    [SOFT] Universal XML Scraper V2
    Community projects
    [soft] universal xml scraper
    112
    670
    921622
    • sassa
      sassa @screech last edited by
      @screech said in [SOFT] Universal XML Scraper V2:
      @sassa
      effectivement j'ai des merdouilles avec le resize automatique.
      Merci pour les exemples, comme ça je vais pouvoir gerer le truc 😉
      De rien 😉 j'ai pas testé les autres consoles donc je sais pas si ça fait pareil j'essayerais tout à l'heure
      • lackyluuk
        @screech do you wanna use the formal "You" or the informal in the german translation?:)
        • screech
          @lackyluuk I don't know ^^ I use the "vous" in french 😉 don't know what it is in german ^^
          • lackyluuk
            lackyluuk Translator last edited by lackyluuk
            @screech Vous is then "Sie" and I think Toi is the informal like "Du" 😄
              paradadf Staff @lackyluuk last edited by
              @lackyluuk @Madmeggo sent me his german translation and I made the PR:
              https://github.com/Universal-Rom-Tools/Universal-XML-Scraper/pull/19
              • screech
                Arg, sorry @lackyluuk
                Don't know @Madmeggo work on German translation too...
                Is it OK for you ? I accept the PR... Let me know if you thing you are disagree with some tranlsation.
                (Thank you @paradadf for the PR...)
                • Madmeggo
                  Madmeggo last edited by
                  I didn't really ask for "official permisson". I just told @paradadf that i can and would like to translate the new scraper version, after i used it and noticed that the german translation was missing. I didn't even know about this thread. I hope the translation is okay with you guys. And i would appreciate if @lackyluuk would check it too!
                  I'm really sorry if i "interfered" with someone...
                  • screech
                    No problem @Madmeggo
                    UXS is an open source project, every one is welcome to participate (even if AUTOIT dev are pretty rare ^^ )
                    And I haven't "communicated" about @lackyluuk started the German translation ^^
                    (And I still looking for Spanish, and Portuguese/Bazilian translator ^^)
                    • Madmeggo
                      Phew, okay @screech . I hope i didn't make mistaktes, and translated everything the correct way.
                      • screech
                        If there is mistake, I can't tell you ^^ I don't speak a word of German...
                        (The last sentence I remember from school is "Du bist ein esel" and me proodly answering "Entschuldigung" ^^)
                          paradadf Staff @screech last edited by
                          @screech I'm on it (spanish)
                          • Madmeggo
                            @screech So you do speak a few word's of german 😉
                            Then let's hope @lackyluuk won't find a mistake 🙂
                            • lackyluuk
                              @Madmeggo @paradadf @screech haha, no prob lads. I started today and just wanted to finish my translation. Fortunately I had a look into the wiki first. 😉
                              Thanks @Madmeggo. I found one, two typos. Is it possible to correct them directly on the github master? The rest seems okay. I will have a closer look tomorrow.
                              @screech your german is nice 😄 I hope u know what a Esel is 😄
                              • screech
                                Now yes 😉 (thank you google translate ^^)
                                For editing directly on Github, I can with my account... don't know if you can... Maybe with an account ^^ (I uncheck "Restrict editing to collaborators only" so maybe you can now ^^)
                                • Madmeggo
                                  @lackyluuk that what @screech said! "Das was Screech gesagt hat"
                                  Ich habe eigentlich gar keine Ahnung wie die ganze Github-Sache funktioniert. Ich hab die XML einfach mit Notepad++ geöffnet, losgelegt und @paradadf dann mein "Exemplar" geschickt.
                                  Einfach einen Fehler korrigieren wenn du einen gefunden hast 🙂
                                  Meine Konzentration lässt in letzter Zeit etwas zu wünschen übrig. Daher kann es gut sein dass ich was übersehen habe. Und manche Dinge waren auch nicht ganz zu verstehen, weil das Englisch noch nicht hunder pro ist. Ich hoffe ich habe den Sinn von allem so weit eingefangen
                                  • lackyluuk
                                    @screech I have an account 🙂 I'll give it a try tomorrrow.
                                    @Madmeggo alright 🙂 Hab auch nicht so ahnung davon 😄 Ich übersetze das Wiki zurzeit und kenne ein paar Sachen davon. Okay, ich schaue es morgen mal genauer an. Hatte heute auch ein paae Begriffe überhaupt nicht verstanden, aber mit deinem Input siehts schon sehr gut aus.
                                    • Madmeggo
                                      Madmeggo last edited by Madmeggo
                                      Super! 🙂
                                      Edit: @lackyluuk Oh man. Wie unhöflich von mir. Ich kann und werde natürlich selbst mal nach meinen Tippfehlern suchen. Das meinte ich mit meiner Konzentration und meinem Kopf ... Kaum zu gebrauchen ... 😄
                                      • 8bit_astronaut
                                        8bit_astronaut last edited by
                                        how can i update some .xml files?
                                        For example, for snes i had a lot of favorites, but i downloaded a lot of new games that i want to scrap, i dont want to delete the old .xml file, how can i update it?
                                          paradadf Staff @8bit_astronaut last edited by
                                          @8bit_astronaut just choose to update de XML file instead of creating a new file. In general configuration I believe.
                                          • screech
                                            @8bit_astronaut yes, @paradadf is right 😉
                                            Just go to general configuration, and in "scrape mode" choose "update XML File (with new rom)" and scrape 😉
                                            It will just add Rom that are not in the XML...
                                            8bit_astronaut 1 Reply Last reply Reply Quote 0
