    Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...)
    Testers's corner
    testers wanted major upgrade pi3b
    198
    805
    919754
      Substring @MarbleMad last edited by
      @marblemad nothing you mentionned is new to this beta 😄
      @james-lord no one said their was any improvements on the xbox one controllers. If you want to give it a try, see here
      @mariob no idea for that kodi problem
      @Choum no you can't switch back to stable, changes are way too diffferent. That's why i said one must use a dedicated sd card
      @Alex_123 i'm not sure the gamesir 3gs ever worked. Does it work fine on the stable ? For the RA settings, some are overwritten at each new launch. I don't think there is any change between the stable and the beta here
      james-lord 1 Reply Last reply Reply Quote 0
      • james-lord
        james-lord @Substring last edited by
        @substring Thanks for your help in the Discord, I now have one of the xbox one pads up and running.
        • Choum
          Choum last edited by
          The md5 verification on the webpage (bios tab) for ATARIOSA.ROM
          eb1f32f5d9f382db1bbfb8d7f9cb343a do not work.
          • Injall
            Injall last edited by
            La PSP ne fonctionne absolument pas. Voici le fichier : https://file.ac/HCaQA0otHqA/
            Cartes : RPI3b, RPI3b+, Tinker ASUS, Odroid XU4
            • JOBARE
              JOBARE last edited by JOBARE
              Hi.
              Thank's for your work.
              Since the recalbox 4.1, BlueMsx core had been patched to map F1/F2/F5 keys on the first gamepad.
              It seems that we lost keys mapping.
              I tested applying following commits as indicated :
              1st update (fix): https://review-master-slwsz0-archive-review-prod.recalbox.com
              2nd update (master of Pi3b release) : https://review-507-b*mp-b-0jn0c0-archive-review-prod.recalbox.com
              I notified this issue as comment on last Gitlab merge dedicated to fix recent BlueMsx core problem : https://gitlab.com/recalbox/recalbox/merge_requests/385
              Could you please have a look before releasing stable version ?..
              Thank's !.
              • vdeolive
                vdeolive last edited by vdeolive
                Hello,
                I am testing recalbox distribution (507-b*mp-bui (fafba916) 28566561 rpi3 2018/08/23) on pi3+ with kintaro super ursus case & 8bitdo SFC30Pro which works pretty well for a upgraded reproduction of my beloved 26 years Snes.
                1. Rom Suppression
                  I would like to mention for a potential improvement when you try to suppress a rom directly from the menu (through editing game information/suppress), it crash the recalbox. It would be helpful to find a way to simplify rom suppression through one button (with confirmation) as we do to mark favorites games. Today for each suppression you have to do several menu manipulations to suppress the rom and its time consuming when you try to clean a romset. Its just an idea.
                2. 8bitdo SFC30 Pro : Mapping is not saved
                  Trying to remap the gamepad, mapping is not saved everytime you reinitiate the recalbox. hotkey is not working even if you use the 8bitdo button (bottom right) or you map it on select. Start+Select exit dosn't works as well For example in NES emulator (with SMB1), you can't open Retroarch menu to set the shaders or exit of the game. You have to reset the console.
                3. 8bitdo SFC30 Pro : Input lag
                  As well i still have light input lag on SFC30Pro with internal bluetooth which is enough for RPG games but for Mario / SFII turbo millimeter gameplay its still not satisfying (i've ordered a BT dongle on the recalstore to try to fix that)
                I continue deepdiving on pi3+ test.
                thx for the work by the way!
                Regards
                joinski Gaetan 2 Replies Last reply Reply Quote 0
                • vdeolive
                  +1
                  1. Kintaro SuperUrsus Case Power/Reset/Fan Scripts
                    And if there's any way to integrate the safe power/ reset / fan scripts to pilot super ursus case inside the next distribution, could be wonderful. (I can share them with you coming from mirefly thread on this forum /michael kirsch files).
                  https://github.com/MichaelKirsch/KintaroSnes
                  Thx
                  • joinski
                    joinski @vdeolive last edited by
                    @vdeolive said in Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...):
                    1. 8bitdo SFC30 Pro : Input lag
                    Regarding input lag, you could try to use the Run-Ahead feature of RetroArch. But due to the lack of performance of the Raspberry Pi, you should overclock it a bit and deactivate Rewind-Function.
                    • Gaetan
                      Gaetan Theme moderator @vdeolive last edited by
                      @vdeolive
                      First thing to do is desactivate wifi on your pi , you'll see a significant difference with your input lag
                      joinski 1 Reply Last reply Reply Quote 0
                      • joinski
                        joinski @Gaetan last edited by joinski
                        @gaetan said in Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...):
                        @vdeolive
                        I would suggest to use a dedicated bluetooth-dongle anyway.
                        Because with my Pi3 even with disabled wifi i noticed a minimal delay.
                        With a bluetooth-dongle the delay was gone. Also the range is way better.
                        But this also depends on the bluetooth-dongle, because i once had a dongle, where the range was bad and it also felt like there was lag.
                        • Gaetan
                          Gaetan Theme moderator @joinski last edited by
                          @joinski In my experience I can't say if a BT dongle will help, but some says yes so you could give it a try if you have one.
                          Anyway, with BT you'll always have latency, the only way to avoid it is to use wired controller.
                          • joinski
                            @gaetan
                            Under some circumstances bluetooth can have less input lag, then wired connection, see here:
                            https://www.reddit.com/r/RocketLeague/comments/8wvf9u/controller_input_lag_comparison_more_info_in_the/
                            But as already mentioned, it depends of the BT-Dongle, some are better, some ar worse.
                            It also depends of the used Controller. Some Bluetooth-Controllers do have more and some have less input-lag.
                            8bitdo Controllers for example (but there was a firmware-upgrade released, which reduced the input-lag a bit).
                            • mamouchka9
                              mamouchka9 last edited by
                              Hi everybody,
                              I have this problems with the beta running on Rpi3 B+:
                              • No sound on background music in menu (Pop-up appears while playing a song, in game sound and music is working...in HDMI)
                              • Global speed is very slower when using the composite output: sound and video are very slow but "works", no weird things in the video or audio signal (@3fps it's not esay to say)
                              • Wifi connection doesn't launch at start, have to manually shutdown and reboot wifi (not a big deal for me)
                              Everything else works great in HDMI with a PS4 wired controller.
                              --> If somebody has a plan to make the speed back with the composite output it would be great !
                              Substring james-lord 2 Replies Last reply Reply Quote 1
                                Substring @mamouchka9 last edited by
                                @mamouchka9 hdmi sound : it does work, but you can force it
                                Sluggish on composite video : edit config.txt and remove the audio_pwm_mode (inmay have scrambled the words)
                                • james-lord
                                  james-lord @mamouchka9 last edited by
                                  @mamouchka9 I also have the reboot for wifi issue on my pi 3+ for me it is an annoyance as I@m using a NESpi case and iot looks awful with the flap open to use the ethernet port
                                  • james-lord
                                    james-lord last edited by
                                    ALso as an update for anyone trying to get he xbox one pad to connect wirelessly: don't bother trying Microsoft deliberately (?) broke non official pairing in the last update stating it was a bug that it had happened in the first place!
                                    • Choum
                                      Is it possible to force 5Ghz wifi on a 3+ with this beta ?
                                      • shinomen
                                        shinomen last edited by
                                        Used Rufus on windows to write image to SD card. Connected x-arcade tankstick and started raspberry Pi 3B+ and got booted out of games I would try to load. Re-mapped controller using controller settings > configure a controller and still has issues.
                                        Connected a pandora arcade controller and ran the 'configure a controller' and had no problems loading games. Link to device below
                                        (https://www.amazon.com/gp/product/B06Y61WDG3/ref=oh_aui_search_detailpage?ie=UTF8&psc=1)
                                        I'm assuming this is an issue with the x-arcade tankstick but I figured I would bring it up. I have attached a link for the support file. If I need to do anything to test let me know.
                                        Raspberry Pi model: 3b+
                                        Recalbox version (build) : Beta Version
                                        Hardware (Micro SD, Power Supply, etc.): 32GB Samsung, CanaKit 2.5Amp Power Supply
                                        Controller(s): x-arcade tankstick (https://www.amazon.com/gp/product/B000ST0184/ref=oh_aui_search_detailpage?ie=UTF8&psc=1)
                                        Support File:
                                        https://file.ac/JF-UkTVBDwQ/
                                        shinomen 1 Reply Last reply Reply Quote 0
                                        • shinomen
                                          shinomen @shinomen last edited by
                                          @shinomen Well that didn't take long. I had configured only player one on my x-arcade stick. I got the great idea to go ahead and configure both player 1 and 2 and low and behold it's working! Sorry but thanks. 🙂
                                          vdeolive 1 Reply Last reply Reply Quote 0
                                          • darksouljedi
                                            darksouljedi last edited by
                                            hello great job, I update to this version.
                                            I want to have custom GPIO.
                                            Can you send to me how to configure recalbox.conf ?
                                            Thanks
