    Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...)
    Testers's corner
    testers wanted major upgrade pi3b
    198
    805
    919731
    • janbaunooo
      janbaunooo last edited by
      Hi,
      I'am on ""RB EMULATIONSTATION V 507-B*MP-BUI (FAFBA916) 28566561 X86_64 2018/08/23 22:32:26" and after setting updates.type=https://review-507-b*mp-b-0jn0c0-archive-review-prod.recalbox.com in recalbox.conf i'm unable to update, in recalbox.log i've this message :
      [ 186.04] ------------ Will process to a https://review-507-b*mp-b-0jn0c0-archive-review-prod.recalbox.com upgrade ------------
      [ 186.15] Unable to get headers for http://archive.recalbox.com/updates/v1.0/https://review-507-b*mp-b-0jn0c0-archive-review-prod.recalbox.com/x86_64/boot.tar.xz
      And I've double check : in recalbox.conf i've this line updates.type=https://review-507-b*mp-b-0jn0c0-archive-review-prod.recalbox.com
      Problem similar if setting updates.type to https://review-master-slwsz0-archive-review-prod.recalbox.com
      tonificante 1 Reply Last reply Reply Quote 0
      • janbaunooo
        No sound on HDMI output until I unmute SPDIF on alsamixer (TERM=xterm alsamixer).
        • tonificante
          tonificante @janbaunooo last edited by tonificante
          @janbaunooo maybe you still have enabled the standard update line? check if you still have this line:
          updates.type=stable
          and if so, then put a # as the first char of the line, to comment it out:
          #updates.type=stable
          By the way, I think the version you have is already the last one, so you won't get any update at this moment anyway.
          • janbaunooo
            @tonificante I've checked and there are no other updates.type line.
            I have a doubt about my test procedure: because it was more convenient, no need to restart with each change, I assumed that executing the /recalbox/scripts/recalbox-upgrade.sh script was doing the same thing as the automatic update check ... but by reading the script content, I don't see how it could work by specifying a URL instead of the update type.
            @Substring Thanks for your works, outputs by HDMI work well now on my hardware 😉
            • Carlos Calixto
              Carlos Calixto last edited by
              me lanzo a una nuieva version del sistema y al reiniciar no arrancó ¿soy al unico que le pasa esto?
              • Gaetan
                Gaetan Theme moderator @Carlos Calixto last edited by
                @carlos-calixto in english please 🙂
                • xavier83bruno
                  xavier83bruno last edited by
                  @substring i have download the img, work fine on pi3 b+, but it s says i have a new update, if i install this update, my pi3 b+ doesnt run.
                  If i connect a Bluetooth controller ( wii mote with classic controller) i can move on menu of emulstation, but no games run.
                  cazeysan 1 Reply Last reply Reply Quote 1
                  • cazeysan
                    cazeysan @xavier83bruno last edited by
                    @xavier83bruno
                    @substring said in Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...):
                    Time to thril
                    You need to edit your recalbox.conf and set updates.type to:
                    1. First update with: https://review-master-slwsz0-archive-review-prod.recalbox.com
                    2. Then update with https://review-507-b*mp-b-0jn0c0-archive-review-prod.recalbox.com
                    A pi3 SD card works on a Pi3b+. Though, I know some people don't have a pi3 anymore, so here is a direct link to the img file. There is no need to make any upgrade on this img, but still, set the updates type to the 2nd link to get updates during the beta. If you update while on the stable branch, you'll simply brick your Recalbox. Now you're warned. I'm pretty sure some smart @$$ will spread this image forgetting its beta state, those people are making a big mistake.
                    Viens par là, c'est pareil !
                    • glukkkk
                      glukkkk last edited by
                      Does anybody know about the RetroFlags' NesPi safe shutdown script? https://github.com/RetroFlag/retroflag-picase Is it compatible with the current upgrade or it is need to be updated?
                      • Gaetan
                        Gaetan Theme moderator @glukkkk last edited by
                        @glukkkk https://forum.recalbox.com/topic/15159/tutoriel-fr-en-installer-le-script-safe-shutdown-pour-nespi-case-et-superpi-case
                        glukkkk 1 Reply Last reply Reply Quote 1
                        • cyberbad
                          cyberbad last edited by cyberbad
                          Bonjour, et merci pour cette beta
                          I'm using Recalbox x86x64
                          I have a problem with my 8bitdo nes30 controler and asus bt400, it's working great but when i start a game the controler not working anymore i have to poweroff and on the controller for be recognize again
                          https://file.ac/5KuSzciRpJE/
                          thank for your time
                          • glukkkk
                            glukkkk @Gaetan last edited by
                            @gaetan Merci!
                            • Gaetan
                              Gaetan Theme moderator @cyberbad last edited by
                              @cyberbad did you remap them ?
                              • cyberbad
                                @Gaetan did you mean on each game or remap on the main menu , I remap it on the main menu it's still same
                                but the controller working only if i poweroff and poweron it. iwill try on the emu thx
                                Franc-Boisier 1 Reply Last reply Reply Quote 0
                                • diamantis42
                                  diamantis42 last edited by diamantis42
                                  hello,
                                  I have install the first beta on my rpi 3b+ all works but I have update and black screen with yellow lightning
                                  after new freshly built image on a Pi3b+
                                  • wifi is now really unstable, no problem in ethernet (the unstable wifi connection already mentioned, I know 😉 ) I have both wifi AC and N
                                  • my 8bitdo pad(sf30 ans sn30) in bluetooth works in game but in emulstation stop randomly, I need to stop it and restart
                                  • I can't access in SSH (rpi3B+ wifi or ethernet)... but I can acces via web broswer
                                  • schlegel11
                                    schlegel11 last edited by
                                    Hi,
                                    so far recalbox runs really good on my pi3b+.
                                    But i found a small bug related to recalbox.conf.
                                    When I uncomment "system.power.switch=PIN356ONOFFRESET" everything works.
                                    It looks like this:
                                    ;system.power.switch=PIN56PUSH # https://github.com/recalbox/recalbox-os/wiki/Add-a-start-stop-button-to-your-recalbox-(EN)
                                    system.power.switch=PIN356ONOFFRESET # https://github.com/recalbox/recalbox-os/wiki/Add-a-start-stop-button-to-your-recalbox-(EN)
                                    ;system.power.switch=PIN356PUSHRESET # https://github.com/recalbox/recalbox-os/wiki/Add-a-start-stop-button-to-your-recalbox-(EN)
                                    But when I restart the pi and open the conf again all lines are replaced by the uncomment line like:
                                      paradadf Staff @schlegel11 last edited by
                                      @schlegel11 that‘s an old known bug... it doesn‘t affect the functionality of the script though.
                                      schlegel11 1 Reply Last reply Reply Quote 0
                                      • schlegel11
                                        schlegel11 @paradadf last edited by
                                        @paradadf
                                        Thats true it doesn't affect it
                                        • Franc-Boisier
                                          Franc-Boisier @cyberbad last edited by
                                          @cyberbad Hi, i've the same problem ... Have you finded an issue ?
                                          Board(s) : Rpi 3 B+
                                          Controller(s) : 8bitdo SFC30 pro
                                          • tombhadAC
                                            tombhadAC last edited by tombhadAC
                                            It seems the hashlib function of kodi/python does so work, so a lot of addons and when you index your Music Collection it crashes. (then it does not start anymore without deleting .kodi)
                                            automatically obtained id of "plugin.video.youtube" dependent on version 2.20.0 of the xbmc.python api
                                            16:45:42.187 T:1589834720 ERROR: ERROR:root:code for hash md5 was not found.
                                            Traceback (most recent call last):
                                            File "/usr/lib/python2.7/hashlib.py", line 147, in <module>
                                            globals()[__func_name] = __get_hash(__func_name)
                                            File "/usr/lib/python2.7/hashlib.py", line 97, in __get_builtin_constructor
                                            raise ValueError('unsupported hash type ' + name)
                                            ValueError: unsupported hash type md5
                                            16:45:42.187 T:1589834720 DEBUG: .
                                            16:45:42.188 T:1589834720 ERROR: ERROR:root:code for hash sha1 was not found.
                                            ValueError: unsupported hash type sha1
                                            and so on ...
                                            Also it seems the Steam Controller is not working at current stage.
