    [Recalbox 9] Theme Next Pixel
    Themes & Interface
    theme recalbox 9
    148
    783
    1180542
    • mYSt
      mYSt Theme moderator @lhari84 last edited by mYSt
      @lhari84 maybe ask from Skarper thread if this option could be added
      @ViRuS-MaN Encore une fois la doc peut te répondre :
      Known issues using Next Pixel mix:
      Next Pixel mix uses some overlay on top of your scraped images to make your screenshots/videos appear like they were displayed on a screen (tv/monitor), unfortunately these overlay will appear also for your folders. If you don't use folders this won't be a issue. Note this issue may be fixed in a future Recalbox release.
      For Favorites system videos won't always matched scraped screenshot size as favorites may contain different systems and each systems may have a different resolution. Due to this restriction overlay mention aboved won't be display for Favorites system and so integration may look a bit sloppy here.
      Pour résumé bug connu avec les dossiers, possiblement corrigé dans une future version de Recalbox
      mYSt lhari84 2 Replies Last reply Reply Quote 0
      • mYSt
        mYSt Theme moderator @mYSt last edited by mYSt
        @ViRuS-MaN une solution temporaire consiste à supprimer le fichier next_pixel_mix_overlay dans le dossier es-theme-next-pixel\fba_libretro\data mais du coup le rendu avec les scrap sera moins joli
        • lhari84
          lhari84 @mYSt last edited by lhari84
          @myst said in [Recalbox 6.1+][Snap Videos][Custom mix] Next Pixel theme:
          Ok, I tried there.
          Also wondering that not more people are facing this issue now, with implementing videos to their existing gamelists 😉
          By the way, if you need help with translations, I can do from English to German. (Because of your request in Readme)
          Pi 4:
          Sony DualShock 4 (2nd gen), 8BitDo Pro 2, 8BitDo SF30 PRO, Retroflag SUPERPi 4 Case, Recalbox 9.0
          Pi Zero 2W:
          GPi Case 2W, Recalbox 9.0
          mYSt 1 Reply Last reply Reply Quote 0
          • Cyril92
            Cyril92 last edited by
            Hello @mYSt , beau travail ce thème est magnifique !
            J'ai donc voulu l'essayer dans ma Recalbox 6.1, j'ai téléchargé le thème 1080p
            Je l'ai installé dans le répertoire share/themes sans changer le nom du répertoire, donc extrait sans modification.
            Puis je l'ai activé dans Recalbox.
            Je n'ai que des fonds noirs, et noms des systèmes sans images 😞
            Une idée ou conseil qui me peremttrait de comprendre pourquoi le thème ne s'affiche pas ?
            Je précise que je n'avais pas touché avant au thème par défaut 'recalbox-next'
            System : Raspberry Pi 3b /Pi 4b
            Box : NespiCase (Pi3b) / Nespi4case (Pi4b 2Go)
            Peripheral devices : SSD Samsung 970 Evo 1To
            1 Manette 8bitdo SN30 pro+
            1 Manette compatible PS3 Shanwan
            Je teste la 8.0-Beta1
            Scavy mYSt 2 Replies Last reply Reply Quote 0
              Scavy Global moderator @Cyril92 last edited by
              Salut @cyril92 Evite le 1080p avec un RPi ^^ Ca mange trop de RAM. Utilise une autre version, perso je suis sur la 480p sur le Pi.
              • mYSt
                mYSt Theme moderator @Cyril92 last edited by mYSt
                @cyril92 Comme le dit @Scavy ne prend pas le 1080p pour le PI3 plutot le 720 ou 480, mais surtout lis bien la doc tout y est expliqué.
                Pour ton pb ça vient je pense du fait que tu as du mal installer le theme, verifies que tu n'as pas installé avec un chemin du style
                • recalbox/themes/nextpixel/nextpixel/...
                  eu lieu de
                • recalbox/themes/nextpixel/...
                Un redémarrage est parfois aussi nécessaire
                • mYSt
                  @lhari84 Indeed this is a pb if you edit gamelist with custom data by i guess most people leave it as is after scraping so this is not a pb for them.
                  You're welcome if you want to translate files, not mandatory but do you know how to use git/github? and are you comfortable with xml files?
                  lhari84 1 Reply Last reply Reply Quote 0
                  • mYSt
                    mYSt Theme moderator last edited by
                    alt text Pour les non anglophone la documentation en français est maintenant disponible ici!
                    Je recherche toujours des traducteurs pour d'autres langues, contactez moi.
                    I'm still looking for translators, please contact me.
                    • lhari84
                      @myst
                      git/hub no, I haven't done software development yet.
                      xml yes, at least I'm able to read the gamelist.xmls and others and I'm able to modify them, if this helps 😄
                      Pi 4:
                      Pi Zero 2W:
                      • lhari84
                        lhari84 @lhari84 last edited by lhari84
                        Hi @mYSt,
                        I got another small issue when scraping new mix:
                        When I freshly scrape with your xml template, I recognize I don't have a good in-game screenshot anymore, but very often the in-game title screen or even worse.
                        For better understand what I mean, I attach an example, left the new image, right the old image.
                        Is this problem Skraper-related, or can i change something in your mix-template to receive all in-game screenshots again?
                        Pi 4:
                        Pi Zero 2W:
                        • ViRuS-MaN
                          ViRuS-MaN last edited by
                          vraiment top ton thème , arrm va bientôt arriver avec les mix pour ton thème et le top c est qu on a rien a configurer , y a plus qu a attendre la mise a jour de arrm
                          • mYSt
                            @lhari84 this is by designed, i choosed to display title screen since video will show in game footage next.
                            however you may easily change this from next_pixel_xml file, open file and replace all "ScreenshotTitle" with "Screenshot".
                            You're the second one to complain about this i may change that for future releases.
                            @ViRuS-MaN merci bonne nouvelle!
                            • lhari84
                              @myst Great, thanks for your help! I guess when using video it's better to use "ScreenshotTitle"...
                              In my special case it's better to use "Screenshot", as I will implement new image mix only and not videos for now (as I can't keep my old metadata because there is no easy way to merge video tags ONLY from new scraped gamelist to my original one - the Skraper problem described above)
                              Pi 4:
                              Pi Zero 2W:
                              • luc1anocruz
                                luc1anocruz last edited by mYSt
                                When I remove all media to be able to add USER PROVIDER MIX, it gives an error in Scrap and it closes!
                                • mYSt
                                  mYSt Theme moderator @luc1anocruz last edited by mYSt
                                  @luc1anocruz You should post this on Skraper thread, maybe @Bkg2k could help, but first make sure you're using last version of Skraper (i think it's beta 8). As a workaround if problem occured when you remove all medias, you may instead select first media and choose USER PROVIDED MIX, then select second media and choose VIDEO or click add if no second media is present.
                                  • lhari84
                                    Hi @mYSt,
                                    just wanted to report an issue I found when looking at ES logs.
                                    Seems not to be a big thing, theme works fine so far.
                                    Pi 4:
                                    Pi Zero 2W:
                                    • mYSt
                                      @lhari84 you can ignore it, gw system has no overlay image on top of scraps so this is just a warning cause the image path is empty.
                                      • marwin91
                                        marwin91 last edited by marwin91
                                        Bonjour @mYSt merci pour ce superbe thème, franchement cela rend trop bien!
                                        J'ai un souci avec le scrap sur le mix next pixel, je n'ai pas le mix comme dans tes screenshot et j'ai un petit cadre ou s'affiche la vidéo en plein milieu mais c'est moche. Cela est à cause des sous dossiers? Car sa me le fait sur tout les systèmes même ceux sans sous dossier. Merci pour ton aide.
                                        text alternatif
                                        Raspberry pi4 4go/Argon One M2 v2/Recalbox RGB DUAL/8bitdo SN30 Pro/Recalbox 8.1.1 CRT/B&O MX7000 1.0
                                        • ViRuS-MaN
                                          ViRuS-MaN last edited by ViRuS-MaN
                                          @marwin91 oui c est un bug connue de recalbox y a une solution provisoire
                                          la pour fba liberto car moi j ai des sous dossiers dans fba-liberto
                                          sinon tu dois refaire tes scrapp avec les nouveau mix soit dans skrapper ou bien dans arrm la dans arrm tu n a aucune modification a faire manuellement les mix sont deja bon
                                          • mYSt
                                            mYSt Theme moderator @ViRuS-MaN last edited by
                                            @marwin91 @virus-man il y a en effet un pb pour les dossiers par contre pour le reste ça ne pose pas de soucis, de ce que je vois de ta capture d'écran tu n'as simplement pas scrapé tes jeux avec le mix next pixel. Soit tu rescrap tes jeux avec le mix next-pixel (ce que je conseil pour un rendu vraiment top) soit tu gardes ces scrap et tu vas dans les options du theme > THEME LISTE DE JEU > et tu choisis une mise en page "others mix". Je rappel que TOUT est expliqué encore plus clairement dans la doc (doc d'ailleur traduis depuis peu en français si tu capte rien à l'anglais, donc aucune excuse ;), n'hesitez pas tout de même à m'indiquer si la doc n'est pas claire!
                                            100.8k
