    Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...)
    Testers's corner
    testers wanted major upgrade pi3b
    198
    805
    919836
    • Choum
      Choum @Gaetan last edited by
      @gaetan on putty :
      hcitool con -> To list gamepad mac adress
      You should see somthing like "ACL AA:BB:CC:DD:EE:FF handle 11 state 1 lm MASTER"
      Then
      l2ping AA:BB:CC:DD:EE:FF
      This will run a infinite ping on the gamepad each second.
      • Gaetan
        Gaetan Theme moderator @Choum last edited by
        @choum thanx ! Will try this 🙂
        • simba51
          simba51 last edited by
          I am testing this beta version with the new Raspberry Pi 3 A + card, with some update of some files in the Boot.Tout partition working properly as its big brother Rpi 3 B +. WiFi is functional as well as bluetooth with 8Bitdo SFC30 Pro controller.
          On the other hand, in spite of the modification in recalbox.conf of:
          update = https: //review-507-b*mp-b-0jn0c0-archive-review-prod.recalbox.com
          the last update does not start.
          Cartes RPi Zéro 2 W - RPi Zéro W - RPi400 - RPi 4/4Gb - RPi 3b - RPi 3b+ - RPi 3 a+
          Stockage 16Gb Sandisk, 32Gb Samsung et clé usb 64Gb & 128Gb
          2 manettes PS3 Freegun Bluetooth - 2 manettes 8BitDo SF30 Pro Bluetooth
          • Gaetan
            Gaetan Theme moderator @simba51 last edited by
            Hi @simba51 ! It's interesting test. What did you modify in Boot to make it work ?
            simba51 1 Reply Last reply Reply Quote 0
            • simba51
              simba51 @Gaetan last edited by
              @gaetan
              I replaced the files:
              "Bcm2710-rpi-3-b.dtb"
              "Bcm2710-rpi-3-b-plus.dtb"
              "Bcm2710-rpi-cm3.dtb"
              "Bootcode.bin"
              "Fixup.dat"
              "Start.elf"
              by those of the boot of the last update of RASPBIAN "2018-11-13-Raspbian-stretch".
              The first 3 files may not be required to replace I think. to test again on new installation.
              • Gaetan
                @simba51 Thanx !
                • vincent-84
                  vincent-84 last edited by
                  détail : recalbox manager affiche une mémoire à 495MB.
                  J'imagine qu'il faut juste actualiser cela.
                  Rpi3b+, Superpi case, SFC30pro
                  vincent-84 1 Reply Last reply Reply Quote 0
                  • Norde
                    Norde last edited by
                    I've measured internal bluetooth input lag with an Xbox one S gamedpad on both Rpi 3 and 3+*.
                    I did not notice any difference.
                    With 100 ping, mean is around 16ms with a min of 14min and a max of 27 in both case.
                    On the other hand I noticed a difference when I change the driver.
                    By moving from xpad to xpadneo, input lag goes from a mean of 16ms to a mean of 22ms (min of 19ms and max of 48ms, from 100 ping).
                    So I guess the difference observed by choum is due to software and not hardware. Have you tried this on a fresh install ?
                    *The tests were carried out with l2ping command on a blank installation of raspbian lite (last version: 2018-11-13), after a sudo apt-get update upgrade.
                    Boards : Rpi1 B+, Rpi2 B, Rpi3 B, Rpi3 B+
                    Controllers : Xbox One S controller, PS1 controllers
                    Case : Superpi case Retroflag
                    • vincent-84
                      vincent-84 @vincent-84 last edited by
                      @vincent-84 said in Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...):
                      Sorry, wrong language :
                      I said : recalbox manager shows a memory at 495MB.
                      Seems to be just a small mistake
                      paradadf 1 Reply Last reply Reply Quote 1
                      • wilfrid
                        wilfrid @OyyoDams last edited by
                        @oyyodams Hello la team et merci pour votre travail !
                        Je viens de flasher une carte fraiche sur ce nouveau build de beta 2018/11/12 pour tester le wifi. ProblÚme toujours présent pour moi : une fois que je l'active, je sélectionne mon SSID et je tape mon MDP mais impossible de se connecter.
                        J'ai aussi essayĂ© en mettant directement les infos dans le recalbox.conf mais j'ai le mĂȘme rĂ©sultat. Du coup, je suis revenu en cable.
                          paradadf Staff @vincent-84 last edited by
                          @vincent-84 no mistake. The rest ist reserved for the GPU.
                          • patsar
                            patsar last edited by
                            Hello,
                            Tested on PI3b+ with 8Bit Do FC30 controllers.
                            Wifi doesn't work.
                            Remapping FC30 failed.
                            text alternatif
                            • toniosj
                              toniosj Spanish moderator last edited by
                              ShareDevice=NETWORK on 3b+ doesnt work.
                              moguai OyyoDams 2 Replies Last reply Reply Quote 0
                              • moguai
                                moguai @toniosj last edited by
                                @toniosj said in Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...):
                                same here... I posted to other threads because I can't get it worked... folders, users and command should be right.
                                If this is a bug that would be "good". Because I tried so much to get it worked.
                                Rpi3 B+
                                PS3 Dualshock, XBox 360 wired
                                toniosj 1 Reply Last reply Reply Quote 0
                                • toniosj
                                  toniosj Spanish moderator @moguai last edited by toniosj
                                  @moguai my shared folder works fine with a pi3 stable recalbox. On my Pi3b+ the same shared folder and configuration dont work on beta recalbox.
                                  • patsar
                                    https://review-507-b*mp-b-0jn0c0-archive-review-prod.recalbox.com => adresse introuvable...
                                    • simba51
                                      simba51 @patsar last edited by
                                      @patsar
                                      @OyyoDams
                                      I understand better why, during my tests with the new Rpi 3 A + with the installation of my image recalbox beta of 08/18/18, the update of 12/11/18 was not made. Updates can not be done now?
                                        OyyoDams Staff last edited by OyyoDams
                                        Hi friends,
                                        First of all, upgrade link is fixed. But that's not all! We've just released a new version of the beta, with some improvements:
                                        • Many fixes on ES and less memory consumption
                                        • Better handle of memory between GPU and CPU, so now PSP games should launch really better 🙂
                                        • Zipped WHDL support
                                        • Default resolution fix on mupen
                                        There are still some work to do:
                                        • Keyboard bug in ES
                                        • Auto pad configuration
                                        • Kodi b*mp
                                        • etc.
                                        We're working on it 😉
                                        voljega OldGreg jorgemagana olivierdroid92 4 Replies Last reply Reply Quote 7
                                        • Marcos Breviglieri
                                          Marcos Breviglieri @Marcos Breviglieri last edited by
                                          @oyyodams said in Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...):
                                          Hi friends,
                                          • Kodi b*mp
                                          • etc.
                                          Any news about these emultors problems on rpi3 version?
                                          BLUEMSX - Returns to the menu
                                          FMSX - Stop on a black screen
                                          HATARI - Returns to the menu after error message
                                            voljega Banned @OyyoDams last edited by
                                            @oyyodams Is the bugfix about displaying folder scraping included ?
