    Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...)
    Testers's corner
    testers wanted major upgrade pi3b
    198
    805
    919877
    • chris256
      chris256 @OyyoDams last edited by chris256
      @oyyodams @toniosj @moguai For those having problems, it may be related to the smb version. You could try adding vers=1.0 at the end of the line, for instance:
      sharedevice=NETWORK
      sharenetwork_smb1=SHARE@192.168.1.94:Games/recalbox:username=recalbox,password=******,vers=1.0
      lhari84 1 Reply Last reply Reply Quote 1
      • lhari84
        lhari84 @chris256 last edited by
        @chris256
        Just because I'm interested using this feature in future:
        Which SMB versions are supported? I've disabled SMB1 on my NAS for security reasons, is SMB2 or even SMB3 supported too?
        Thanks
        Pi 4:
        Sony DualShock 4 (2nd gen), 8BitDo Pro 2, 8BitDo SF30 PRO, Retroflag SUPERPi 4 Case, Recalbox 9.0
        Pi Zero 2W:
        GPi Case 2W, Recalbox 9.0
        • vincent-84
          vincent-84 @vincent-84 last edited by
          @vincent-84
          @vincent-84 said in Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...):
          @OyyoDams
          since the last release, ES always crash after the introductive video (black screen with the version of the release).
          I've try with a direct upgrading (from ES) first, and then I reflash my SD card with the same result.
          Any idea about that issue ?
          that's came after coping my old bios and roms folders
          @OyyoDams
          this is my issue with this last release (when I try to start ES from root) :
          "#lv10: /recalbox/share/system/.emulationstation/es_system.cfg files does not exist! [je confirme]
          lv10: System "favorites" is missing name, path, extension, or command!
          terminate called after throwing an instance of 'boost: : exception_detail: :clone_impl <boost: :exception_detail: :error_info_injector<boost: :property_tree: :ptree_bad_path> >'
          what(): No such node (gamelist)
          Rpi3b+, Superpi case, SFC30pro
            paradadf Staff @lhari84 last edited by
            @lhari84 this might answer your question regarding samba versions. I haven’t tested it myself though.
            https://forum.recalbox.com/topic/11528/smb-v2-support/5
            lhari84 1 Reply Last reply Reply Quote 0
            • lhari84
              lhari84 @paradadf last edited by
              @paradadf Great, thanks!
              Pi 4:
              Pi Zero 2W:
              • kos
                kos last edited by kos
                Prompt why on the Chinese gamepad analog sticks work as a simple cross? When pressing home button it on the computer and retropie all switches and recalbox not be switched. What could be the problem?0_1543838495951_HTB1gqkYnBDH8KJjSszcq6zDTFXaS.jpg image url)
                • pkerga
                  pkerga @vincent-84 last edited by
                  This post is deleted!
                  • pkerga
                    pkerga last edited by
                    @OyyoDams
                    same issue
                    vincent-84 1 Reply Last reply Reply Quote 0
                      voljega Banned last edited by
                      @matthieu24 did you read the first post ?
                      • vincent-84
                        vincent-84 @pkerga last edited by
                        @pkerga @OyyoDams @Bkg2k
                        That's a favorites issue.
                        I've deleted all the gamelist.xml contening favorites ( <favorites>true</favorites>) and the problem is solved.
                        But yet, I couldn't add any favorite. Adding a favorite on ES shows the symbol of favorites (the pad) AND the barred eye, and ES crashs when I want to restart.
                        pkerga 1 Reply Last reply Reply Quote 0
                          OyyoDams Staff last edited by
                          Hi again all, please read this post 🙂
                          • pkerga
                            i've tried... no succes
                            • Marco Polo
                              Marco Polo last edited by
                              bonjours,
                              J'aimerais bien une traduction en français de comment faire une mise a jour quand la version bêta(j'ai la première version et je voudrait bien pouvoir mettre les suivantes sans avoir a tout re-installer), je n'es pas tout compris(moi et l'anglais sic)
                              Merci pour tout le taf en tout cas !
                                OyyoDams Staff @Marco Polo last edited by
                                @marco-polo si tu as déjà la beta, il faut juste que dans recalbox.conf tu mettes updates.type=https://review-507-b&ast;mp-b-0jn0c0-archive-review-prod.recalbox.com pour qu'il aille chercher la mise à jour de la beta et surtout pas de la stable.
                                Marco Polo 1 Reply Last reply Reply Quote 2
                                • Marco Polo
                                  Marco Polo @OyyoDams last edited by
                                  @oyyodams Oui javait installer la première bêta et justement je voudrait bien pouvoir faire la nouvelle mise a jour !
                                  Alors j'ai fait comme tu dis et rien ne se passe, j'ai modifier le fichier "recalbox.conf" je sauvegarde, je relance ma recalbox et j'arrive a la liste des émulateurs sans que cela et fait de mise a jour ! ou alors j'ai rater quelque chose?
                                    @marco-polo tu peux faire une archive support ?
                                    Marco Polo 3 Replies Last reply Reply Quote 0
                                    • Marco Polo
                                      @oyyodams Archive support de?
                                      aerao 1 Reply Last reply Reply Quote 0
                                      • aerao
                                        aerao @Marco Polo last edited by
                                        @marco-polo said in Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...):
                                        Archive support de?
                                        Ouvrir votre navigateur internet :
                                        Sous Windows http://recalbox/help ou http://ip_recalbox/help
                                        Sous Mac / Linux http://recalbox.local/help.
                                        Un lien sera automatiquement uploadé et un lien vous sera donner.
                                        Poste le lien dans votre sujet en cours sur le forum ou dans l'issue que vous avez ouverte.
                                        Voilou ^^
                                        Marco Polo 1 Reply Last reply Reply Quote 0
                                        • Marco Polo
                                          Marco Polo @aerao last edited by
                                          @aerao D'accord Merci ^^
                                          • Marco Polo
                                            @oyyodams Voila le lien https://file.ac/QyQrT2-Yt3E/
