    Recalbox sur TV CRT en RGB
    recalbox crt rgb
    51
    782
    825978
    • aTg
      aTg @Substring last edited by
      @Substring No, are incompatible in many pins and not possible to move.
      But with SPI is possible moving CS pin, RPi in last firmwares accepts any gpio to get CS and the other pins is posible integrate in hdmi_mode=3
      • haricot
        haricot last edited by
        That was the start of my problem ...
        I use the GPIO for input two Nintendo SNES PAD. I was commit to HDMI->VGA for the Display.
        Solutions exist that can use SPI and input on the GPIO.
        pi 2 jamma
        but that cost a lot...
        If we find cheaper hardware , it will be the perfect solution for many of use ....
        Stéphane.
          Substring @aTg last edited by
          @aTg Can't reach 60fps with SPI, so we can't go that way. I had hoped that you only needed as many GPIO as the total number of bits, but looks like this is not possible
          aTg 1 Reply Last reply Reply Quote 0
          • aTg
            aTg @Substring last edited by aTg
            @Substring SPI for input buttons at 10Mhz and DPI for video output at the same time.
            It is totally possible with rgb565 mode3.
              @aTg so it means we can combine GPIO video DPI + a i2c MPC23017 ?
              • aTg
                @Substring MCP23S17 is a SPI version, tomorrow i can upload a preliminar schematic to work, today i finish the last revision of rgb-pi with all improvements i can do and finally pass to the next project.
                • haricot
                  @aTg , You made me curious 😄
                  I'm more comfortable with code than electronic but may be i can be of some help.
                  I found a lot of doc on SPI , but UINPUT is less common...
                  somes questions :
                  -MCP23S17 is a 16 bits inputs , using 2 Joystick and 6 buttons each will use more than 16 bits . does your schematic use two of them ?
                  -Are you using INT or going on a read loop ?
                  I take a look at Controlblock sourcecode , Adding a SPI input will not ask for tons of labor.
                  waiting for your schematics and will make a prototype.
                  Stéphane.
                    Substring @haricot last edited by Substring
                    @haricot We have the mk_gpio_arcade kernel module that is supposed to handle the MPC23017, so no need of any programming, it should already be implemented. Consider 1 MPC23017 per player.
                    if you want some uinput examples, the easiest I know of is xarcade2jstick that we use for keyboard encoders : https://github.com/petrockblog/Xarcade2Jstick (and i'd love to make it a real configurable thing with ini file support for multiple encoders ... if you ever wanna contribute ... 😉
                    • aTg
                      aTg last edited by aTg
                      @haricot Im working on the code of ControlBlockService2 , This is a full working soft to mcp23s17 but the driver to control the chip is bcm2835.c and not is included the lines to use aany GPIO pin to CS, RPi last versions can drive CS from any GPIO pin makin an overlay and i compile one but the ControlBlock (CB) not works in a different pins that 7 or 8:
                      The especific line on the code is here:
                      bcm2835.h
                      /*! \brief bcm2835SPIChipSelect
                       Specify the SPI chip select pin(s)
                      typedef enum
                         BCM2835_SPI_CS0 = 0,     /*!< Chip Select 0 */
                         BCM2835_SPI_CS1 = 1,     /*!< Chip Select 1 */
                         BCM2835_SPI_CS2 = 2,     /*!< Chip Select 2 (ie pins CS1 and CS2 are asserted) */
                         BCM2835_SPI_CS_NONE = 3,  /*!< No CS, control it yourself */
                      } bcm2835SPIChipSelect;
                      Here
                      airspayce(.com)/mikem/bcm2835/group__constants.html#ga29bba154633d37d07fa130a86e4a1f2aurl REMOVE THE PARENTESIS I SPAM PROBLEM WITH TE FORUM
                      explain the options por CS but i find another version of the driver.
                      This include the GPIO CS options for a arduino project, i added the code and compile:
                       typedef enum
                            // Only GPIO > 3 can be used (to not interfere with the previous value just above )
                                // Lucky we have plenty of theese pins
                           BCM2835_SPI_CS_GPIO4  = RPI_V2_GPIO_P1_07,
                           BCM2835_SPI_CS_GPIO17 = RPI_V2_GPIO_P1_11,
                           BCM2835_SPI_CS_GPIO18 = RPI_V2_GPIO_P1_12,
                           BCM2835_SPI_CS_GPIO22 = RPI_V2_GPIO_P1_15,
                           BCM2835_SPI_CS_GPIO23 = RPI_V2_GPIO_P1_16,
                           BCM2835_SPI_CS_GPIO24 = RPI_V2_GPIO_P1_18,
                           BCM2835_SPI_CS_GPIO25 = RPI_V2_GPIO_P1_18,
                           BCM2835_SPI_CS_GPIO28 = RPI_V2_GPIO_P5_03,
                           BCM2835_SPI_CS_GPIO29 = RPI_V2_GPIO_P5_04,
                           BCM2835_SPI_CS_GPIO30 = RPI_V2_GPIO_P5_05,
                           BCM2835_SPI_CS_GPIO31 = RPI_V2_GPIO_P5_06
                      After change the inicialization of the driver in bcm2835.c:
                       void bcm2835_spi_begin(void)
                      volatile uint32_t* paddr;
                      /* Set the SPI0 pins to the Alt 0 function to enable SPI0 access on them */
                      bcm2835_gpio_fsel(RPI_GPIO_P1_26, BCM2835_GPIO_FSEL_ALT0); /* CE1 */
                      -  bcm2835_gpio_fsel(RPI_GPIO_P1_24, BCM2835_GPIO_FSEL_ALT0); /* CE0 */
                      + bcm2835_gpio_fsel(RPI_GPIO_P1_22, BCM2835_GPIO_FSEL_OUTP); /* CE0 */
                      bcm2835_gpio_fsel(RPI_GPIO_P1_21, BCM2835_GPIO_FSEL_ALT0); /* MISO */
                      bcm2835_gpio_fsel(RPI_GPIO_P1_19, BCM2835_GPIO_FSEL_ALT0); /* MOSI */
                      bcm2835_gpio_fsel(RPI_GPIO_P1_23, BCM2835_GPIO_FSEL_ALT0); /* CLK */
                      /* Set the SPI CS register to the some sensible defaults */
                      paddr = bcm2835_spi0 + BCM2835_SPI0_CS/4;
                      bcm2835_peri_write(paddr, 0); /* All 0s */
                      /* Clear TX and RX fifos */
                      bcm2835_peri_write_nb(paddr, BCM2835_SPI0_CS_CLEAR);
                       void bcm2835_spi_end(void)
                      /* Set all the SPI0 pins back to input */
                      bcm2835_gpio_fsel(RPI_GPIO_P1_26, BCM2835_GPIO_FSEL_INPT); /* CE1 */
                      - bcm2835_gpio_fsel(RPI_GPIO_P1_24, BCM2835_GPIO_FSEL_INPT); /* CE0 */
                      + bcm2835_gpio_fsel(RPI_GPIO_P1_22, BCM2835_GPIO_FSEL_INPT); /* CE0 */
                      bcm2835_gpio_fsel(RPI_GPIO_P1_21, BCM2835_GPIO_FSEL_INPT); /* MISO */
                      bcm2835_gpio_fsel(RPI_GPIO_P1_19, BCM2835_GPIO_FSEL_INPT); /* MOSI */
                      bcm2835_gpio_fsel(RPI_GPIO_P1_23, BCM2835_GPIO_FSEL_INPT); /* CLK */
                      And finally i change the file mcp23s17pi.cpp and recompile CB:
                       bcm2835_spi_begin();
                            bcm2835_spi_setClockDivider (BCM2835_SPI_CLOCK_DIVIDER_32);    // 3.9 MHz
                            bcm2835_spi_chipSelect(BCM2835_SPI_CS_GPIO25);
                      All is compiled without errors but not work :_(
                      • aTg
                        The schematic for audio+rgb+buttons over gpio...
                        https://drive.google.com/open?id=0B71ugqHtPbYMZzY1SHViRFRjUTQ
                        It's a quick drawing, I'm still working on it.
                        ajefr 1 Reply Last reply Reply Quote 0
                        • n3o_c59
                          n3o_c59 last edited by
                          Salut les gars,
                          J'ai fais un Screenshot après avoir suivi le tuto. Comme dis un peu plus haut j'ai une zone de mon écran qui n'est pas prise en compte, et ça donne ça :
                          J'ai fais comme le tuto express mais en hdmi_cvt j'ai mis 720 au lieu de 1920 parce que ça ne passait pas sur ma TV (trinitron)
                          Une petite précision par contre, dans mes fichiers cfg pour chaque emulateur j'ai dû doubler la résolution pour avoir du plein écran (genre au lieu de 224 j'ai 704)
                          Voilà... Je précise que je ne maîtrise pas tout pour le moment désolé si ça paraît simple comme solution !
                          Merci !
                            Substring @n3o_c59 last edited by
                            @n3o_c59 Tu as un problème de ratio, on dirait que tu es en 21/9
                            • n3o_c59
                              Ah ça peut venir de ça ?
                              Merci, je vérifie ça en rentrant mais le ratio est sur "custom" il me semble.
                              Sinon je le mets dans recalbox.conf ? Ou je dois définir un ratio genre 8/3 et le modifier en fichier cfg pour chaque console ?
                                @n3o_c59 essaie juste sous retroarch de changer les ratio pour voir le resultat immediatement
                                • n3o_c59
                                  Merci @Substring ! J'ai enfin mon plein écran 👍
                                    @n3o_c59 donc tu es sur quelle valeur ?
                                    • ajefr
                                      ajefr @aTg last edited by ajefr
                                      @aTg said in Recalbox sur TV CRT en RGB:
                                      You should take care of never shorting two ouput pins.
                                      Especially when both signals could have different value at the same time.
                                      When hsync is high and vsync low, you create a short circuit inside the pi.
                                      You may destroy it with time.
                                      • aTg
                                        aTg @ajefr last edited by
                                        @ajefr Ok, tomorrow I can upload a more polished version with everything corrected, also must see if it is possible to avoid putting resistors in the inputs of the MCP23S17, they should only go to mass but the output current can also create a short circuit too.
                                        • aTg
                                          aTg @aTg last edited by
                                          @ajefr Here a clean schematic with the error solved and more clear, the name of the input buttons and the orden is arbitrary.
                                          alt text
                                          • aTg
                                            aTg last edited by
                                            A great job of the friend @Substring already makes it possible to change resolutions on the fly in Recalbox and DPI output.
                                            I tested it with RGB-Pi and it works perfectly, here some tests.
                                            https://www.youtube.com/watch?v=5-tOQPgltNA
                                            100.2k
