    Recalbox Rasberry pi 3 and Analog joystick
    Community projects
    recalbox rasberry analog joystick
    4002
    • creaturefactory
      creaturefactory last edited by
      Anyone know of a good tutorial to add Analog joysticks and small 16 mm and 12 mm buttons pretty much like a StreetFighter ll cabinet. I would also like to add a 5 inch hdmi powered screen for it as well. I've searched and it either requires Arduino or some odd set up and needs a breadboard. I'm looking for a cleaner soloution and more plug and play.
      • lackyluuk
        Something like this?
        https://github.com/recalbox/recalbox-os/wiki/GPIO-controllers-(EN)
        creaturefactory 1 Reply Last reply Reply Quote 0
        • creaturefactory
          creaturefactory @lackyluuk last edited by
          @lackyluuk
          Close but I'm looking for help with having Analog joystick, or like this. Some way of getting this joy stick to interact with the Rasbery pii 3.
          https://www.adafruit.com/products/512
          https://www.adafruit.com/products/3102
          • ian57
            ian57 Staff last edited by
            @creaturefactory : you can use an analog PS2 joystick (see bangoog or aliexpress) and convert them to digital one to wire the controls on GPIO thnaks to an LM339 chip :
            here is the schematic :
            alt text and the result :
            alt text
            this helped me to build a small cabinet with a 3.2" tft screen :
            alt text
            creaturefactory 2 Replies Last reply Reply Quote 0
            • creaturefactory
              creaturefactory @ian57 last edited by
              @ian57
              Thanks this is awesome!!
              • creaturefactory
                @ian57
                Can't I use this and have it wired up to the Rasberry pi 3 and have GPIO wires connected to the GPIO of the pi3?0_1489034579644_MiniAnalog Joystick -10k Potentiometer.JPG
                • ian57
                  @creaturefactory Yes I think so. It is the same type of joystick... only bigger 😉
                  101.4k
