    Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...)
    Testers's corner
    testers wanted major upgrade pi3b
    198
    805
    919798
    • OldGreg
      OldGreg last edited by
      About favorites and scrap :
      • Two or three times i reset my gamelist.xml for megadrive and supernes, and always problems. I can have scraps, but not favorites. When i had them, most of the times they no longer there next times. And sometimes, all the scraps are erased.
      May be my kingston usb or my noname sd ? I'll tell you after i recept a better material than actually.
      RPi 3B+ with Recalbox 6.0
      • darksouljedi
        darksouljedi last edited by
        I found how to use gpio controler.
        it works on the main screen.
        I can go in sub menu, change parameters ,....
        but when I try to start a game, it go back to the main menu.
        In the controler parameters, I select controler 1 & 2 -> gpio
        nothing change.
        how to resolve this problem ?
        Is it necessary to use an us controler ?
        thanks for the job & help
        • Vincent Ducroquet
          Vincent Ducroquet last edited by
          Hello, I can't Edit the recalbox.conf file to set updates.type from "stable" to "theUrlOfFirstUpdate".
          when i save the file (i'm using WinScp), and go back to it, the url is replaced by "stable".
          So when I update the recalbox after the reboot I have a yellow lightning on top right of my screen, so I have to flash my sd again with the orginial file.
          I have a 3b+.
          • Marcos Breviglieri
            Marcos Breviglieri last edited by
            Is there a newer beta than the one previously available? Are we close to the stable version being released?
            maxmoro77 1 Reply Last reply Reply Quote 1
            • maxmoro77
              maxmoro77 @Marcos Breviglieri last edited by
              @marcos-breviglieri said in Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...):
              @Substring did not post anything on this forum for more than a month! Is he okay? ☹️
                voljega Banned @maxmoro77 last edited by
                @maxmoro77 he left the project
                mi7chy 1 Reply Last reply Reply Quote 0
                • mi7chy
                  mi7chy @voljega last edited by
                  @voljega We greatly appreciate his contribution but are there other developers continuing the effort or is Recalbox on hold if he was the sole developer?
                    voljega Banned @mi7chy last edited by
                    @mi7chy there are other developers continuing the project
                    maxmoro77 1 Reply Last reply Reply Quote 0
                    • vincent-84
                      vincent-84 last edited by
                      @vincent-84 said in Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...):
                      Glad to heard this.
                      Some precision about my message above : each time I start a game, both of my two SFC30pro controllers are disconnected.
                      That doesn't occur with USB-c connexion.
                      Rpi3b+, Superpi case, SFC30pro
                      • Damn_it666
                        Damn_it666 last edited by
                        after install, recalbox want an update. I try it, than it was all black on the screen.
                        Wired CSL GamePad works .. (i have an 3b+) but no one game starts … after changing Simulator it starts not, too.
                        voljega OldGreg 2 Replies Last reply Reply Quote 0
                          voljega Banned @Damn_it666 last edited by
                          @d**n_it666 did you bother readingvthe first message in this subject ?
                          • OldGreg
                            OldGreg @Damn_it666 last edited by
                            @d**n_it666 : In first message : no update after install. ^^
                            • maxmoro77
                              maxmoro77 @voljega last edited by
                              @voljega said in Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...):
                              Would it be possible to estimate the release date of a stable version? Only an approximate estimate! Days, weeks or other months? Thanks a lot!
                              Gaetan 1 Reply Last reply Reply Quote -3
                              • Gaetan
                                Gaetan Theme moderator @maxmoro77 last edited by
                                @maxmoro77 between weeks and mounths probably
                                • BertL1005
                                  BertL1005 last edited by
                                  Hi there. The Master version was the best. Can you release this version again? All Emus worked in master version for the 3b+.
                                  Now i have the 18.07.13 version on my pi 3b+ is this a stable version ?? greets Robert
                                  • zevleu
                                    zevleu last edited by
                                    Using Pi3b+ with xbox game pad, games on N64 run fine.
                                    Using Kodi, I can reach and watch videos from my Upnp NAS, but plugin incursion fails to access movies. I have exactly the same Kodi/Incursion configuration on my laptop running Ubuntu 18 and it runs perfectly.
                                    Looks like Kodi+Incursion cannot access web, while it's ok on my laptop on same network.
                                    There is no specific error in the logs.
                                    • BertL1005
                                      Nobody needs kodi on recalbox. You can install librelec to use kodi.
                                      Michael Muguet 0 1 Reply Last reply Reply Quote 0
                                      • Michael Muguet 0
                                        Michael Muguet 0 @BertL1005 last edited by
                                        @bertl1005 A lot of people need Kodi on recalbox. For many off us it's the main use because it's on the TV.
                                        • youknow
                                          youknow Banned last edited by youknow
                                          This post is deleted!
                                            OyyoDams Staff last edited by OyyoDams
                                            Hi friends,
                                            Good news! We've fixed many bugs and had to rewrite a lot of code, but here we go, the beta is still on a good, very good development process. All these improvements are not visible yet, but we've decided to release a new beta version anyway, so here are some visible changes:
                                            • ES: Fix Music Thread issues
                                            • B*mp Kodi's Youtube Plugin to version 6.2.2
                                            • Add Pi3B+ Overclocking Values and improve Pi3B's Overclocking value consistency
                                            • Fix: unstable wifi
                                            Direct links updated in 1st post.
                                            If you want to upgrade from previous beta, be sure in recalbox.conf the line updates.type is set to:
                                            https://review-507-b*mp-b-0jn0c0-archive-review-prod.recalbox.com
                                            Gaetan toniosj wilfrid 3 Replies Last reply Reply Quote 6
