    [Recalbox 9] Theme Next Pixel
    Themes & Interface
    theme recalbox 9
    148
    783
    1180284
    • jejehtc
      jejehtc last edited by
      Hello,
      Can you confirm that the pack for the GPi Case is this one?
      es-theme-next-pixel-crt-small.zip
      mYSt 1 Reply Last reply Reply Quote 0
      • mYSt
        mYSt Theme moderator @jejehtc last edited by
        @jejehtc yes that's it
        • lhari84
          lhari84 last edited by
          Hi @mYSt Thanks, great new backgrounds 🙂
          Unfortunately I have an issue with music:
          I just upgraded to RB 6.1 and latest 720p version 1.2 of Next Pixel theme on Pi 3B+. Now music of your theme ist much louder than sound in-game. I have no idea how to fix this, but I guess the only way would be to reduce volume of sound files in your theme...?
          I have another suggestion about alternate theme for future: A Resident Evil theme for psx and/or dreamcast would be great! 🙂
          Pi 4:
          Sony DualShock 4 (2nd gen), 8BitDo Pro 2, 8BitDo SF30 PRO, Retroflag SUPERPi 4 Case, Recalbox 9.0
          Pi Zero 2W:
          GPi Case 2W, Recalbox 9.0
          • mYSt
            mYSt Theme moderator @lhari84 last edited by mYSt
            @lhari84 Oui des ajustements des sons de recalbox ont été fait juste avant la sortie, je n'ai pas eu le temps de normaliser mes pistes dessus, ca sera corrigé dans la prochaine version
            Edit : Pour resident evil si tu veux le 1 ou le 2 c'est pas gagné il y a très peu pour pas dire pas de source interessante sur le net, assez surprenant pour ces 2 jeux culte
            lhari84 flaker38 2 Replies Last reply Reply Quote 1
            • lhari84
              lhari84 @mYSt last edited by
              @myst I‘m not speaking french, but Google translator helped a bit.
              Thanks for normalization of audio.
              regarding resident evil backgrounds, that‘s really strange because of part 1 & 2 there are even remakes on many platforms that should guarantee source material. too bad 😞
              ...RE code veronica (main part of the series on dreamcast) has no remakes yet, in this case it‘s even worse for sure.
              Pi 4:
              Pi Zero 2W:
              • mYSt
                mYSt Theme moderator last edited by
                teasing...
                text alternatif
                lhari84 1 Reply Last reply Reply Quote 5
                • lhari84
                  @myst Looks fabulous!
                  Does the preview-video come from screenscraper?
                  A bit off-topic, but as you already are implementing it, you maybe have an answer:
                  Is it possible to add preview videos only, WITHOUT touching other meta-data of existing gamelist?
                  I'm asking because it took me a long, long time (almost got insane 😄 ) to modify and correct everthing to what I'd call perfection (correct titles, release dates, genres, descriptions, pictures...) Screensraper data is good, but many things are incomplete, in a bad format or wrong so far, though.
                  So I don't want to re-scrape everything and correct it again, but just ONLY ADD the preview-videos to existing meta-data...
                  I'm currently using software "Skraper", if this helps.
                  Pi 4:
                  Pi Zero 2W:
                  paradadf mYSt 2 Replies Last reply Reply Quote 0
                    paradadf Staff @lhari84 last edited by paradadf
                    @lhari84 said in [Recalbox 6.1][Complete][Snap Videos] Next Pixel theme:
                    My heart hurts when I read comments like that. Why on earth would anyone correct things locally and not in the ScreenScraper database, so EVERYONE can profit from all the needed improvements. The database is cummunity driven and too many people have spent countless hours just so someone like you can just scrape and everything is (almost) perfect for you. If you would have corrected all upstream, it is just a matter of rescraping, as many times as you want, and you would get always better results.
                    voljega lhari84 2 Replies Last reply Reply Quote 5
                    • flaker38
                      flaker38 @mYSt last edited by
                      @myst +1 pour réduire le volume, je me suis fait surprendre en changeant de thème !
                      Sinon c'est vraiment du beau travail, j'adore ton thème !
                      Odroid XU4Q + Boitier OGST
                        voljega Banned @paradadf last edited by voljega
                        @paradadf the screenscraper team asked for help here and didn't even bother to respond to questions.
                        and furthermore you can have a very specific scrape setup like your own genre names or what to hide or not which doesn't align at all with screenscraper
                        • mYSt
                          @lhari84 everything is from screenscrapper but with custom mix, that means scrapping everything again (withcache not a huge deal) but maybe just save your gamelist xml before scrapping (skrapper can save it automatically) and reapply them after scrapping
                          Scavy lhari84 2 Replies Last reply Reply Quote 0
                            Scavy Global moderator @mYSt last edited by
                            @myst La vidéo avec le boitier 3D + et la cartouche à côté, c'est pas (encore) réalisable, si ? Parce que c'est ce que je voulais faire avec Skraper et j'ai pas pu (ou pas réussi) !
                              paradadf Staff @voljega last edited by
                              @voljega maybe, but as you know, it isn’t usually the case. I always try to fix grammar and wrong encodings upstream when I find them. No many do that.
                              • mYSt
                                mYSt Theme moderator @Scavy last edited by
                                @scavy Si tu parles du gif video que j'ai posté, non ce n'est pas possible directement. J'utilise un mix custom et j'ai du adapter un peu mon theme. Je plublirai tout ça pour la prochaine version du theme.
                                  @myst Merci, oki. Ptet que @bkg2k peut nous proposer un mix vidéo+autre média via skraper lors d'une prochaine mise à jour ? C'est réalisable ?
                                  • mYSt
                                    mYSt Theme moderator @Scavy last edited by mYSt
                                    @scavy said in [Recalbox 6.1][Complete][Snap Videos] Next Pixel theme:
                                    C'est drole on l'a évoqué ce matin mais ne compte pas trop la dessus c'est trop complexe pour pas dire impossible en l'état.
                                    Mais ma petite "bidouille" marche pas trop mal 😄
                                      @myst Oki, je comprends, je ne me rends pas compte de la difficulté. C'est déjà génial qu'on est la vidéo lol On en veut toujours plus mais on sait être aussi content de ce que l'on a 🐵
                                      • starmagoo
                                        starmagoo last edited by
                                        Short question: Do I need a special Mediaset configuration for scraping media with Skraper?
                                        • mYSt
                                          mYSt Theme moderator @starmagoo last edited by
                                          @starmagoo Hello! What do you mean with "Mediaset"? For now you may scrap with any mixes but i'm working on a special mix for better video integration
                                          starmagoo 1 Reply Last reply Reply Quote 0
                                          • lhari84
                                            lhari84 @paradadf last edited by
                                            @paradadf Sorry, I didn't even know that I can participate and change Screenscraper's data source the time I was reviewing my local gamelist.
                                            Further I don't know if anybody else wants the things changed the way like I did.
                                            Regarding genres for example, it was a bug in Skraper, these tags even where missing at all for a longer time period, even though the tag was existing at Screenscraper's database. In this case the only way was to add them locally.
                                            Next time I scrape (for example when adding more systems on a Pi 4 with more RAM), I'll try to do changes online.
                                            Pi 4:
                                            Pi Zero 2W:
                                            100.8k
