    Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...)
    Testers's corner
    testers wanted major upgrade pi3b
    198
    805
    919743
    • starmagoo
      starmagoo last edited by
      Here are my found problems:
      • Recalbox crashes sometimes at hash calculation for Netplay
      • Kodi doesn't start (Black screen and recalbox returns to the home screen)
      • Restart doesn't work
      cheers
      starmagoo 1 Reply Last reply Reply Quote 0
      • betikito84
        betikito84 last edited by
        Hello everyone:
        I have updated my Raspberry Pi 3 b +, to the latest beta version, and I have several problems:
        1. It does not connect to the internet or via wifi or lan.
        2. Do not connect my PS4 or PS3 bloetooch controller.
        3. Every time I restart I get the message that Recalbox is already updated.
        Thank you all and forgive me since I am Spanish and English is not very good for me.
        • starmagoo
          starmagoo @starmagoo last edited by starmagoo
          @starmagoo said in Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...):
          cheers
          I have also tried various emulators and ROM's but none has started (NES, SNES, GG, GB, ...).
          Webif also doesn't work.
          SumOfOneInteger 1 Reply Last reply Reply Quote 0
          • SumOfOneInteger
            SumOfOneInteger @starmagoo last edited by
            @starmagoo Remap your controller.
            • hoyohoyo
              hoyohoyo last edited by
              rpi3b +
              Thanks for this rotten update!
              black and lightning screen up and right, update launched from the menu...
              I had 100gb of rom...
              Gaetan Substring 2 Replies Last reply Reply Quote -1
              • Gaetan
                Gaetan Theme moderator @hoyohoyo last edited by
                @hoyohoyo before updating you have to change the recolbox.conf as it's said in the first post.
                If you don't, you'll brick your recalbox. If you do it like it should be done, you'll have a normal update and everything will be ok.
                  Substring @hoyohoyo last edited by
                  @hoyohoyo have you read the very first post stating this is experimental, and you should do this on a backup SD ?
                  • glukkkk
                    glukkkk last edited by
                    C'mon, testers! Hurry up 🙂 My Pi3+ board inside the NesPi Case is ready and waiting for you!
                    P.S. I'm joking, you do everything great! Make the release build as much stable as possible.
                    • CedrickM
                      CedrickM @noktambule last edited by
                      @noktambule Thank you for your help, i managed to start the recalbox again with the update. Nevertheless, i still try to add roms, and they did not appear in my recalbox "interface" whereas it appear in my recalbox roms directory. Has someone an idea ?
                      • Simon DA SILVA
                        Simon DA SILVA last edited by
                        Hello,
                        I just installed Recalbox beta on my 3b + but I have a problem, no game starts when I wander through the menus (out emulator confused), I tried several times, formatting cleanly (deleted partition, long formatting , etc.), if anyone has an idea to help me?
                        Thank you ! 🙂
                        • Gaetan
                          Gaetan Theme moderator @Simon DA SILVA last edited by
                          @simon-da-silva you have to remap your controller first
                          Simon DA SILVA 1 Reply Last reply Reply Quote 0
                          • Simon DA SILVA
                            Simon DA SILVA @Gaetan last edited by
                            @gaetan yeah just after i wrote my question i,ve looked at that, it's work 😄 thx dude !
                            • Gaetan
                              @simon-da-silva have fun 🙂
                              • cazeysan
                                cazeysan last edited by
                                For everyone, if you want to do some serious tests on Recalbox for Raspberry Pi 3b+, you have to read the first post in this topic.
                                Viens par là, c'est pareil !
                                1 Reply Last reply Reply Quote 3
                                • james-lord
                                  james-lord last edited by james-lord
                                  Testing with a bluetooth xbox one controller and it will not pair, has anyone got this to work with the builtin BT on the Rpi 3+?
                                  • MarbleMad
                                    MarbleMad last edited by
                                    Mon petit retour d'expérience sur l'install de recalbox beta sur pi3b+ dans un boitier snes Retroflag
                                    • Reboot indéfiniment après l'écran d’accueil d'EmulationStation quand on utilise une alimentation trop faible
                                    • Date des fichiers au 01/01/1980 20:00 : pas gênant mais bizarre
                                    • Pas de dossier share/overlays/ d'origine : ça serai interessant d'en créer un avec un fichier lisez-moi dedans qui renvoi a la page wiki d'installation des overlays de jeux.
                                    Voila pour l'instant, je continu mais tests 😉
                                    • mariob
                                      mariob last edited by
                                      I just installed Recalbox beta on my 3b+ but I have a problem with a video plugin not running in kodi. This IPTV plugin run very well on my 2 rpi3B (not +) with libreelec and recalbox and also on my odroid xu4 under android 8.1. On the B+ it tells me to look in the log file to see the error description. Here it is: 23:31:27.961 T:1925739120 ERROR: GetDirectory - Error getting plugin://plugin.video.xxxxxxxx/
                                      23:31:27.962 T:1925739120 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.xxxxxxxx/) failed
                                      This doesn't occur on my B+ with a retropie image including kodi 17.6.
                                      I have well mapped my controller before anything and the retrogaming is ok, ssh trough my wired network is ok, vido sources are ok in kodi.
                                      Any idea ?
                                      Thank you.
                                      SumOfOneInteger 1 Reply Last reply Reply Quote 1
                                      • Choum
                                        Choum last edited by
                                        Hello,
                                        With this beta image (on a new installation on 3+), will it be possible to return to the stable branch when this beta will end or we will have to reinstall the recalbox with a new image ?
                                        • Alex_123
                                          Alex_123 last edited by Alex_123
                                          Hello, I have downloaded the beta version and tested on my Raspberry 3B+:
                                          Works:
                                          • Xbox360 wireless gamepad: Gamepad remapped, it works well in Recalbox menus and games launched.
                                          Not Works:
                                          • Gamesir 3gs wireless gamepad: Gamepad remapped, it works in Recalbox menus but it does not respond in games launched.
                                          • Retroarch gui menu settings are not saved: I access to Retroarch gui (hotkey+b) and change in Settings->Video->Bilinear filter from On to Off but this change is not saved, after restarting On value go back.
                                          • SumOfOneInteger
                                            SumOfOneInteger @mariob last edited by
                                            @mariob There's been a few other posts here (including one I made three weeks ago.) No responses yet. Just keep monitoring this thread.
