    [Recalbox 9] Theme Next Pixel
    Themes & Interface
    theme recalbox 9
    148
    783
    1180354
      paradadf Staff @lhari84 last edited by
      @lhari84 thanks! And I’m sure for any doubt you might have on how to contribute, you can ask on screenscraper’s discord and even tag @abunille directly. It isn’t that difficult as it might seem.
      • mYSt
        mYSt Theme moderator last edited by mYSt
        v1.2.1 available
        just released a patch version to fix musics loudness.
        Your ears will enjoy it! 😉
        flaker38 jorgemagana 2 Replies Last reply Reply Quote 5
        • flaker38
          flaker38 @mYSt last edited by
          @myst Merci, le son est nickel !
          Odroid XU4Q + Boitier OGST
          • starmagoo
            starmagoo @mYSt last edited by
            @myst Look, in Skraper you can choose different Mediasets like "5 Image Mix", "Box 2D", Box 3D", Box 2D (Side)" and so on. Is a certain mediaset relevant for a good look?
            Bild Text
            mYSt 1 Reply Last reply Reply Quote 0
            • mYSt
              mYSt Theme moderator @starmagoo last edited by mYSt
              @starmagoo internal mix > screenscrapper v2 looks great for me, but i'm working on a special mix for this theme for a better video integration
              starmagoo 1 Reply Last reply Reply Quote 1
              • mYSt
                Another teasing...
                text alternatif
                myjosito 1 Reply Last reply Reply Quote 1
                • Gaetan
                  Gaetan Theme moderator last edited by
                  Hi @mYSt ! You are doing an amazing work with this theme!
                  I know it takes hundreds of hours to achieve such work, I'm sure everyone that is using it is gratefull 🙂
                  mYSt 1 Reply Last reply Reply Quote 2
                  • mYSt
                    mYSt Theme moderator @Gaetan last edited by
                    @gaetan Hey @Gaetan nice to see you around, thx for your feedback, i know you know this is time consuming ;), your work inspired me as well!
                    Gaetan Scavy 2 Replies Last reply Reply Quote 0
                    • Gaetan
                      Gaetan Theme moderator @mYSt last edited by
                      @myst thank you, it's nice to hear it 🙂
                        Scavy Global moderator @mYSt last edited by
                        Hi @myst !
                        Excellent idea you have to include the video snap inside a console or a screen !
                        With the support + 3d box, it's a must !
                        • jorgemagana
                          jorgemagana @mYSt last edited by
                          @myst hello, system freezes when selecting 3-Light Blue in Theme Menu
                          • mYSt
                            mYSt Theme moderator @jorgemagana last edited by
                            @jorgemagana Hi, thx for reporting, will be fixed next release
                            jorgemagana 1 Reply Last reply Reply Quote 1
                            • myjosito
                              myjosito @mYSt last edited by myjosito
                              @myst Alors franchement, bravo. Ca me tente franchement
                              Tu as une idée de la date de release ? (question de jour ? semaine ? mois ?)
                              Et il y aura toujours la possibilité d’intégrer le synopsis, non ? je ne le vois plus dans ton dernier teasing...
                              Merci en tout cas, de la belle ouvrage ! 🙂
                              • jorgemagana
                                @myst thanks
                                • starmagoo
                                  @myst thanks for the hint. All I can so ist the 3d Box or the video in the gamelist. How can I change this to your example?
                                  3dbox
                                  Video
                                  • ViRuS-MaN
                                    ViRuS-MaN last edited by ViRuS-MaN
                                    bonjour
                                    regarde le problème que j'ai sur mon odroid xu4 assez souvent , j ai utilisé la version 1080 et 720 et j ai toujours ce problème
                                    Affichage
                                    • mYSt
                                      Hello,
                                      @starmagoo as i said you need to scrap using internal mix > screenscrapper's recalbox v2 and add the video as well, that's the ones i used for my screenshot
                                      @ViRuS-MaN hum aucune idée je ne pense pas pourvoir intervenir sur ce genre de pb (soit un pb hardware soit un pb de emulationstation)
                                      • ViRuS-MaN
                                        je sais pas je vais essaye sur mon pi3 pour voir mais ca fait bizarre pour cela que je voulais te montrer sinon ton thème il est vraiment top la je test beaucoup sur mon odroid car sur ma tele je peux y jouer de mon canapé et comme je dois rester allonger c est top
                                        • lackyluuk
                                          Hi @mYSt
                                          Thanks so much for this absolutely amazing theme. I love it.
                                          First of all the graphics looks so great and you really chose the right music for the right graphics ❤
                                          One question I have is regarding updates: How to update the theme when a new release is out? Download the whole package?
                                          Thanks a lot & cheers 🙂
                                          mYSt 1 Reply Last reply Reply Quote 1
                                          • mYSt
                                            mYSt Theme moderator @lackyluuk last edited by
                                            @lackyluuk Hi thx for your feedback!
                                            i recommand downloading whole package each time a new version is out, this will ensure everything go the way it should 😉
                                            100.8k
