    Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...)
    Testers's corner
    testers wanted major upgrade pi3b
    198
    805
    919813
    • Gaetan
      Gaetan Theme moderator @OyyoDams last edited by
      @oyyodams +1000000000 !
      • olivierdroid92
        @OyyoDams
        Thanks a lot for all the Dev team !!!
        • toniosj
          toniosj Spanish moderator @OyyoDams last edited by
          @oyyodams Thanks! Really good news!
          • Goden57
            Goden57 last edited by
            Thnx, updated on Pi3b+
            Niceeee
            • williamperri
              williamperri last edited by
              I added a RaspBerry PI3 B + ... I found in the Forum that the image is still in Beta. I installed the image on PI3B+ and it worked for a few days. I did an upgrade suggested by RECALBOX, but after that the Operating System did not initialize ... I refined the image with BUILD 28566561, but none of the games (nor the natives coming with the image) do not start ... Could someone help me, for know where the LOGs are so I can investigate?
              OldGreg 1 Reply Last reply Reply Quote -1
              • OldGreg
                OldGreg @williamperri last edited by
                @williamperri : At the end of the first message : beware : after install the beta, no updates !
                RPi 3B+ with Recalbox 6.0
                williamperri 1 Reply Last reply Reply Quote 2
                • williamperri
                  williamperri @OldGreg last edited by
                  @oldgreg I am new user from RaspBerry... and Recalbox... You know if have another old builds to RaspBerry PI3b+? I will try with anothers builds... Because, in this build (2018-08-23) any roms start :(... Thanks.
                    OyyoDams Staff @williamperri last edited by
                    @williamperri first remap your pads, then if it still doesn't work, post a support archive.
                    williamperri 1 Reply Last reply Reply Quote 0
                    • williamperri
                      williamperri @OyyoDams last edited by
                      @oyyodams Uau Man... Incredible... WORK!... My control is work normally, after deploy... then I not reconfigure control... because work normal... but.. after reconfigure, the room is started.. thanks a lot!
                      • vdeolive
                        vdeolive last edited by
                        Hello,
                        Fresh installation of 11/12/2018 beta with the p3+ link yesterday. I am using recalbox on sd card 16go and usb key sandisk256go / system parameter on any external source.
                        1. virtual keyboard to fullfill wifi key does not appears.
                          Impossible to set the wifi without keyboard.
                        2. kintaro ursus scripts to pilot safe stop + reset button + fans not integrated
                        So far, emulation is ok. Extrem overclock 1500mhz works.
                        Still testing.
                        Thank you guys for your hardwork and dedication in making us happy.
                        Regards
                        • vdeolive
                          1. Gamepad loss while entering in retroarch. The gamepad (sfc30pro) works on emulation station interface but the inputs are not communicated to retroarch. You have to reinitiate the system manually
                            OyyoDams Staff @vdeolive last edited by
                            @vdeolive about the virtual keyboard: known issue, just go back and enter again, the virtual keyboard will appear.
                            I've played with a sf30pro yesterday on the latest build without any issue. Be sure to reconfigure the mapping.
                            • mi7chy
                              mi7chy last edited by
                              Thanks for the 11/12/2018 update. These are the issues I've run into so far:
                              • Controller setup glitches with genuine Sony PS3 six axis controller once you get to the trigger buttons. It's working fine in the stable release and one of the reasons I switched to Recalbox.
                              • Atari ST .ipf images in compressed .zip still no longer work and just return to menu like with previous test versions. Stable version works fine.
                              • mi7chy
                                mi7chy last edited by mi7chy
                                Added some additional roms and after updating game list through Start menu it's been stuck at "PLEASE WAIT" on Recalbox Emulation Station white screen. Can ping the IP but can no longer SSH into it to do proper restart. Updated from stable release 18.07.13.
                                • Guy Don
                                  Guy Don last edited by
                                  Hi !
                                  I'm using recalbox rpi3 12/11/2018 beta (4ad393af) on a Rpi3B+,
                                  OS is runing, but can't launch any game ( game build in ) . Black screen and go back menu.
                                  Kodi not running black screen ...
                                  • OldGreg
                                    OldGreg @Guy Don last edited by
                                    @guy-don : Have you remap your gamepad after upgrade ? It's the solution, most of the time...
                                    • vdeolive
                                      vdeolive last edited by vdeolive
                                      Hello,
                                      To be more precise i am playing with bluetooth dongle (i've bought the recommanded one on your shop) in order to reduce input lag. Sfc30pro is updated on last firmware from 8bitdo.
                                      The sfc30pro is recognised and i can configure it.
                                      It works on emulation station but when you enter retroarch, pad is not recognised anymore. I have tried several times to forgot the pad and reconfigure it but still same issue. Pad connected with cable works.
                                      Only with bt, gamepad is lost on retroarch.
                                      Any idea?
                                      Thanks
                                        OyyoDams Staff @vdeolive last edited by OyyoDams
                                        @vdeolive my latest test was with internal BT of the B+. I'll make a test with the BT dongle and check if it works.
                                        • vincent-84
                                          vincent-84 last edited by vincent-84
                                          @OyyoDams
                                          For me, the new version of the beta doesn't solve the bluetooth pad (SF30pro, fireware updated) issues, without dongle :
                                          _ deconnexion from ES to retroarch. Sometimes, waiting several minute allow the reconnexion of the pad.
                                          _ some L2/R2 issues
                                          remapping the pad doesn't solve the problem, but USB-C connexion does.
                                          Maybe "retroarch input driver" in config could solve this issue ?
                                          Rpi3b+, Superpi case, SFC30pro
                                          • Jesper Ammitzbøll
                                            Jesper Ammitzbøll last edited by
                                            Thanks for the update. wondering if HDMI to dvi is fully implemented, coz i tested on my old 19" 4/3 screen, and it just vent black. tested on my newer 24" also over dvi, no problem there.
                                            Jesper Ammitzbøll 1 Reply Last reply Reply Quote 0
                                            Copyright Š 2021 recalbox.com
