    Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...)
    Testers's corner
    testers wanted major upgrade pi3b
    198
    805
    919713
    • Michael Baudino
      Michael Baudino Staff last edited by
      @Substring Not sure if it's the best place to post it but I had to make some changes to be able to build the image from scratch. I submitted this merge request against your branch.
      • VoSed
        VoSed @VoSed last edited by
        Not helped
        • VoSed
          Also if I choose "Reboot" in ES, ES just close
          • wilfrid
            wilfrid last edited by
            Hello,
            I downloaded and installed the beta2 image on a fresh SD, mapped my Xbox 360 pad (wired) and configured the wifi.
            Couple of observations :
            • the wifi connection is unstable. Sometimes it can't connect to my box (freebox) and sometimes it "loose" the connectivity : it's kinda frozen and then unfreeze after 10 or 20 seconds. (my wifi connection was working fine with pi3)
            • the wired connection via ethernet is stable
            • via the windows 10 file explorer, when I try to access \recalbox (or directly the ip \192.168.0.44), the folder list is empty. It doesn't show me the share & roms folders
            • I can access http://recalbox via my browser but I can upload only small files into the rom folders, so when I try to upload big roms via a sftp connection (client = WinSCP), the upload fails randomly (sftp error, bad packet), both in ethernet and wifi connection.
            • Clock speed : it shows 1200 MHz and not 1400 MHz as expected
            • Memory : it shows a total of 495 MB instead of 1 GB of RAM
            Next round : I'll test some emulators.
            tonificante 1 Reply Last reply Reply Quote 0
            • CedrickM
              CedrickM @Substring last edited by
              @substring Hello substring, i'm just trying to install the recalbox on my raspberry Pi 3 B+ for 15 days without success...i'm desesperate !!!
              I discovered your tutorial but i've got a problem, the We transfer Pi3/cm3/pi3b+ img link is no more availlable, and after reading all the posts of the 15 last days i access, i did not find the link. Is is possible to reactivate it. i found differents files types of recalbox 4.000 beta 6 but each time i expand files and copy them on the sd card, the start screen of the rpi3pb+ stay rainbow colored...So perhaps with image files it will work... Thank you for your answer
              Cedrick
              • Gaetan
                Gaetan Theme moderator @CedrickM last edited by
                @cedrickm Find the beta here : https://mab.to/iNoBCIih0
                Then flash it on your sd with Echter or Win32DiskImager , not just copy it.
                CedrickM 1 Reply Last reply Reply Quote 0
                • Franc-Boisier
                  Franc-Boisier @Franc-Boisier last edited by
                  @franc-boisier I tried again yesterday, but nothing works, someone has an idea?
                  Board(s) : Rpi 3 B+
                  Controller(s) : 8bitdo SFC30 pro
                    OyyoDams Staff last edited by
                    Direct download links updated on 1st post
                    Suriv mi7chy 2 Replies Last reply Reply Quote 1
                    • Suriv
                      Suriv @OyyoDams last edited by
                      @oyyodams
                      Thanks for the info.
                      Will it be notified when the image is updated?
                      Franc-Boisier 1 Reply Last reply Reply Quote 0
                      • Franc-Boisier
                        Franc-Boisier @Suriv last edited by
                        @suriv
                        Recalbox warns you when an update is available. However, it is true that it would be nice to know the version of the proposed image ...
                        Board(s) : Rpi 3 B+
                        • CedrickM
                          CedrickM @Gaetan last edited by
                          @gaetan Thank you so much for your answer Gaetan, it is the first time for 2 weeks i manage to see the screen of recalbox on my RPi3B+ !!. Just two questions. As i 'm working with 3B+ version, is it possible to update the recalbox version to the last one ( normally i've readen it doesn't work...).Why when i strictly follow the recalbox tutorial (unpack the 4.000 beta 6 version) and copy the extracted files in the root of my sd card, it doesn't work). Because they say copy and no flash. That's why i've asked for help to obtain an image file. In the image you gave me, which version of recalbox it is ? I thank you for your answers and your patience, i'm novice as you can see, but i want to understand my mistakes.
                          Cedrick M.
                          • Gaetan
                            @cedrickm No problem 🙂
                            Yes, you can update your Recalbox to the last version following thos instruction :
                            You need to edit your recalbox.conf and set updates.type to:
                            https://review-507-b*mp-b-0jn0c0-archive-review-prod.recalbox.com
                            and then reboot
                            CedrickM 2 Replies Last reply Reply Quote 0
                            • CedrickM
                              @gaetan Hello thnk you for your answer, but i need some explanations, what do you mean by "You need to edit your recalbox.conf and set updates.type to:
                              Thank you
                              • mi7chy
                                mi7chy @OyyoDams last edited by
                                @oyyodams
                                Noticed the checksum is different from beta2 full image so thought maybe it's a new beta3 full image. Decided to give it a try but it's dated the same 8/23/2018 and still have issues with atarist roms no longer working. Looked into it some more and the roms that no longer work are .ipf extension. Tried a .st rom and it worked so the issue seems to be restricted to .ipf only. Have proper tos.img BIOS installed, es_systems.cfg reference extensions .ipf .IPF and required capsimage library files are present. Anyone have any suggestions on what else I can check?
                                • tonificante
                                  tonificante @wilfrid last edited by tonificante
                                  My version: "RB EMULATIONSTATION V 507-B*MP-BUI (86B655AC) 28480032 RPI3 2018/08/22 22:54:50"
                                  My errors:
                                  • the unstable wifi connection mentioned by user wilfrid.
                                  • when I update the gamelist, it hangs somehow at the end of the process. When I reboot or switch off from recalbox, it hangs almost always and then I have to do soft reset or soft switch off by using a raspberry pi app from my smartphone that sends a reboot or shutdown signal.
                                  • when I copy a snes rom through samba network and reboot raspberry using my app, then I lose all the scrapped info of snes and I just see the list of roms with no artwork or infos. It's tedious to scrap again and again, so I don't scrap anymore. I didn't have this problem with other systems, maybe it has been a random situation of corrupt copy through samba network...
                                  • when I enter a rom and I get the "zoom in" effect in the artwork image in emulationstation, I can barely see a tiny delay in the movement of the image a couple of times, so maybe the graphics of new 3b+ still doesn't have the 100% optimized driver, just like the wifi.
                                  • when it is idle in emulationstation menus, it reaches 66ÂșC after a while (room temp about 25ÂșC). When I check via ssh the top command, the only process consuming cpu is emulationstation (9%). The raspberry is just connected via hdmi to a full hd 1920x1080p 22" tv and a buffalo snes pad.
                                  My custom changes:
                                  • I manually disabled with chmod -x some services that I don't need from /etc/init.d: S02splash, S24lircdmod S25hyperion S25lircd S31sixad S32bluetooth S92steamcontroller S92virtualgamepads
                                  • I enabled custom shaders for the roms
                                  Thanks to all people putting effort on this release!
                                  • tonificante
                                    tonificante last edited by
                                    I disabled both the recalbox web manager and kodi from the corresponding emulation station menu options, and now it is working better. I think the recalbox web manager was colliding with the stopped virtual gamepad service. Now temp seems to stay at 62ÂșC when idle, and emulationstation stays on 5% cpu use. The "zoom" effect when entering a rom seems to be more fluent now.
                                    • CedrickM
                                      @gaetan Hello Gaetan, I've tried lots of ways of making updates with your message, and i 've been forced to format my sd card after each updates. When i listen creators speaking about the Recalbox speaking of the way to make easier the access to such programs, it mahes me dream...
                                      • Gaetan
                                        @cedrickm You need to acces to the Webmanager
                                        https://github.com/recalbox/recalbox-os/wiki/recalbox-manager-WEB-interface-(FR)
                                        Then go to recalbox.conf
                                        Then find the line :
                                        updates.type=stable
                                        and change it to :
                                        updates.type=https://review-507-b*mp-b-0jn0c0-archive-review-prod.recalbox.com
                                        Hit save button
                                        Restart
                                        • CedrickM
                                          @gaetan Thank you for your answer Gaetan, when i do that, and run the update, i've got a message : "an error occured - update downloaded".
                                          • noktambule
                                            noktambule @CedrickM last edited by
                                            @cedrickm check if you have an "/" after the line.
                                            And so delete it.
