    AMIGA CD32 EMULATION - HOW TO -
    Emulator Arcade/PC/Console
    amiga cd32
    32
    160
    123439
      voljega Banned @Ratte last edited by
      @ratte no need to justify yourself dude, I was just saying we hadn't seen you in a while to someone who wanted an answer on your cd32 integration, that's all 😉
      no problem of competition or anything either, it's just that I can respond for you on your part as I don't know it well at all
      • Dragu
        Dragu Banned last edited by
        @Ratte
        I suppose, you are german.. You know that In french your forum name sounds like a sort of patato 😉 Thanks for your job on this story.
        • Ratte
          German and potato goes well, their Frenchmen also drive all CV6, eat only baguettes, drink red wine with the baby bottle and seduce German women. That is the German-French friendship. Did I forget something? 😉
          •Raspberry Pi model: Pi ZeroW
          •Raspberry Pi model: Pi 3B @ 1350/500/500 MHz
          •Raspberry Pi model: Pi 3B+ @ 1550/500/500 MHz
          Dragu mrseguin 2 Replies Last reply Reply Quote 0
          • Dragu
            Dragu Banned @Ratte last edited by
            @ratte
            No, those who seduce german women are italian. 😉
            Ratte 1 Reply Last reply Reply Quote 0
            • Ratte
              Ratte @Dragu last edited by
              @dragu
              Ah, then it was the french women who seduced the german men ... 😛
              • DerSchatten
                DerSchatten last edited by
                Some Games Need a Second Button to works (Project-X, Xenon 2, ...)
                Is it possible to use it with a XBox Controller?
                • ejr
                  ejr @Ratte last edited by ejr
                  @ratte Yup, I've made those .cues before after conversion , but I made a mistake, as orignal .img files had .cues MODE1/2352. After changing that to 2048 it works now flawlessly 🙂
                  BTW: Is there ANY (other than F12 - my wireless keyboard doesnt have function keys) way to enter Uae4all gui or just stick to editing .cfg files to change ratio etc?
                  • Ratte
                    Ratte @ejr last edited by
                    @ejr said in AMIGA CD32 EMULATION - HOW TO -:
                    Enter the directory "share/roms/amigacd32/cds" inside you will find the text files:
                    ntsc_games.lst
                    ntsc_games_overscan.lst
                    pal_games.lst
                    pal_games_overscan.lst
                    You can enter your game (with .cue extension) in one of the four textfiles for a prefered screenratio.
                    Not listed games will automatically handeld like pal_games_overscan 😉
                    br
                    André
                    ejr 1 Reply Last reply Reply Quote 0
                    • Ratte
                      Ratte @DerSchatten last edited by
                      @derschatten said in AMIGA CD32 EMULATION - HOW TO -:
                      The xbox controller supports all (seven) cd32-buttons.
                      (red, blue, green, yellow, shoulder left, shoulder right & start/pause)
                      There is a picture at the beginning of this thread.
                      BR
                      André
                      • ejr
                        ejr last edited by
                        @derschatten all the cd32 buttons works on my pad and arcade stick works fine
                        DerSchatten 1 Reply Last reply Reply Quote 0
                          voljega Banned last edited by
                          No the mapping of the cd32 controller is completly broken, not all buttons work and some of them are crazy or duplicated, depending of the game
                          And this comes from amiberry's development team
                          • ejr
                            @ratte So, I checked overscan_pal.uae config file.. There are two entries that are interesting:
                            button_for_menu=-1
                            gfx_correct_aspect=0
                            Do anyone know how can I get corrent value for button menu and what is the correc value for the gfx aspect 4:3 ?
                            Can I use filters/masks like in winUAE?
                            • DerSchatten
                              DerSchatten @ejr last edited by
                              ok, but with which key I can select the extras in Project X ?
                              • ejr
                                ejr @DerSchatten last edited by
                                @derschatten First of all, make sure you configured your controller in recalbox menu, and selected it by name in P1 input. In my case it also matters - make sure your controller is plugged into rpi before you start the machine, not when it is already on. Then just check all the buttons 🙂
                                • Ratte
                                  Ratte @voljega last edited by
                                  @voljega said in AMIGA CD32 EMULATION - HOW TO -:
                                  No, thats not 100% true.
                                  It depends on the controller, with the XBox Controller (I use the Speedlink Torid in XBox-mode) you can use every button just like a real cd32 controller.
                                  https://www.youtube.com/watch?v=lP9uub-oyE0
                                  (My early testrun under retropie and later verified on recalbox ... all buttons identical to the testrun)
                                  But ... and thats the problem ... i used a fixed XBox-setting, becaus i dont know how to integrate a Emulator in emustation-scripts in a right way.
                                  (Still searching for a detailed "how-to", with all scripts and config-files.)
                                  BR
                                  André
                                  • DerSchatten
                                    @ratte said in AMIGA CD32 EMULATION - HOW TO -:
                                    Was meinst du mit fixed XBox-setting ?
                                    • Ratte
                                      The gamecontroller settings are hardcoded to an xbox-controller layout. This means, that PS3-controllers or other controllers might have a different layout or missing buttons.
                                      poumtaq 1 Reply Last reply Reply Quote 0
                                      • TotalRecall
                                        TotalRecall last edited by
                                        Marche au top même avec les dernières montées de version de Recalbox
                                        Merci pour ce super travail !
                                        Recalboxer novice qui ne demande qu'à apprendre (Rpi4)
                                        • retrocraze
                                          retrocraze last edited by
                                          What about Amiga 500/600/1200 emulation? Is this being added?
                                            voljega Banned @retrocraze last edited by
                                            @retrocraze
                                            https://github.com/Voljega/amiga4recalbox
                                            100.2k
