    Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...)
    Testers's corner
    testers wanted major upgrade pi3b
    198
    805
    919677
    • SumOfOneInteger
      SumOfOneInteger last edited by
      Almost no Kodi add-ons are working. Plex, YouTube, and HDHomeRun have been tested. It appears to be a problem with Python 2.7 verifying the hash of the plugin. I don't have these issues running these add-ons in LibreElec or on older versions of Recalbox.
      The excerpt from kodi.log is here: https://pastebin.com/TQ4VqHAZ
      • Gaetan
        Gaetan Theme moderator last edited by
        Problème de police de caractère avec la dernière maj :
        text alternatif
        • Suriv
          Suriv @fosi last edited by
          @fosi
          In two previous comments @Substring replies:
          "new up to date beta version of the pi3 https://we.tl/t-oaFQNyWQuq"
          • Gaetan
            Gaetan Theme moderator @Gaetan last edited by Gaetan
            @Substring Aujourd'hui plus de problème de police de caractère...
            Ma manette SFC30 pro n'est pas reconnue dans les jeux utilisant Retroarch alors que dans les émulateurs standalone elle fonctionne correctement.
            Archive de support : https://file.ac/1g785k-fsL8/
            Quand le SFC30 pro est apparairée, elle empêche aussi la manette usb de fonctionner dans les jeux.
            Les favoris ne s'enregistrent plus.
            Ecran noir après maj de la gamelist
            Archive de support : https://file.ac/6ctKKH7cE0U/
              paradadf Staff @Gaetan last edited by
              @gaetan this is an english thread, so please write only in english the next time.
              Gaetan 1 Reply Last reply Reply Quote 1
              • Gaetan
                Gaetan Theme moderator @paradadf last edited by
                @paradadf you right, sorry.
                • mi7chy
                  mi7chy last edited by
                  Ran into an issue running the latest update https://we.tl/t-oaFQNyWQuq.
                  This NES rom hack doesn't run with any of the cores and just stays at a black screen when launched.
                  https://www.romhacking.net/hacks/4123/
                  Works fine with 18.07.13 release.
                  • olivierdroid92
                    @mi7chy
                    Noted, can you please try to re-map your pad and try again. think it should works as I 've experimented same issue
                    mi7chy 1 Reply Last reply Reply Quote 0
                    • glukkkk
                      glukkkk last edited by
                      So, do you have any ETA when the beta testing is over? Maybe some progress percentage? Can't really wait when the stable release is ready! I wish I had skills and time to help you to test it 😞
                      • Injall
                        Injall last edited by
                        La mise à jour en OTA ne fonctionne pas. J'ai un écran noir avec un éclaire jaune en haut à droite de l'écran. J'utilise un adaptateur de 5V 3A.
                        Cartes : RPI3b, RPI3b+, Tinker ASUS, Odroid XU4
                        • Gaetan
                          Well the new update is not working, black screen and yellow thunder 😕
                          • mi7chy
                            mi7chy @olivierdroid92 last edited by
                            @olivierdroid92
                            Rom hack still doesn't work even after remapping controller updated from stable 18.07.13 > beta1 > beta2.
                            Works if reflashing new with beta2 image.
                            Works if updating from 18.07.13 > beta2.
                            Also fixes msx2 gamelist.xml from getting wiped.
                            Doesn't fix atarist roms that no longer work.
                            Doesn't fix Kodi controller input from working by default. Have to use keyboard to go to 'configure attached controller' menu then accepting prompt to enable required addon (Kodi joystick support?).
                            • djeb
                              djeb last edited by
                              RetroAchievements don't work on my side. What about you ?
                              • djeb
                                djeb last edited by
                                Kodi works well but crashes as soon I'm adding a NFS source.
                                It doesn't start anymore until I remove the .kodi folder
                                • Viktor K
                                  Viktor K last edited by
                                  Where i can get img file? Link is empty.
                                  • chadi
                                    chadi last edited by
                                    @suriv said in Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...):
                                    @fosi
                                    This Link is dead to
                                    • chadi
                                      @Substring could u reup pls?
                                      Gaetan Fry_4TF1V 2 Replies Last reply Reply Quote 0
                                      • Gaetan
                                        Gaetan Theme moderator @chadi last edited by
                                        @chadi @Viktor-K
                                        Be patient, the link will be fix soon
                                        • Fry_4TF1V
                                          Fry_4TF1V @chadi last edited by
                                          @chadi Here is the link from my FTP
                                          chadi Franc-Boisier wally007uk 3 Replies Last reply Reply Quote 0
                                          • crash2393
                                            crash2393 last edited by
                                            Hello. I'm new.
                                            I offer my best help to test image throughly, however i would need image for XU4 board. Probably i could build one from repos on my own, but it could bias the tests with bugs of my own compilation origin.
                                            I work professionally with embeded linux systems so i hope i could contribute to great work recalbox is.
