    AMIGA CD32 EMULATION - HOW TO -
    Emulator Arcade/PC/Console
    amiga cd32
    32
    160
    123593
    • Gwyllion
      Gwyllion @voljega last edited by Gwyllion
      @voljega Are you kidding me ? please avoid your messages not working. If you are not be able to work with, its your problem. Code has been modified to work with other controllers guy. Probably you need to see whats done to learn.
      @gaetan 😉 https://www.youtube.com/watch?v=Kgmt65ipv3c
        voljega Banned @Gwyllion last edited by voljega
        @gwyllion said in AMIGA CD32 EMULATION - HOW TO -:
        No it hasn't, it's a copy of Ratte's solution which is itself a slitghy modified copy of mine, please don't give me advice about code, especially when you're clearly not programming anything by yourself
        Your own video shows that not all buttons are supported and they are not placed well on the controller.
        Whatever... if @gaetan wants to continue losing his time...
        Gwyllion 1 Reply Last reply Reply Quote 0
        • Gwyllion
          @voljega first you say CD32 It works with amiga1200 games executed on CD32, not with CD32 games using all the buttons of the pad ....FALSE, after dont work with controllers as 8bitdo or PS3, only X360.... FALSE, I would like to know what is your dark intention not to say to the community that AMIGA CD32 is full emulated with others programmers with a modified code. You should lower your pride and admit it, if you can. Amiga CD32 I tested, Works fine.
          On the other hand, you should improve your code and help the community.
          Cheers.
          PS: No more answer to you, not worth it.
            I didn't exactly said that or maybe I didn't express myself well, what I meant is the controls for CD32 pad with this emulator are harcoded for xbox360 controller, this mean that for any other controller :
            • on a few controllers, it may work exactly the same if the controller works exactly like an x360 controller from linux point of view
            • in most case the buttons will be all randomly disposed on the controller, not mapped like a real CD32 pad at all
            • some CD32 buttons may be not reachable/activable at all
            Because once againt it isn't, all proves that this code works exactly the same like my old version from two years ago. For it to work, it would require an amiberry version from 2018 and newer than two months (anything older than that can not work because amiberry was bugged before).
            I know it because I wrote this code and I removed it from official integration because it was not working well.
            There is no dark intention except in your crazy head.
            Funny from someone who never participated in any way to recalbox code
            We can agree on that.
            • Ratte
              Ratte @Gwyllion last edited by
              @gaetan @gwyllion Please take care of the "cue" fix!
              Post 7 & 10
              Otherwise you cant play multifile games (cds with soundtracks).
              At the moment i compare the uae4arm with the amiberry-uae.
              There are some sweet updates since I released the cd32 addon.
              I will add a dtv64 emulator with the next addon-release.
              •Raspberry Pi model: Pi ZeroW
              •Raspberry Pi model: Pi 3B @ 1350/500/500 MHz
              •Raspberry Pi model: Pi 3B+ @ 1550/500/500 MHz
              • Gaetan
                Gaetan Theme moderator @Ratte last edited by
                @ratte Yes, the games I tried were multifiles with cds soundtracks as you described.
                I'm sorry, but I don't se what you're talking about "Post 7 & 10".
                Is there a new thing to add to the tutorial ?
                Are those steps the good one :
                Take this files: Amiga CD32
                mount -o remount rw /
                Copy lib, recalbox and usr from the file downloaded
                Inside /usr/bin/uaearm/ rename uae4arm-rpiX (X is RPI 2, 3, etc...) for uae4arm
                Copu from file downloaded etc/emulationstation/themes/recalbox to /recalbox/share_init/system/.emulationstation/themes/recalbox
                Add in /recalbox/share_init/system/.emulationstation/es_systems.cfg the following:
                <system>
                <fullname>AmigaCD32</fullname>
                <name>amigacd32</name>
                <path>/recalbox/share/roms/amigacd32</path>
                <extension>.iso .Iso .ISO</extension>
                <command>/usr/bin/uae4arm/scripts/start.sh %ROM%</command>
                <platform>amigacd32</platform>
                <theme>amigacd32</theme>
                <emulators>
                <emulator name="uae4arm">
                </emulator>
                </emulators>
                </system>
                Be sure you have all the permissions done:
                chmod 755 /usr/bin/uae4arm/uae4arm*
                chmod 755 /usr/bin/uae4arm/scripts/*
                chmod +x /lib/*
                Add .iso to /recalbox/share/roms/amigacd32
                Add the CORRECT BIOS to /recalbox/share/bios
                5f8924d013dd57a89cf349f4cdedc6b1 kick31CD32.rom
                bb72565701b1b6faece07d68ea5da639 CD32ext.rom
                • djtwok
                  djtwok last edited by
                  Cd32 Works great with the Amiga Emu which is provided with the official recalbox release (just press f12 change setting to cd32 and reboot after adding the bios files). My usb pad won’t work but keyboard and mouse does.
                  • Gaetan
                    Gaetan Theme moderator last edited by
                    @Ratte @Gwyllion did you also notice that amiga cd32 is working just as it's mention by @djtwok ?
                    • Ratte
                      dtv64-addon available
                      https://forum.recalbox.com/post/100467
                      next level - cd32 optimization
                      Ratte 1 Reply Last reply Reply Quote 1
                      • Ratte
                        Ratte @Ratte last edited by Ratte
                        new theme - preview
                        • Secamfr
                          Secamfr last edited by
                          @Ratte nice!
                          • Gaetan
                            @ratte Great ! I hope it can be officialy be a part of Recalbox 🙂
                            • Ratte
                              controller & console
                              going to be a svg-artist ....
                              • Ratte
                                theme preview recalbox & recalbox-next
                                • Secamfr
                                  @Ratte Great theme !
                                  • MilesCW
                                    MilesCW last edited by
                                    Looking forward to it too. Keep the good work up.
                                    • Alex_123
                                      Alex_123 last edited by
                                      Hi,
                                      I have been testing this guide on my Raspberrt Pi3b+ with Racalbox Pi3b+ beta and It didn't work to me.
                                      When I add:
                                      <system>
                                      <emulators>
                                      </emulator>
                                      </emulators>
                                      </system>
                                      in /recalbox/share_init/system/.emulationstation/es_systems.cfg then Recalbox doesn't start, if I remove those lines from the file then Recalbox starts fine. Someone have tested this emulator over a Raspberry 3b+ with latest Recalbox beta? Thanks!!!
                                      • djtwok
                                        Any news about this ? Will cd32 be included in future releases of recalbox ?
                                          voljega Banned @djtwok last edited by
                                          @djtwok yes when we upgrade amiberry version
                                          • Arabianknight
                                            Arabianknight last edited by Arabianknight
                                            Hi,
                                            I have the rgb-pi recalbox build. Everything is working fine except for amiga when launching the amiga UI (F12). I am getting the UI in weird unreadable resolution. Anyone can help?
                                            alt text
                                            Thanks
                                            100.2k
