    [Recalbox 9] Theme Next Pixel
    Themes & Interface
    theme recalbox 9
    148
    783
    1180448
    • flaker38
      flaker38 @mYSt last edited by
      @myst Thanks !
      Odroid XU4Q + Boitier OGST
      • mYSt
        mYSt Theme moderator last edited by mYSt
        v1.3 release
        So here it is, new Next Pixel theme release, short changelog but lots of work here :). Here are the 2 new features from this release:
        • Next Pixel theme now includes a custom Recalbox starting script to randomly select a game theme for each systems (if system has multiple game themes of course). Sometime it may be difficult to make a choice between all game themes available for a system, so using this script may be a good alternative as you will see a different image each time you start Recalbox. Please read documentation to get more info.
        • Was teased for a long time now, Next Pixel theme now includes its own scraping mix to enhance your game screenshots and/or videos. Using this new mix is not mandatory but theme assumes you will use it and adjust its layout for it, so if you don't want to use Next Pixel mix you will have to disable this option from theme settings. Please read documentation to get more info and sorry, yes!, you have to scrap again ;).
        Check updated original post for documentation and download links.
        Enjoy!
        ap3demak 1 Reply Last reply Reply Quote 9
        • ap3demak
          ap3demak last edited by ap3demak
          Bonjour, ce Thème est fabuleux, j'ai créé pour ma part ce petit thème pour la PSP car j'ai gardé l'ancien pour la PSP Minis.
          Pour ceux qui serait intéressés, le voici.
          Thème PSP en 720p pour version 1.2.1
          ap3demak 1 Reply Last reply Reply Quote 1
          • courte
            courte last edited by
            Vraiment merci pour ce super Theme et pour toutes ces améliorations !
            • ap3demak
              ap3demak @ap3demak last edited by ap3demak
              Version 1.3
              Thème PSP en 720p
              mYSt 1 Reply Last reply Reply Quote 0
              • mYSt
                mYSt Theme moderator @ap3demak last edited by
                I need help!
                If you're interested to get involve in this theme please contact me.
                • I need photoshop expert to help adding new game themes.
                • I need illustator expert to help adding new rating icons.
                • I need translators, if you can convert english to any language, you're welcome.
                J'ai besoin d'aide!
                Si vous êtes interessé pour participer à ce thème contactez moi.
                • j'ai besoin d'un expert en photoshop pour l'ajout de thème de jeu
                • j'ai besoin d'un expert llustator pour l'ajout d'icones pour les notes
                • j'ai besoin de traducteurs, si vous pouvez traduire l'anglais en n'importe quel langue, tu es le/la bienvenu(e)
                ap3demak 1 Reply Last reply Reply Quote 3
                • ap3demak
                  ap3demak @mYSt last edited by
                  @myst Pas de problème pour moi, je suis assez bon sous Photoshop et GIMP ainsi qu'en XML, juste que je ne suis pas souvent dispo [ bien que quand je commence un truc, je le fini dans la foulée 😉 ], mais ça me plait de contribuer a un beau projet comme celui-ci.
                  • ap3demak
                    Voici mon petit thème pour la PSP Minis sur une base de "Angry Birds"
                    • 720p pour version 1.3 >>Download<<
                      @ap3demak
                      créer ton propre sujet si tu réalises des thèmes pour recalbox, nous ne sommes pas un forum pour PSP mini. contacte @mYSt sur discord ou par mp si tu veux partager ton travail.
                      ap3demak 1 Reply Last reply Reply Quote 0
                      • ap3demak
                        ap3demak @acris last edited by
                        @acris ok, pas de probleme
                        • ap3demak
                          @myst Salut, juste pour info, dans le script next_pixel.xml, il manque les (./)
                          (<Item Type="LocalFile" LocalFilePath="./systems/console.png">)
                          • mYSt
                            mYSt Theme moderator @ap3demak last edited by mYSt
                            @ap3demak Tu es sur quel os? pas de soucis pour moi avec les chemins actuels et tous les mix intégrés dans Skraper utilise ce style de chemin.
                            • ap3demak
                              ap3demak @mYSt last edited by ap3demak
                              @myst Je suis sous linux mint et rb6.1/rpi3b+, pour moi j’ai du les mettre, sinon ça ne fonctionnais pas.
                              • mYSt
                                @ap3demak Ok je check ça, merci, sinon si tu veux participer au projet contact moi en mp pour qu'on en discute.
                                • lhari84
                                  lhari84 @mYSt last edited by
                                  @myst
                                  Ok, but how to reapply old gamelist after scraping? If i just delete the fresh one and rename the backed up one after scraping, I'll loose at least the new <video> metatags of freshly scraped gamelist. Is there a comfortable way to merge?
                                  Pi 4:
                                  Sony DualShock 4 (2nd gen), 8BitDo Pro 2, 8BitDo SF30 PRO, Retroflag SUPERPi 4 Case, Recalbox 9.0
                                  Pi Zero 2W:
                                  GPi Case 2W, Recalbox 9.0
                                  • mYSt
                                    mYSt Theme moderator @lhari84 last edited by
                                    @lhari84 Hi, from Skraper you have an option to update gamelist instead of creating a new one, can'tcheck more for now i'm at work
                                    lhari84 1 Reply Last reply Reply Quote 0
                                    • ViRuS-MaN
                                      ViRuS-MaN last edited by
                                      bonjour
                                      je rencontre un petit problème avec la version 6.1 , dans mon dossier fbn j ai des sous dossiers et quand je rentre dedans j ai ceci
                                      text alternatif
                                      text alternatif
                                      text alternatif
                                      est ce qu il y a une chose que j ai mal faites ??? je suis sur mon odroid xu4 et mes roms son sur un disc dur externe pour info
                                      • mYSt
                                        mYSt Theme moderator @ViRuS-MaN last edited by
                                        @virus-man Hello, comme indiqué dans la doc le thème assume que le mix Next Pixel est utilisé pour les scrap. Si tu ne veux pas utilisé le mix Next Pixel il faut le specifier dans les paramètres du thème GAMELISTVIEW > choisir un layout sans le mix Next Pixel
                                        • lhari84
                                          lhari84 @mYSt last edited by lhari84
                                          Hi @myst, I tried the update-option of Skraper, but it seems Skraper always updates the changes I made manually in title, description, etc. to version found online too.
                                          For me this behaviour should be normal, as Skraper can't know I want to keep the texts that differ from its database. But it's fatal in my case...
                                          I'm afraid the only way to add just videos and new picture-sets only, while keeping all other content of gamelist as it is, would be to merge the metadata (especially <video>-tags) from "updated" gamelist to my original, backed up one in some way. But don't know how 😞
                                          Pi 4:
                                          Pi Zero 2W:
                                          • ViRuS-MaN
                                            j utilise les mix , je suis en train de les mettre mais dans mon dossier fbn j ai des sous dossiers et je vois le carre de la video ce qui est genant
                                            100.8k
