    Recalbox sur TV CRT en RGB
    recalbox crt rgb
    51
    782
    824086
    • ian57
      @substring Nop, it does not work on my TV... As i read somewhere else, sometimes 5v will be ok, but most of the time not. I tested a 6.5V phone power supply successfully.
      • ian57
        The ultimate VGA-RGBScart cable for arcade cabinet integration 😉
        alt text
        • ironic
          ironic last edited by ironic
          Nice cable.
          I give you Timings i use.
          ** 60Hz Timings ** Up to 224p
          hdmi_timings 960 1 24 96 120 248 1 3 10 6 0 0 0 60 0 19200000 1
          hdmi_timings 1920 1 48 192 240 248 1 3 10 6 0 0 0 60 0 38400000 1
          ** 50Hz Timings ** Up to 256p
          hdmi_timings 1920 1 48 192 240 302 1 3 10 6 0 0 0 50 0 38400000 1
          hdmi_timings 960 1 24 96 120 302 1 3 10 6 0 0 0 50 0 19200000 1
          Do not forget you can change CRT parameters (as overscan) if you CRT isn't too old.
          If you use Arcade monitor, use potentiometers.
          I think 960 horizontal pixel is enough but, feel free to try.
          (Hum, up to 1920 is better...).
          If you want to play arcade games in 224p/60Hz, it is better to sort them.
          I made a script (.bat) to extrach all 224p games from mame and fba romsets.
          85% of best arcade games are 224p, never mind honrizontal resolution.
          There's others game which can"t be run in 224p. like R-Type (384x256x55Hz)
          Let's see what wee can do...later....
          • aTg
            aTg last edited by aTg
            @ironic but the horizontal resolution needs to adjust to the screen, by default many machines resice the native resolutions to 4:3 format and if you expand horizontal many games to 1920x224 the aspect ratio of the game is not 4:3
            In SNES for example I need to put 1778x224 in snes.cfg (using 1920 timing) to view the correct aspect of the game.
            The case of CPS3, is inside the list of 224p games but is 384 in the horizontal resolution, this shows incredible ovescan for inportant games like sf2.
            I think the solution is a database, based on a one standar resolution and with the resicing parameters for every rom, is a lot of work I know but is the only way.
            • ironic
              Yes, of course, i also resize horizontally to have 4/3 screen.
              If not, the horizontal overscan is big and the game isn't 4/3.
              In snes, i have approximately the same resolution.
              For a games of 256x224, 320x224 or 384x224, it's the same viewport.
              If viewport is setup for a 224p 4/3 game, it can accept all 224p games.
              I have an arcade database of over 8000 games with many games informations. i'm writing severls small batabases of games, by vertical resolution and refresh rate.
              I think also, databases are the only way to handle games specs.
              (i do it since a year with games lists for severals Fba.libretro versions)
              We must do for MAME and FBA :
              Databases of :
              • 190p at 50Hz
              • 190p at 60Hz
              • 200p at 50Hz
              • 200p at 55Hz
              • 200p at 60Hz
                240p at 60Hz
                256p at 55Hz
                Substring @ironic last edited by
                @ironic mame can generate .dat files with resolution info. I've been using that for some time, but take care to take an old mame version because the format changed on latter versions. As I've worked pretty much with advancemame which is based on Mame 0.106 i have the XML file.
                • onaryc
                  onaryc last edited by onaryc
                  Hi,
                  I follow this thread for some time trying to keep up with all the work/solutions when i will have time to do this.
                  There is one thing which is not clear for me : who is setting the correct resolution? Is it done by script before launching the emu (libretro core,...) or are you setting the timings and then when the emu ask for a particular resolution, the system changes accordingly (like emu, i.e. mame with autoswitch res, on a PC with soft15khz for example)?
                  If this is the first solution, how is the resolution modification during game execution is taken into account?
                  Of course, imho, the second solution seems to be the best one, but perhaps there is some limitation from the emu themselves.
                  Anyway, keep up the good work, it will be amazing to have a simple 15khz RGB output on the PI!
                  • ironic
                    @Substring
                    Is it this type of database ?
                    8000 arcade games
                    @onaryc
                    RGP-Pi (Recalbox 4.0)
                    For this time, there is one resolution by libreto core.
                    All resolutions can be found in config.txt file.
                    It's ready to play. emulator resolution is launched before emulator and emulationstation resolution is restored before back to emulationstation .
                    I think changing resolution on the fly in game is impossible.
                      @ironic it's just from a mame .dat file 🙂 find a mame exe, check its command line switches and you will see 🙂
                      • ironic
                        @Substring
                        Ok, the MAME XML 😉
                        Let see how i handle multiple resolutions by emulator.
                        Sorry, i don't use Configgen.
                        Emulator :
                        • MAME
                        Few games :
                        • R-Type (rtype.zip) : 384x256x55Hz
                        • After Burner II (aburner2.zip) : 320x224x60Hz
                        • Golden Axe (goldnaxe.zip) : 320x224x60Hz
                        • Caveman Ninja (cninja.zip) : 320x240x60Hz
                        I use 4 resolutions (more come soon) :
                        1920 1 48 192 240 248 1 3 10 6 0 0 0 60 0 38400000 1 For fullscreen 224p at 60Hz games.
                        1888 1 48 184 232 278 1 3 10 6 0 0 0 55 0 38400000 1 For fullscreen 256p at 55Hz games.
                        960 1 24 96 120 248 1 3 10 6 0 0 0 60 0 19200000 1 For all others games which are not in databases (just for try games).
                        480 1 14 45 56 300 1 10 5 5 0 0 0 60 0 9600000 1 For EmulationStation.
                        In datadases, i have referenced 2 games :
                        [aburner2.zip] to use 224p x 60Hz
                        [rtype.zip] to use 256p x 55Hz
                        From emulationstation/MAME, i have :
                        After Burner II
                        Caveman Ninja
                        Golden Axe
                        R-Type
                        If i choose After Burner, the game is launching in fullscreen 224p 60Hz with "retroarchcustom.cfg" AND 224-60.cfg (for adapted viewport of all 240p games)
                        If i choose R-Type, the game is launching in fullscreen 256p 55Hz with "retroarchcustom.cfg" AND 256-55.cfg (for adapted viewport of all 256p games)
                        If i choose Golden Axe, the game is launching in a 960x240x60Hs screen with "retroarchcustom.cfg" AND standart.cfg (small viewport to try games) because is not in database
                        If i choose Caveman Ninja, the game is launching in a 960x240x60Hs screen with "retroarchcustom.cfg" AND standart.cfg (small viewport to try games) because is not in database
                        I think is the perfect way to handle multiple resolutions per core.
                        It works great
                        The databases is a file named "resolution.cfg" in recalbox/share/roms/mame/ folder
                        In this file there's :
                        declare -A mame_games
                        #320x224x60Hz
                        mame_games[aburner2.zip]="224-60"
                        mame_games[goldnaxe.zip]="224-60"
                        mame_games[shinobi.zip]="224-60
                        #384x256x55Hz
                        mame_games[rtype.zip]="256-55"
                        It's very easy to add game to resolution.
                        CODE :
                        . /recalbox/share/roms/mame/resolutions.cfg
                        if [[ "$emulator" == "mame" ]]; then
                        	if [[ -n ${mame_games[$filename]} ]]; then
                         		if [[ ${mame_games[$filename]} == "224-60" ]]; then
                         	          vcgencmd hdmi_timings 1920 1 48 192 240 248 1 3 10 6 0 0 0 60 0 38400000 1
                               		  tvservice -e "DMT 87"
                                	  fbset -depth 8 && fbset -depth 16
                               		  retroarch -L /usr/lib/libretro/mame078_libretro.so --config /recalbox/share/system/configs/retroarch/retroarchcustom.cfg --appendconfig /recalbox/share/system/configs/retroarch/resolutions/${mame_games[$filename]}.cfg $1
                        		elif [[ ${mame_games[$filename]} == "256-55" ]]; then
                        		  vcgencmd hdmi_timings 1888 1 48 184 232 278 1 3 10 6 0 0 0 55 0 38400000 1
                        		fi
                        	else
                                  vcgencmd hdmi_timings 960 1 24 96 120 248 1 3 10 6 0 0 0 60 0 19200000 1
                                  retroarch -L /usr/lib/libretro/mame078_libretro.so --config /recalbox/share/system/configs/retroarch/retroarchcustom.cfg --appendconfig /recalbox/share/system/configs/retroarch/resolutions/standart.cfg $1
                        	fi
                        vcgencmd hdmi_timings 480 1 14 45 56 300 1 10 5 5 0 0 0 60 0 9600000 1
                        fi
                        Of course, it can (will) be optimised...
                          @ironic As 4.1 is coming closer and closer (have you seen the blog is back ?) this will be a little different as you can :
                          • add per system .cfg (well, you can already do it, that's something we made quite early in this topic)
                          • add per rom .cfg (not much different in fact)
                          • have configgen use hdmi_cvt or hdmi_timings resolutions. What is truly missing is to handle a per game resolution. Haven't found yet an elegant way to do it, except having a massive file saying which resolution for which game (that needs to be written. I wanted to have, for each arcade rom : resolution + screen rotation angle)
                          • ironic
                            A per game resolution ins'nt needed, need resolutions/frequency for games...
                            Arcade games must be separate :
                            • Mame or FBA.
                            • Honrizontal or vertical.
                            • Resolutions.
                            • Frequency
                            I have 350 MAME roms and 340 FBA.
                            I need more 30 resolutions/frames rate files.
                            To handle all Mame/Fba games, there is need more files.
                            • ian57
                              ian57 Staff @ironic last edited by
                              @ironic How to change the CRT overscan? A menu in the tv OSD? or need to tune potentiometers inside the TV?
                              • ironic
                                If your CRT isn't too old, there's pehaps a hidden menu. On my 33cm WALTHAM (11AK57 chassis), i must :
                                • Open the menu : MENU KEY
                                • Hit : 4, 7, 2, 5
                                  And the hidden config menu appear.
                                I can't tell you if your CRT have this menu and how open it.
                                On most CRT, you must : Open menu and enter a code (as me 4725).
                                Be carefoul, it's hard to understand all parameters.
                                You must looking for on line for code and/or try all codes you can find.
                                I sorted all my MAME games by resolutions and by frequency.
                                You can see, i must use a lot (more 40) of resolution/frequancy.
                                And remember, here there no vertical games.
                                text alternatif
                                1st ligne, 224p is vertical resolution (no need honrizontal resolution).
                                And 60 is frequency (60Hz).
                                We can bring together some frequency.
                                60.096154 is near 60.
                                But there is some specific resolutions as : 57.444853Hz.
                                Is it near 55Hz or 60Hz ?
                                I think, games up to 240p must be 60Hz and over 240p, 55Hz.
                                And this : 27.407585Hz and 76.293945Hz ?
                                And FBA ??!!
                                Work begin...
                                • ian57
                                  ian57 Staff last edited by
                                  @ironic thanks for the reply... i don't have the remote control of the TV... so no luck tu test if there is a hidden menu 🙂 Will try that on another one. Thanks
                                    @ironic that's why there is AdvanceMame, it's supposed to handle arcade without a hitch.
                                    The real deal for now would rather be consoles
                                    • ian57
                                      @ironic @substring http://www.advancemame.it/doc-install : advmame uses programmable modelines for DPI and HDMI. All seems to be automatic now
                                      "Whatever hdmi_mode you select, the Advance programs will use mode 87 group 2, restoring your selected original mode when finished."
                                        Substring @ian57 last edited by
                                        @ian57 because DMT 87 is the only way to specify hdmi_timngs, you have no choice but :
                                        1. set hdmi_timings
                                        2. switch to DMT 87
                                        • aTg
                                          aTg last edited by
                                          The problem is that we still do not know how exactly the custom hdmi_timings of AdvMAME works to carry it to the other emulators, the Ironic method can be used with all the emulators already.
                                          Does Recalbox plan to introduce these changes officially? Or is it going to have to be another mod?
                                            Substring @aTg last edited by
                                            @aTg as I said, advmame can do the job for now, and that's why i added it. For the retroarch part, this will come later, but for now, it looks like anything linked to arcade is not yet ready, so i can't implement anything yet. The subject is complicated and has not yet reached maturity, i will spend some time on it once the tries and conclusions seem definitive.
                                            If I'm not mistaken, so far we're just trying to reach a DAR of 4:3, but not a PAR of 1:1 ... @ironic do you agree with that ?
                                            For emulator, advancemess will also be included, so once again, the same story goes : rely on the emulator. But I didn't even have a single second to test advmess yet. But for now, i have definitely no time to spend on that. Holidays are coming, 4.1 is on the go as said on the blog.
                                            100.1k
