    Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...)
    Testers's corner
    testers wanted major upgrade pi3b
    198
    805
    919698
    • Gaetan
      Gaetan Theme moderator @crash2393 last edited by
      Hi @crash2393, any help is welcome 🙂
      Do you own a rpi3b too ?
      • crash2393
        Unfortunately no, just XU4 and quite a few A10 and A20 based SoC's but they're kinda useless for retrogaming.
        • chadi
          chadi @Fry_4TF1V last edited by
          @fry_4tf1v Thank You!!!
          • Neibaf41
            Neibaf41 last edited by
            Installation de la beta 2 sur mon rpi3b+
            Mes manettes Xbox 360 Wireless sont reconnues mais aucunes roms ne se lancent (testé SNES, CPC).
            Merci et bravo pour votre travail
            Hi,
            Beta2 on my rpi3b+
            Wireless Xbox 360 pad work fine but any roms boot (tested on SNES and CPC roms).
            Thanks and congrats for your job
            • olivierdroid92
              @Fabien-Dugué
              Try to map again your pad before.
              Tu dois remapper tes pads avant de joueur
              Neibaf41 1 Reply Last reply Reply Quote 0
              • Gaetan
                Gaetan Theme moderator @Neibaf41 last edited by Gaetan
                @fabien-dugué you need to remap your controller first.
                @olivierdroid92 ce n'est pas possible de t'envoyer un mp, tu pourrais m'en envoyer un ?
                Ce serait a propos d'un test pi3b/pi3b+
                • Neibaf41
                  Neibaf41 @olivierdroid92 last edited by
                  @olivierdroid92 said in Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...):
                  @Fabien-Dugué
                  Merci, c'est nickel
                  • lafureur
                    lafureur last edited by
                    Hello, there is no valid download link ... Can you help me?
                    Fry_4TF1V 1 Reply Last reply Reply Quote 0
                    • Fry_4TF1V
                      Fry_4TF1V @lafureur last edited by
                      @lafureur Look my post above
                      • Franc-Boisier
                        Franc-Boisier @Fry_4TF1V last edited by
                        @fry_4tf1v Thank you !
                        Board(s) : Rpi 3 B+
                        Controller(s) : 8bitdo SFC30 pro
                        • wally007uk
                          wally007uk @Fry_4TF1V last edited by
                          @fry_4tf1v I used your download, when loaded up it wanted to update, did update and get lighting bolt now 😞
                          Franc-Boisier 1 Reply Last reply Reply Quote 0
                          • Franc-Boisier
                            Franc-Boisier @wally007uk last edited by
                            @wally007uk
                            Did U edit your recalbox.conf and set updates.type to:
                            https://review-507-b*mp-b-0jn0c0-archive-review-prod.recalbox.com
                            Board(s) : Rpi 3 B+
                            wally007uk 1 Reply Last reply Reply Quote 0
                            • wally007uk
                              wally007uk @Franc-Boisier last edited by
                              @franc-boisier said in Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...):
                              Yes, all that was good, when i try and run Mario Kart 64 it just goes back to game list!?
                              • Gaetan
                                Gaetan Theme moderator @wally007uk last edited by
                                @wally007uk you need to remap your controller
                                • Franc-Boisier
                                  Hi all,
                                  My pads are recognized, but when i launch a game, they are no longer ...
                                  I must restart RB ...
                                  I've tryed to reinstal, but it's always the same .
                                  Board(s) : Rpi 3 B+
                                  • Gaetan
                                    Gaetan Theme moderator @Franc-Boisier last edited by
                                    @franc-boisier Did you remap your controller ?
                                    • Franc-Boisier
                                      Franc-Boisier @Gaetan last edited by
                                      @gaetan Yes, of course .
                                      Board(s) : Rpi 3 B+
                                      • VoSed
                                        VoSed last edited by
                                        Hello. Yesterday I installed the beta version of Recalbox, following the instructions. After some time of use, it happened strange - after clicking on "Update Game List" EmulationStation is closed. After that, I checked the file system, and it turned out that there were errors on the root partition (probably because when Recalbox hung during the transfer of games through Recalbox Manager, I turned off the RP3 from the socket). After fsck -fy, the file system errors were fixed, and I decided to install the update (root.tar.xz) again. But the problem with closing the EmultationStation was not solved. Can I solve this problem without reinstalling Recalbox?
                                        VoSed 1 Reply Last reply Reply Quote 0
                                        • VoSed
                                          VoSed @VoSed last edited by
                                          Maybe I need to unzip/untar root.tar.xz to root directory?
                                          • Michael Baudino
                                            Michael Baudino Staff last edited by
                                            @sumofoneinteger I'm seeing the exact same behaviour (from a freshly built image on a Pi3b+). It looks like hashlib is not working properly with Python 2.7. I'm trying to figure out why and will post a merge request if I succeed.
