    Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...)
    Testers's corner
    testers wanted major upgrade pi3b
    198
    805
    919662
      Substring @Juakin last edited by
      @juakin thank you for the feedback. I've suggested you disable audio_pwm_mode, have you tried ?
      For ES : yeah, known but, though i javen't had a clue on it yet. I believe it's ES somehow crashing, i've exprienced this on some boards, but not everytime ... But i'm on it 🙂
      Juakin 1 Reply Last reply Reply Quote 0
        Substring @betikito84 last edited by
        @betikito84 donyou still have thay faulty file ? I'd need to dig why it was causing such trouble
        • Juakin
          Juakin @Substring last edited by
          @substring yes, I've tried both, disabled and enabled, but it doesn't solve the issue.
          Substring 2 Replies Last reply Reply Quote 0
            @juakin i'll check this, i have the cables and some CRT
            • Injall
              Injall @Substring last edited by Injall
              @substring Salut !
              J'ai une carte RPI3B+ je test si tu cherche encore des testeurs. J'ai aussi un Tinker Asus !
              Cartes : RPI3b, RPI3b+, Tinker ASUS, Odroid XU4
              • noktambule
                noktambule @Injall last edited by
                @injall ben, y'a toujours besoin, y'a jamais trop d'avis ! Installe et dis nous tes impressions !
                  @juakin set audio_pwm_mode=0 and tadaaaaa
                  • Juakin
                    @substring that worked perfectly, thank you very much!
                    It seems that the option "Refresh/update games list" makes ES crash too...
                    For some reason I've lost N64 scrape data and I'm having some problems scraping again...
                      @juakin remove the gamelist file. The option does work, your file must have been corrupted
                      • Injall
                        Bonsoir,
                        Pour info suite à l'installation j'ai mis tous les BIOS ils sont au vert dans le manager mais, aucun jeux fonctionnent... Ai-je oublié quelque chose ?
                        • olivierdroid92
                          @Injall
                          Can you please tell us wtich is not working ?
                          Do you have remapped your pad ? As tu assigné les boutons sur ta manette ?
                          • Juakin
                            @substring that worked, thank you!
                            • Suriv
                              Suriv last edited by
                              Hi
                              I wanted to download the image where the links are but apparently they are limited by time. Can they be updated? Or will a new version be uploaded?
                                Substring @Suriv last edited by
                                @suriv new up to date beta version of the pi3 https://we.tl/t-oaFQNyWQuq
                                this update has been deployed, but the updgrade server is naughty and is not responding. I hope it will be back soon
                                  New upgrade available : fixed arcade GPIO driver on pi3
                                  • almanet
                                    almanet last edited by
                                    Raspberry Pie 3 B+:
                                    The picture on the FullHD TV is beyond the border of the screen.
                                    • fosi
                                      fosi last edited by fosi
                                      Hello
                                      I dont have my rasperry 3b anymore.
                                      Please can you upload the direct image for the 3b+ again.
                                      The old Link is down.
                                      Thanks
                                      Fosi
                                      Suriv 1 Reply Last reply Reply Quote 0
                                      • Gaetan
                                        Gaetan Theme moderator last edited by
                                        Avec la dernière màj (pi3b+) :
                                        • Ecran noir en voulant rejoindre une partie sur le netplay.
                                          Obligé de redémarrer Recalbox via le webmanager.
                                          https://file.ac/K0dhzSF96EI/
                                        • Ecran noir AVEC logo blanc et version en bas en voulant redĂ©marrer Recalbox.
                                          J'ai réussi a éteindre Recalbox avec le webmanager.
                                          https://file.ac/7n9xee9e3Qk/
                                        • Ecran noir SANS logo blanc et version en bas en voulant redĂ©marrer Recalbox.
                                          https://file.ac/vltUVlkQAOs/
                                        C'est systématique, je ne peux pas éteindre Recalbox proprement en passant par le menu ES, je suis obliger de le faire via le webmanager.
                                        • Dreamcast
                                          Les boutons ne répondent pas correctement avec le jeu DOA2, tous les boutons font la garde. La même rom fonctionne normalement sur mon pi3b et sur mon odroid.
                                          https://file.ac/pgI4QSepJjA/
                                        • Ckau
                                          Ckau last edited by
                                          When scrapped video kodi closed and i cant launch kodi again
                                          Ckau 1 Reply Last reply Reply Quote 0
                                          • Ckau
                                            Ckau @Ckau last edited by
                                            when i delete .kodi*userdata* kodi start again
