    Recalbox sur TV CRT en RGB
    recalbox crt rgb
    51
    782
    825807
      Substring @Scandy last edited by
      @Scandy let's see where lag can come from, depending on the input method :
      • GPIO : the mechanics of sticks/buttons do not generate any lag. The clock scanning the gpio + the processing of the gpio information (which is inside the kernel, not in userspace), then udev or SDL2, is the only source of lag before the data is processed by the emulator
      • USB : again, let'.s not bither with mechanics. The info has to be processed by the onboard chip, send the right info through the usb, then processed by the usb-hid kernel module, udev/sdl2 then emulator
      I'd say the gpio is slightly faster as the processing preceding the emulator is a bit shorter.
      A while ago i tried increasing the kernel rate (known as the Hz patch) + switch the context environment (server/desktop/realtime) ... I wouldn't say i found any miracle, but worse : ES constantly had micro stutters
      Scandy 1 Reply Last reply Reply Quote 0
      • aTg
        aTg @gkralicek2 last edited by aTg
        @gkralicek2 I'm working on a GPIO JAMMA adapter with rgb565, 32 non-latency buttons and audio all through the GPIO.
        Scandy gkralicek2 2 Replies Last reply Reply Quote 0
        • Scandy
          Scandy @Substring last edited by
          @Substring said in Recalbox sur TV CRT en RGB:
          So, forced to only one choice, you'd rather use the GPIO for video or controls?
          IMHO the delay generated by an HDMI>VGA converter is more sensitive than that induced by USB hardware.
          I do not take into account the delay caused by the emulator/SDL because it would be present in both cases.
          • Scandy
            Scandy @aTg last edited by
            @aTg a RGB-Pi with female SCART and one (or two) DB15 female controller ports would be definitive, IMHO.
            aTg 1 Reply Last reply Reply Quote 0
            • gkralicek2
              gkralicek2 @aTg last edited by
              @aTg That's good news ! Something i could definetely put to good use in my candycab :=)
              But as @scandy mentioned it, an RGB stereo SCART output with DB-15 connectors to plug in neo-geo type arcade sticks would be a definitive killer for CRT TV owners ! :=). Though i doubt there would be enough pins on the GPIO connector to achieve this...
              • aTg
                aTg @Scandy last edited by aTg
                @Scandy That already exists, the rpi2scart ... (A bit expensive the truth)
                He thinks that I am alone, I can not launch so many projects at the same time.
                I had an idea about this that you are telling me, so that it was not the same as everything I had thought of including in the design a box for the RPi in the form of a console, its connector scart on the back and the DB15 in front, with button of power and reset.
                But it's just an idea.
                @gkralicek2 If there are, I already have a prototype working.
                alt text
                • Scandy
                  @aTg said in Recalbox sur TV CRT en RGB:
                  alt text
                  A board with the same form-factor of RPi, placed on top of it (like a "shield") with female SCART and DB15 controllers... hmmmmmm! 😄
                  • gkralicek2
                    @aTg Now that's impressive ! Good job mate !
                    • Scandy
                      Ok guys, I need your help. 🙂
                      RPi3 > HDMI to VGA > OK! (on a LCD monitor)
                      but
                      RPi3 > HDMI to VGA > VGA to SCART (from Retrocable.es)
                      ...I get only a black picture. 😞
                      My crt TV seems to recognize that there is some kind of signal, but I only get a black picture. What I'm doing wrong? :_(
                      Thanks.
                      aTg Substring gkralicek2 3 Replies Last reply Reply Quote 0
                      • aTg
                        @Scandy For the tv to be set to RGB mode you need 3v on pin 16 of the scart.
                          @Scandy said in Recalbox sur TV CRT en RGB:
                          D**n, i had hoped I2C pins would still be available in DPI mode, or that DPI can be used for DPI. Looks like not. Too bad 😕
                          One test that could be done is use a HDMI multiple output, and compare HDMI vs HDMI2VGA at the same time.
                          Anywya, enugh of trolling stuff 🙂
                            but
                            Thanks.
                            @archimage or @ian57 any clue ?
                            • gkralicek2
                              gkralicek2 @Scandy last edited by gkralicek2
                              @Scandy Have you plugged the USB connector from the "retrocable.es" cable into one of the Pi USB port or a USB power supply ? You need that +5v line to be connected so the TV can switch to RGB mode properly otherwise it will expect a composite signal by default and display a blank screen.
                              If you've done that already and still have a black picture then have you modified the config.txt and recalbox.conf files in order to output a video mode compatible with the TV @15khz (such as CEA mode 6 -> 480i or CEA mode 8 ->240p) ?
                              You could use :
                              hdmi_group=1
                              hdmi_mode=6
                              in your ./boot/config.txt file so that emulation station is displayed in 480i (640*480 interlaced mode)
                              and :
                              global.videomode=CEA 8 HDMI
                              in your ./recalbox/share/system/recalbox.conf file so that your emulators run at 240p (720x240 progressive). Note that you will have to adjust the aspect ratio in retroarch and activate the "smoothing" option in recalbox menus to get a proper 4/3 display in your games out from the 720x240 res.
                              • Scandy
                                Scandy @gkralicek2 last edited by
                                @gkralicek2 thank you very much for your feedback.
                                Yes, the USB was connected, but in config.txt I only set hdmi_safe=1.
                                I'll check with
                                hdmi_group=1
                                hdmi_mode=6
                                Thanks!
                                gkralicek2 1 Reply Last reply Reply Quote 0
                                • ian57
                                  ian57 Staff @Substring last edited by
                                  @Substring as gkralicek2, I was thinking of the +5V which force the tv to switch to the right mode.
                                  • gkralicek2
                                    @Scandy Then that's for sure the source of your problem :=)... If you haven't configured the config.txt file with a proper output video mode compatible with what your CRT TV can display, all you'll get is a black screen. Default boot up res is 640*480 progressive @31khz which is compatible with a PC LCD screen but NOT with a TV set which is limited to resolutions using a 15khz horizontal frequency (240p, 480i or 576i).
                                    Once you'll have applied the settings i gave you in my previous post, you should get a picture :=)
                                    • Scandy
                                      @gkralicek2 @ian57 @Substring thank you for your help!
                                      Adding a male - female VGA cable between the HDMI > VGA adapter and Retrocable VGA > SCART fixed it (of course I've also setup config.txt).
                                      Now I have a perfectly clear RGB picture on my good old crt TV. 🙂
                                      Unfortunately, it seems that real time resolution switch does not work in AdvanceMAME using the HDMI > VGA adapter (I only get a black screen... l'll write to Andrea).
                                      So I still wait for the GPIO - VGA from Malaysia... 😕
                                      P.S. If someone's interested, I found how to use Unibios in AdvanceMAME.
                                        @Scandy check my issue at Andrea : you're supposed to configure your monitor in advcfg first
                                        • Scandy
                                          @Substring thank you very much for your advice (and for your constant support) I've yet manually configured my monitor (crt TV) in advmame.rc but it seems an issue related to HDMI > VGA adapter I'm using (I can't even run videomodes in advcfg). I'll check with the GPIO-VGA when I'll receive it.
                                          I'm testing the 3.1 RC and it's great: Andrea fixed many little things, and audio and vsync are now perfect, as the UI.
                                          BTW I've checked both the HDMI > VGA > SCART output and the Composite output and let me say that... to me, lag brought by my Lindy HDMI > VGA is consistent.
                                          Ryuuko no Ken (Art of Fighting) in Composite is much more reactive, I hardly feel the difference with the real CMVS. Can't wait to test the VGA shield on the same aspect.
                                          On the other hand, seeing AdvanceMAME in pure RGB at 240p@60hz (fixed, for now) is impressive.
                                          I smile thinking about how emulation on RPi was different just some time ago. Who knows what the future holds! 😉
                                            @Scandy OK, i'm now equipped for pi 2 scart through GPIO. Advmame 3.1-rc sound is fuzzy sometimes (like when a vinyl was turning too fast), i didn't get this behaviour on normal HDMI. Dunno how to check the resolution change, but i'm not sure it happens.
                                            100.2k
