    AMIGA CD32 EMULATION - HOW TO -
    Emulator Arcade/PC/Console
    amiga cd32
    32
    160
    123516
    • Jesús BL
      Jesús BL last edited by
      Does AmigaCD32 addon run in new recalbox 4.1 stable?
      I ran this in beta but I can't in new stable version.
      Trucos y recetas para raspberry pi:
      http://malagaoriginal.blogspot.com.es/search/label/raspberry pi
      djtwok 1 Reply Last reply Reply Quote 0
      • Dragu
        cOOL !
        I also just install CD32 Emulation.
        Is there a chance that this is part as one of the next Recalbox release ?
        voljega Substring 2 Replies Last reply Reply Quote 1
          voljega Banned @Dragu last edited by
          @dragu yes it should be sooner or later, but amiberry has a better support of a500/a1200 than cd32 for now
            Substring @Dragu last edited by
            @dragu As @voljega made the hard part for configgen, we'll take a look sooner or later. Still got 1 bugfix release of 4.1 coming shortly, got some major internal work to do nefore adding new packages, then i'll go into amiga. I'm just now quite disappointed with 2 points :
            • Amiberry is SDL1 for now ... It's more than time to move on to SDL2
            • Amiberry is raspberry only (or am i wrong ?), leaving odroids and x86* on the side
              voljega Banned @Substring last edited by
              @substring yeah the second point is the more bothering clearly, but they're willing to make a version for odroid, for x86, not that much apparently or not in a near future :
              https://github.com/midwan/amiberry/issues/143
              https://github.com/midwan/amiberry/issues/131
              And they are still working SDL2 version, but it looks like it will be released later than sooner 😉
              • mightor
                mightor last edited by
                Hello everybody and many thanks for this tuto. I'll try it ASAP. Can you tell me which version of cd32_base.rom and cd32_ext.rom I need (version # or CRC) ?
                Thanks !
                  voljega Banned @mightor last edited by
                  @mightor Go back a little I posted them in this thread just two months ago
                  mightor 1 Reply Last reply Reply Quote 0
                  • mightor
                    mightor @voljega last edited by
                    @voljega got it ! Many thanks.
                    • ejr
                      ejr last edited by ejr
                      I tracked all the posts in this thread, made everything with the instructions, I even converted my cue/imgs to isos and made new cues for them, but still when I try to load something it always throw me back to recalbox. I edited start.th, made all the changes... It still doesn't work at all. Am I missing something?
                      edited:
                      Always read readme.txt 🙂
                      "RENAME YOUR REQ. EMULATOR AT:
                      ...\CD32-Beta\usr\bin\uae4arm
                      uae4arm-rpi1
                      uae4arm-rpi2
                      uae4arm-rpi3
                      (rename your req. version to "uae4arm" and delete the unused two other versions)"
                      Official relased games work now (I mean that one that are .cue/.iso "originally" downloaded. Unofficial "collections" converted from .cue/.img to iso and with manual made .cues doesn't work for me. But I can now play Banshee! Thanks Ratte!
                        voljega Banned @ejr last edited by
                        @ejr It doesn't seem that Ratte is supporting his version too much anymore, and I can't help you with it.
                        You can try mine if you want, but it doesn't support CD32, only Amiga 500/1200
                        ejr Ratte 2 Replies Last reply Reply Quote 0
                        • ejr
                          ejr @voljega last edited by
                          @voljega I have read Your whdload thread many times, I have huge collection of the whdloads in WinUAE, but I was afraid how it can be complicated in Recalbox (because of the policy to be user-friendly - I know - paradox). Its easy under WinUAE but it seems to be too complicated in Recalbox. ...or maybe I'm wrong?
                          • Dragu
                            @ejr
                            What I used, because seems that there are different versions
                            Kickstart v3.1 rev 40.60 (1993)(Commodore)(CD32).rom
                            and
                            CD32 Extended-ROM rev 40.60 (1993)(Commodore)(CD32).rom
                            and after renaming to cd32_base.rom and cd32_ext.rom
                            ejr 1 Reply Last reply Reply Quote 0
                            • ejr
                              ejr @Dragu last edited by
                              @dragu I used the same roms, like I wrote before - dumped originals (single games in cue/iso format) works. Unofficial compilations (200 Games for CD32 or CD32-444) doesn't work for me, maybe because I obtained those in cue/img format and made a mistake in converting those to cue/iso? Maybe someone knows how to do it properly?
                              • Dragu
                                @ejr
                                In the Amiga hardware description they write
                                The CD32 features a double speed (330 kB/sec) top-loading CD-ROM drive. The supported CD formats are ISO-9660 CD-ROM, Audio CD, CD+G.
                                With the addition of the FMV module CD-i Digital Video and Video CDs can be played.
                                Perhaps you must just create the 9660 type of ISO ?
                                  voljega Banned @ejr last edited by voljega
                                  @ejr my solution is pretty easy to use for whdload if you follow the instructions (just copy the whdload folder of the game and rename a standard uae with the name of the folder alongside it and that's it) and it will be even easier in the final version.
                                  • ejr
                                    @voljega I still can't wait for the final version, but I will try Your solution to the Amiga emulation tomorrow 🙂
                                    • ejr
                                      @dragu I don't think that official 20 years old specifications of the hardware solutions matters today, as it all works in winuae. It's only a matter of config files or emulators in this case. I think something went wrong during converting. This made me to one conclusion - when I editedt start.sh to recognize .cue instead of .iso, can I leave img/cue format, as the cue is a "starter"? Does the uae4all will recognize .img?
                                      • Ratte
                                        Ratte last edited by
                                        Ist easy to write a cue file with a Texteditor.
                                        Then your compilation-cd should work.
                                        Copy one existing cue, rename ist to the same Name like your compilation and edit the file.
                                        Inside rename the filename.bin to your compilation-cd name.
                                        Remove the other filesdescriptions on the cue (the .wav or .mp3 files).
                                        Only one filename.bin should resists insiede the cue.
                                        Thats it .. have fun.
                                        •Raspberry Pi model: Pi ZeroW
                                        •Raspberry Pi model: Pi 3B @ 1350/500/500 MHz
                                        •Raspberry Pi model: Pi 3B+ @ 1550/500/500 MHz
                                        • Ratte
                                          sample cue file - "CD32 100 Games.cue"
                                          FILE "CD32 100 Games.iso" BINARY
                                          TRACK 01 MODE1/2048
                                          INDEX 01 00:00:00
                                          Thats it ... 😉
                                          • Ratte
                                            Ratte @voljega last edited by
                                            @voljega said in AMIGA CD32 EMULATION - HOW TO -:
                                            There is also a life outside of recalbox. I had a little stay in the hospital. Then two weeks ago I was on the Amiga 32 in Neuss to deal with real Amigas. There I got an A1000 cover signed by Dave Haynie, Jeff Porter & Ron Nicholson. Then it went for a week on vacation. Our home remodeling is not quite finished yet and you also have to take care of the family. Besides, I do not see ourselves in the competition, I listed you in the movie credits, because without your help, I would not have been able to integrate the CD32 emulation. That you prefer to integrate a computer and I rather see the Game Console inside Recalbox is secondary.
                                            100.2k
