                                  (but dtoverlay=rgb-pi works)
                                  Let see how i prefer use Rpi/CRT :
                                  For emulationstation :
                                  • I Prefer to use this timings : hdmi_timings 506 1 8 44 52 240 1 6 10 6 0 0 0 60 0 9600000 1
                                    (But your timings ar ok)
                                  • Another skin, this one isn't very nice on CRT.
                                  For RetroArch :
                                  • I use vertically pixel perfect but not horizontally.
                                    So INTERGER SCALE must be DISEABLE !!
                                    and vertical pixels must be set in CUSTOM_VIEWPORT_HEIGHT.
                                  • I use horizontally high resolution as :
                                    hdmi_timings 1920 1 52 208 260 240 1 6 10 6 0 0 0 60 0 38400000 1
                                    (i use this timings for all emulators)
                                  • I Disable THREADED VIDEO (less input/video lag)
                                  • I Disable HW Bilinear Filtering (no nee with 1920 pixels)
                                    (But needed if i use this timings - hdmi_timings 996 1 24 96 120 240 1 3 10 6 0 0 0 60 0 19200000 1)
                                  • I use ASPECT RATIO INDEX : 22 (Custom)
                                  This is my custom Viewports for Genesis :
                                  aspect_ratio_index = "22"
                                  video_smooth = "false"
                                  video_scale_integer = "false"
                                  video_threaded = "false"
                                  custom_viewport_width = "1920"
                                  custom_viewport_height = "224"
                                  custom_viewport_x = "-14"
                                  custom_viewport_y = "12"
                                  I always use 240p, all consoles/computers (usually) use 240p and clip to 239, 224, 192...
                                  (Master System use 192p and have nice black bordes 🙂
                                  Have a high honrizontal resolution is perfect for all systems. No need to
                                  Do not forget there a lot a game in 50Hz, open a 60Hz screen isn't adapted for scrolling quality
                                  I see Mednafen pcengine isn't pixel perfect, 1x ratio is 288x232. Must use other emulator.
                                  Some of Timings i use/used :
                                  hdmi_timings=996 1 24 96 120 240 1 3 10 6 0 0 0 60 0 19200000 1
                                  hdmi_timings=506 1 8 44 52 240 1 6 10 6 0 0 0 60 0 9600000 1
                                  hdmi_timings=336 1 10 30 34 252 1 15 3 42 0 0 0 50 0 6400000 1 AVEC BORDURES
                                  hdmi_timings 480 1 29 35 66 234 1 4 10 18 0 0 0 60 0 9600000 1
                                  hdmi_timings=990 1 22 94 116 240 1 6 10 6 0 0 0 60 0 19200000 1
                                  hdmi_timings=820 1 42 260 100 240 1 6 10 6 0 0 0 60 0 19200000 1
                                  Perfect
                                  hdmi_timings=320 1 12 32 44 240 1 6 10 6 0 0 0 60 0 6400000 1
                                  hdmi_timings=1920 1 52 208 260 240 1 6 10 6 0 0 0 60 0 38400000 1
                                  hdmi_timings=512 1 16 48 64 288 1 3 5 6 0 0 0 50 0 9600000 1
                                  I'm will search for more 50Hz resolution.
                                  • Yes, in this way, RetroArch GUI isn't pixel perfect.
                                  • ironic
                                    I think i found why Mednafen PcEngine uses 232 lines.
                                    The PcEngine can render several resolutions.
                                    256x224 to 512x242, most commonly 256x239.
                                    (here, timings in 1920 are welcome).
                                    Mednaden render first line at 4 (0 to 239), the 4 first lines are ignored.
                                    Mednaden render last line at 235 (0 to 239), the 4 last lines are ignored.
                                    On a 240p (i think, 239 lines are useable on 240) game, 4 to 235 = 232 lines.
                                    I think the first 4 lines and the last 4 lines are unused to show pixels because games never use them.
                                    All that remains to verify.
                                      Substring @ironic last edited by
                                      @ironic Have a look at https://github.com/libretro/RetroArch/blob/master/retroarch.cfg#L226-L228
                                      • ironic
                                        i always set video_crop_overscan to false.
                                        This is only a retroarch option.
                                        Mednafen PcEngine standalone also "crop" to 232p.
                                        lolo 1 Reply Last reply Reply Quote 0
                                        • ian57
                                          @ironic thanks again for your work around hdmi_timings, it saves time to all of us. On my side, I finished a VGA-SCART cable with external power supply on the pin 8 on the SCART, to auto switch the TV on AV mode on start up. It is required for arcade cabinet integration. The wiring schema is below :
                                          alt text
                                            @ian57 The 5V from the Pi isn't enough ?
                                            100.1k
