    Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...)
    Testers's corner
    testers wanted major upgrade pi3b
    198
    805
    919766
    • Gaetan
      Gaetan Theme moderator @darksouljedi last edited by
      @darksouljedi Here is the wiki, you may find your answer there 😉
      https://github.com/recalbox/recalbox-os/wiki/recalbox.conf-(EN)
      darksouljedi 1 Reply Last reply Reply Quote 0
      • Juakin
        Juakin last edited by
        I tries to update the beta version and it crashed horribly, then everytime I tried to launch recalbox I obtained a black screen with a few lines of error...
        I want to try and reinstall Recalbox again but I want to make a Multiboot system (NOOBS) the problem is that Network install it's not working... It says somthing like It can't find the file on the server...
        Could this issue be solved?
        PD: I'm using the latest NOOBS that incluided Recalbox.
        • olivierdroid92
          @Juakin
          The easiest way to try a BETA version is to make some run and trials from a fresh copye image. I do not think a dual boot will be a good option.
          • Juakin
            I understand that, but I would like to restablish the non beta version, but It doesn´t seems to download from NOOBS, it can't reach the server... It seems the file is unavailable 😞
            • BertL1005
              BertL1005 last edited by
              When is the stable version for pi 3b+ ready to download ??
              • Gaetan
                Gaetan Theme moderator @BertL1005 last edited by
                @bertl1005 Not yet, wait and see 🙂
                • daz
                  daz last edited by daz
                  hi ive tried this image & when i try to load games from a memory stick it try's to load then just goes back to the main screen is anyone else having the same problems from external memory
                  • Gaetan
                    Gaetan Theme moderator @daz last edited by
                    @daz did you remap your controller ?
                    daz 2 Replies Last reply Reply Quote 0
                    • darksouljedi
                      darksouljedi @Gaetan last edited by
                      @gaetan
                      thanks for the link. But it only explain how to activate the GPIO map.
                      I want to change the GPIO map
                      I try this in recalbox.conf
                      controllers.gpio.args=map=5
                      And in mk_arcade_joystick.conf
                      options mk_arcade_joystick_rpi map=5 gpio=13,19,26,21,22,20,16,12,6,27,6,17
                      but the nothing works after rebooting recalbox.
                      Thanks for your help
                      • vdeolive
                        vdeolive @shinomen last edited by vdeolive
                        @shinomen hello.i would like to do the same configuring 2P with my pandora box. I can only have 1p configuration. How did you do please? If i enable x-arcade mode in recalbox.conf, it will works on pandora? Thx
                        shinomen 1 Reply Last reply Reply Quote 0
                        • shinomen
                          shinomen @vdeolive last edited by shinomen
                          @vdeolive
                          I have found that there is not much you need to do with recalbox to make pandora box arcade controller work. If you have a fresh image that you write to the SD card and then boot raspberry pi, you will then configure your player 1 controller from the controller settings > configure a controller. Then after you have finished and saved that, go back into controller settings > configure a controller, and this time hold one of the buttons on the player 2 side so it detects it and takes you to the controller configuration screen. Then configure all the buttons you want with that player 2 controller and save.
                          One issue I ran into with configuring the pandora controller was that my player 2 "select" button was not recognized when I try to configure it. So instead I assigned player 2 select to the button in the back of the controller that allows you to get to the exit menu typically when running the pandora box software.
                          After both players were configured, everything just worked.
                          vdeolive 1 Reply Last reply Reply Quote 0
                          • daz
                            daz @Gaetan last edited by
                            @gaetan hi yes i have remapped my controller it also forgets the wifi after resetting the pi its as if your using external memory it forgets everything after a reboot
                            • Choum
                              Choum last edited by
                              Wifi do not reconnect after reboot (you have to retype the password everytime and remove the enc one).
                              Internal Bluetooth frequent disconnect, or massive lag on 8bit do nes 30 pro (SF 30 pro seems to work normally).
                              tested on 3b + with the img on first post.
                              • vdeolive
                                @shinomen thanks
                                • Jayah
                                  Jayah last edited by
                                  @choum said in Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...):
                                  Salut !
                                  Exactement le même souci que @Choum avec le wifi et la manette 8bitdo nes30 pro v2 (firmware 4.1).
                                  Concernant le wifi, nul besoin de retaper le code mais juste désactiver puis réactiver la connexion. C'est pénible mais cela fonctionne. Pour la manette je n'ai pas trouvé comment améliorer la stabilité et cela m'embêterait d'avoir à utiliser un dongle BT...
                                  Bye et merci pour vos projets 😘
                                  • Phil333
                                    Phil333 last edited by
                                    I just wanted to tell you that I tested the image on my Pi3B+ and it booted and the original PS3 sixaxis controller works.
                                    I got a message that there is an update availble (249MB) which I did.
                                    After that it rebootet and showed the same message - and I also did the update (again 249MB... maybe the first update was unsuccessfull or it were really 2 updates with the same size).
                                    After that update the Pi3B+ just boots with a black screen and does nothing.
                                    Maybe someone else have the same issue.
                                    • Gaetan
                                      Gaetan Theme moderator @Phil333 last edited by
                                      @phil333 you need to edit your recalbox.conf as it said in the first post
                                      • MeisterP
                                        MeisterP last edited by
                                        Hi,
                                        the PI3 B+ release runs very well when using a PS3 controller (tested with the cable).
                                        Unfortunately I have problems when using my X Box controller (with USB cable). The DPAD often stops working during the gameplay (SNES - Mario Kart/F-Zero). Using the analog stick is OK.
                                        Hope you can fix it.
                                        Cheers
                                        • outlaw77230
                                          outlaw77230 last edited by
                                          Petit retour pour ma part avec mon pi3:
                                          • Obligé d'eteindre et d'appairer ma 8bitdo sf30 pro a chaque lancement de jeu (mais je crois que ce soucis a déjà été remonté)
                                          • Bug "manette" avec certains jeu. A croire qu'on reste bloqué sur des boutons de la manette
                                          • Difficultés d'utilisation du clavier virtuel Amstrad, c64, etc. Les touches ne se valident pas
                                          • Plus de musique avec mes jeux doom dans le système Prboom alors que l'arborescence de mes fichiers est bonne
                                            Désolé je n'ai pas de compétence Linux. Je peux seulement vous rapporter mes problèmes
                                          Boards : Rpi3 B - µSDHC SanDisk 16go classe 10
                                          Power supply: Aukru 5v 3a
                                          Storage: HDD Maxtor 2to + hub USB
                                          Controllers : 8bitdo SFC30 Pro
                                          Case: Retroflag SuperPi Case
                                          simba51 1 Reply Last reply Reply Quote 0
                                          • simba51
                                            simba51 @outlaw77230 last edited by simba51
                                            @outlaw77230
                                              Solution : Le répertoire "game-musics" contenant la musique pour chaque ".wad" de prboom est à mettre dans le dossier "save/prboom" de chaque jeu ".wad". Copier également le "prboom.cfg" dans chaque dossier de sauvegarde de vos "*.wad". J'ai eu le même problème et j'ai fait ainsi pour avoir les musiques respectifs de doom et doom2, etc...
                                            Cartes RPi Zéro 2 W - RPi Zéro W - RPi400 - RPi 4/4Gb - RPi 3b - RPi 3b+ - RPi 3 a+
                                            Stockage 16Gb Sandisk, 32Gb Samsung et clé usb 64Gb & 128Gb
                                            2 manettes PS3 Freegun Bluetooth - 2 manettes 8BitDo SF30 Pro Bluetooth
